Question about Motorola Mobility HS810 Consumer Headset
Wont find headset
When i go to my bluetooth search for devises it NEVER finds it.
Fold the mike boom to rear, push center football shaped button down for about 3 sec until it stays lit (not blinking) unfold the mike boom make sure it stays steady lit (no blinking) scan for bluetooth Walla!
Posted on Feb 22, 2009
My iPhone 4 bluetooth won't discover the plantronics 220 Bluetooth earpiece for pairing. Both devices are on including bluetooth on my phone
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode ***(usually you have to hold the power button for 7-10 seconds)***
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 31, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Same problem as the majority, enjoyed em227 with my obsolete phone but now wont work with my iphone4
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Dec 29, 2010 | Southern Telecom Emerson Bluetooth Headset...
I purchased a Emerson228WM Bluetooth My 3G Iphone will not pair with this and I was told it would Help!!!
Dec 28, 2010 | Southern Telecom Emerson Bluetooth Headset...
My uniden bt108 bluetooth headset would not pair with my new Iphone4. My Iphone 4 couldn`t even recognize my bt108.
Dec 17, 2010 | Uniden BT-108 Bluetooth Headset
Unable to pair Blueaction Wireless Headset BAE-825 with iPhone, and I cannot locate a user manual, either.
Dec 13, 2010 | MyNetDeals BlueAction Wireless Bluetooth...
The ps3 keeps scanning and wont pair with the headset
BELIEVE IT OR NOT, SOME HEADSETS ARE NOT COMPATIBLE WITH PS3. I HAD SOME PROBLEMS WITH MY PLANTRONICS 3XXX. I FOUND THE SOLUTION WAS THAT I WASN''T HOLDING DOWN THE BIG BUTTON ON THE FRONT LONG ENOUGH. WHEN I WOULD PRESS THE BUTTON, WHILE PS3 SEARCHED, I WOULD ACCIDENTALLY TURN OFF THE BLUETOOTH.
BE SURE THE BLUETOOTH IS POWERED ON. ONE TAP SHOULD DO.
WHEN PS3 BEGINS TO SEARCH, HOLD DOWN BIG BUTTON, AND DO NOT RELEASE UNTIL PS3 FINDS.
IF THERE IS A LIGHT ON THE BLUETOOTH, IT WILL PROBABLY BLINK A COUPLE TIMES WHEN FOUND. THE NAME OF THE BLUETOOTH WILL ALSO SHOW ON THE TV.
OH YEA, BE SURE TO CHECK YOUR PS3 SETTINGS.MAKE SURE IT IS SET TO ACCEPT BLUETOOTH HEADSET CONNECTION.
Dec 09, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
I can't get my lg xenon to pair w/ any bluetooth headset. I've tried 2 now & it just doesn't recognize the device. BT is on, visibility is on...I've gone through several exercises with LG customer...
Try searching a new devise and it should recognize it either that or your bluetooth headset is dead or out of range meaning that you need to be closer to it when you search.
Aug 03, 2009 | LG Xenon GR500 Cell Phone
Need to know how to sync bluetooth device to current cell phone
to setup your bluetooth you will need to go to the phone settings, look for anything that deals with connectivity, once you find it you will see the bluetooth option, click ON then you will need to scroll down till you see search for devices. Turn on the bluetooth devise before searching for devices. The cell will automatically search, once it finds the devise it will ask or show all the devices in the area, look for your equipment, pair it and Voila!! Hope this was helpful
Good Luck =)
Jun 05, 2009 | Just Wireless Bluetooth Headset Wireless...
Reprogramming bluetooth
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Mar 15, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth H700 will not pair with my Envy 2
http://www.motorola.com/mdirect/manuals/QSG-H700_9499A88B.pdf
Can you tell me if it works i'm thinking of buying this headset
Mar 05, 2009 | Motorola Mobility H700 Wireless Headset
Motorola Mobility HS810 Consumer Headset Logo
185 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
