Question about Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Screen has faint "water mark" looking images on both sides of picture
The picture is perfectly watchable. But there are two faint images running vertically on the left and right sides of the picture that are best described as looking like water marks on paper, or what it looks like if you try and remove a stain from clothes by using a dry cleaning solution and it leaves a faint ring. It looks a little like a faint vertical coastline on a map. It's on all channels and inputs. I have moved the set into another room and there is no change. I have cleaned the screen. There is an image flip/rotate feature and the 'stains' do not change position.
    President:
  • 1,284 Answers
Then the only possibilitiy at this point is the LCD panel having some kind of defect in it. Since you flipped the picture and no change it is a permanent mark or failure. Check to see if you have any warranty left as this will be an expensive part if needed. They do list a diffusion sheet part number PSHEP0288CEZZ that will probably be the first layer of the screen assembly.
Posted on May 10, 2007
Samsung LCD TV has pattern of short horizontal lines on screen.
The TV may be picking up stray radiation from another piece of equipment, try disconnecting and unplugging all other digi/cable/dvdplayers/phones etc. to isolate the offending article
Jan 24, 2018 | Samsung Televison & Video
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Black screen
If its LCD get the room very very dark and turn on--with a flashlight near the screen look closely at the screen to see if you see a very faint image of the picture or not---Most LCD flatscreen's (not Plasma) use what is called a back light to light the screen--light source.
If a faint picture can be seen that way the light is not on.
Dec 17, 2012 | Sceptre Televison & Video
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Picture goes black but still has sound
Use a strong light next to the screen and look for a faint image on the screen. If you see a faint picture, your backlight has a problem. Service shop time. Not a simple fix.
Mar 25, 2010 | Televison & Video
NEC plasmasync 42pd3
A Plasma Screen never need 're gassing'.
If you have verified the connections and leads are correct the the up converter is possibly faulty and in need of servicing.
Take it to an authorised NEC repair shop.
Jun 10, 2017 | NEC PlasmaSync 42PD3 42" Monitor
Red lines, Help??
when you replace the convergence amp board. u usally have to go into setup. or service mode and manualy converge the set. these settings are what perfect focus basis it reconvegence on. sort of the factory settings. these faint lines may also be a red crt overdriving too
Jan 03, 2008 | Samsung HCN5527W 55" Rear Projection...
Good picture for 30 seconds then screen goes black with a faint ghost of the image
the 12V is for speakers.. the 245bw takes regular 120V AC (same cord as your computer)
the buzzing is annoying, though. i don't know if it's a "feature" or just a side effect.. ie, if i could take the case off and poke around, i would. 4 times out of 5 it's some dumb piece of tin reverberating from a transformer or something..
Dec 03, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Blue image shadow on one side of the screen..Help!
Perfect! That is typically called "Ghosting" where there is a faint image shadow behind the image on your screen. I'm glad you were able to get it fixed!
Jul 23, 2007 | Mitsubishi WS-65809 65" Rear Projection...
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Sharp Aquos LC-20B4U-S 20 in. LCD EDTV Logo
522 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
