Question about RCA D52W19 52" Rear Projection Television
Tv shuts off
I have a rca d52w19 big screen tv. it will play for a couple hours when it sits overnight then will shut off, if you try to turn back on the power light will flash on and off but will not come back on. if you let it sit for 15 to 20 min it will come on and play for 30 min or so and then shut back off. were should i start?
  • ldcathcart Jan 06, 2009
    After it started shuting off I placed a box fan behind it thinking it may have been overheating and it continued shuting off the same. I can soder boards and have my own meters need to know where I should be troubleshooting on this kind of problem. When this goes down the power light flashes on and off about three times until it will not turn back on. If you let it sit for 15 minutes it will turn back on like nothing is wrong.
    Power has been plugged into two different houses and different outlets. Volts and HZ have been checked. No sleep timers are activated that was checked first. Thanks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, let's try a process of elimination:
  • defective major component (unlikely) - otherwise the unit will not even turn on;
  • heat related (unlikely but still is a possibility) - could only be verified with a hot air blower and/or a can of compressed air;
  • power supply board (likely) - standby +5VDC is being supplied even when in protect mode, but is the mains B+ available. Is there clicking sound when powering up? Is the same clicking sound preceding the auto shut down? If there is a clicking sound, it would be coming from bottom right front;
  • all others which may include:
  1. capacitors;
  2. coolant leak;
  3. cold solder.
This of course would require opening the unit, perform voltage measurements, determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual (chassis # ATC221 or ITC222) or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa.
Posted on Jan 06, 2009
    Scholar:
  • 91 Answers
I think it has gone into protection mode. this is caused when a short circuit is detected by the power management system inside the tv.
Try a hard reset: Unplug the power cord for a full 4 hours; then try it again and see if it will clear the protection fault and reset it.
If the reset does not help you will need to have a tech look at the set and take voltage measurements inside to determoine which section of the tv has failed and what components will need replacement.
  • 716 Answers
Heres What You Do Find A Company That Does Free Estimates They'll Come Out And Look At It And Tell You Exactly Whats Wrong With It. Then Decide If You Can Fix It. If Your Like Me You'll Try And Fix It Anyways. Once You Find Out What Part You Need Post It Here On Fixya And You'll Find What Your Looking For. Take Care And Good Luck
  • 40 Answers
Try checking for bad/bulging capacitors on the circuit boards and replace them. some may not show signs of being defective so test them anyway. Also look for any other defective components/burnt components, making sure all solder connections are intact. good luck!
    Genius:
  • 2,035 Answers
Try to plug the tv in different Ac mains and check if the tv turns off ,and make sure there is no sleep timers is activated on the tv...
Good luck...
Posted on Jan 02, 2009
  • Anand Kumar
    Anand Kumar Jan 07, 2009
    Well this seems to problem with board in the tv ,you need to trouble shoot step by step to find the fault ,you can have a service manual..from this link make sure you get right chassis number before order for manual :
    http://servicemanuals.vstore.ca/....
  • 679 Answers
It sounds like a crack in the pc board, this is very hard to troubleshoot, what usually happens is the board heats up and expands seperating one or the pc board circuits thus breaeking contact. If you have time leave the panel off the back and let it run, chances are if it stays on that's what it is. Then you will need a voltmeter to see if the voltage cuts out when she heats up. Put a fan next to it if you can't leave the back open just to see if it's heat related
My rca 52" tv was working this morning than shut
Replace the Deflection board. You can get the replacement deflection board from www.tvrepairworld.com
Nov 08, 2010 | RCA D52W19 52" Rear Projection Television
RCA D52W19 Flat Screen TV capacitor 2200/16 needs replacing. But I can only find 2200/10. Think this is good enough or should I go higher in voltage like 25 or higher?
the common practice is never go down in voltage rating. as a technician i would defintly not go down to 10 volt i suggest you go up 25 would be ok if you can get it to fit
Oct 16, 2010 | RCA D52W19 52" Rear Projection Television
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
My RCA Bigscreen HDTV will not turn on.
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
May 06, 2009 | RCA D52W19 52" Rear Projection Television
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
On off switch
clean front panel contact switches on/off vol- vol+ use contact cleaner .
Dec 03, 2008 | RCA D52W19 52" Rear Projection Television
TV shuts off by itself and has a burning smell
mine is doing the same thing but i was able to pinpoint it to a capacitor arching and smoking. haven't replaced it yet so i'm not sure if it's just a bad capacitor or a more involved issue.
Jul 29, 2008 | RCA D52W19 52" Rear Projection Television
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
RCA D52W19 power problem
these set is what i like to call VAlue sets.. you can get these for 800 at walmart. If you smell something theres a good chance its what is called a flyback transformer... i repair that averages about 300 to replace. Caution it may be more. DANGER, Do not attempt repair of set unless qualifed to do so tv generte high and leathal voltages.
Jan 01, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
19 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
