Washing machine error c1
I am having the same problem with my Kenmore washer. Did you get it resolved? What was done and how much did it cost?
Thanks.
  • 15,935 Answers
The CL fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
You should have been able to clear the display by pressing the STOP/CANCEL button.
If you try running the washer again and continue to get this fault code even with a small or medium load, I recommend calling a service technician to diagnose and repair the washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
I have a Kenmore He 2 plus washing machine, which is getting an error code (F24). Can someone help. I'm not sure if this is an easy fix or not, nor what needs to be done to stop this error. Thanks
Hi
F24 is a water temperature sensor error. You have to unplug the washer and check the water temperature sensor and its connections, if that is fine then check the resistance of the heating element and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 07, 2011 | Kenmore 3.2 cu. Super Capacity Plus Top...
I have a Kenmore Elite Oasis top load washer and keep having the UL code pop up. I have leveled and re-leveled the machine with no avail. I have also ensured that my level is still in working order. If...
You can try to clear the Error Codes;
  • Unplug the washer for 1 to 2 minutes.
  • Disconnect the U.I. (touch pad).
  • Plug the washer back in for 1 to 2 minutes.
  • Unplug the washer.
  • Plug the U.I. back in and then plug the washer back in. Codes should then be cleared
  • if that doesn't work that indicates a problem with the software in the machines control board replace board with this part number 26-110-8564393R and this should resolve the problem part cost about 114.16 if you like go sears parts direct .com or call parts directly at 800-573-6456
Jul 15, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite comes up with F35 not sure what that means and locks my machine up
Hi
In your Kenmore F35 error indicates Analog Pressure Sensor Failure. To resolve this issue you have to start with checking the pressure hose and the air trap, try to clean them for any clogs and check if they are fixed correctly. After doing this if the issue is still not resolved then you'll have to check and replace the water level switch.
Thanks
Rylee
Oct 29, 2010 | Kenmore Elite 45986 Front Load Washer
What is the cost to have a repair if the washer is flashing f 11?
Hi
Thanks for using FixYa. F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | Kenmore Elite 45986 Front Load Washer
Washer stops and flashes F21
Hi
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Kenmore Elite 45986 Front Load Washer
What does the F06 error code on the Kenmore Elite HE3 washer mean?
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite calypso codes a C1 and quite working
Maybe "CL" From User Manual:
“CA” or “CL” (Current Limit)
Is the washer overloaded?
Press STOP/CANCEL to clear the display.
Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore washer model # 110.24086200
The C1 code indicates the "instantaneous current limit" trip. This signifies problems with the drive motor, thermal protector, motor controller. Overloading the machine will cause high amps and trip the unit. Instantaneous current trip occurs if there is a current spike of 26 amps instantly at the motor windings in which the motor overload trips. check bearings for lubrication - or as stated above overloading the washer.
Sep 06, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
