Question about Humax DRT800 TiVo 80-Hours Video Recorder
Humax Tivo Stuck on the welcome screen
I have a Humax Tivo DVR w DVD it is stuck on the welcome screen for Tivo. Ive had it for two years with no problems. Ive tried disconnecting and the unit to restart but no joy.
Any ideas?
  • donna_franci Mar 02, 2009
    i've had mine for about 3 years..with the same problem..its just stuck on the welcome screen..so far no solution..humax is telling me i have a defective unit..and for $379 they will send me a refurbished unit..i dont think so..i can get a new unit for that much..
I just had the same problem with mine and found another post that at least fixed mine.
I had a DVD in the unit as it was restarting. I took a flathead screwdriver and opened up the DVD slot by inserting at the top right corner and opening the door. On the inside, at the bottom right, is a button that ejects the DVD player (the eject button on the outside won't work while it's booting up). I ejected the DVD that was in it, unplugged the unit for 30 seconds, and then it rebooted just fine.
Hope it works out for you too...
Posted on Aug 20, 2009
I need installation instructions for a tivo drt-400 humax dvr
No. There is no tuner in the Tivo . It will record cable or satellite but not off air antenna.
Nov 01, 2014 | Televison & Video
I have a DVD that is stuck in my TIVO. The screen
Take the DVD player aparts,take out DVD disc out of the drawer,check the open/close drawer button again.Same result indication on the screen say is open infact it close.The motor the help open and the dvd drawer it dead.Need the motor replaced.
Jun 26, 2010 | Humax T800 TiVo 80-Hours Video Recorder
My dvr is stuck int the welcom pwering up screen
May be a little too late, but usually the problem is the Hard Drive with that. There are several places online to buy a new hard drive with the proper software already installed or you can buy InstantCake and a blank hard drive and make your own
Oct 28, 2009 | RCA DVR40 DIRECTV DVR with TiVo
Our Toshiba RS-TX60 Tivo-DVD is stuck on 'Welcome'
Could Be a Bad Drive.
These units sometimes take a long time to boot.
Wait about 5-10min.
Replace Drive
Aug 09, 2009 | Toshiba RS-TX60 DVD Recorder
Humax DRT800 DVR recorder has no sound
Loss of sound is often a problem with the SCART connections. The SCART may not be pushed in securely, or if the SCART is old the pins may not be good. Check SCART is securely in, or try another SCART lead.
Mar 13, 2009 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
I can't figure out how to record two shows at once on my DRT400 Humax Series 2 Tivo.
You can't. The unit doesn't have dual tuners, so your stuck with just recording one show at a time. Sorry.
Dec 27, 2008 | Humax DRT400 TiVo 40-Hours Video Recorder
Tivo won't eject bad DVD.
unplug power. hold the eject button while plugging in the power cable
Oct 22, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
No picture on Humax DRT400
Try taking the cover off and taking an air compressor and blowing it out real good. I have the exact same one and I had the exact same problem and after i blew it out it worked like new.
Jan 24, 2008 | Humax DRT400 TiVo 40-Hours Video Recorder
Humax Tivo will not record to DVD
After the update to 1.15 I had to delete EVERY recording on the unit. After that, any new recordings would burn just fine. However, some have found that same failure even after a hard reboot (repower). Called Humax level-1 support and they suggested a replacement unit so I swapped it out. But I've since learned that TiVo "pushes" a DVD firmware patch (possible supplied by Humax) from 1.08 to 1.15 and that patch is the culprit. That patch is suppose to make the DVD burn at a higher spin rate. After talking with level-2 Humax support they heard of the problem and said "the unit is working as designed", meaning, the DVD drive manufacturer specs say the drive is capable of a faster burn rate. So now I have Humax DTR800 #2 and so-far-so-good, but TiVo hasn't pushed the patch onto the box yet!
Nov 10, 2007 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
The Screen shows "welcome. Powering up....." and is stuck
Direct TV has been working on numerous software issues. Some patches have been downloaded for TiVo that in some cases have caused problems. In your case, it is more possibly an indication that the hard drive is not running and you have a possible hardware failure. When you rebooted and became stuck on the "welcome, powering up screen", it could be an indication of a software glitch or a hard drive failure. I would go with a hard drive failure. Since this is a Hughes Receiver like mine and you own it, you could try a drive swap with another TiVo drive out of a like receiver. If one is not available, you may have to purchase one. Pre-configured and initialized drives are available from www.weaknees.com. I have no interest in them, but that is where I buy Tivo pre-configured Hard Drives from. You can get replacement or upgrade Maxtor Drives preconfigured from them for this specific brand and model of TiVo DVR. A drive swap would be cheaper troubleshooting. There is also a possibility of a problem with the built-in IDE controller or the power supply on your receiver which can't be determined until you do swap out with a Known Good Drive to eliminate a hard drive problem. If you are able to swap it out and If the good drive works, then your old one has corrupted data and would need to be re-initialiaed and reloaded. If it is an older smaller (35 hour) drive, you would be better off with a new replacment since the loading is a somewhat lengthy process and must be done on a computer running the Linux Operating System.
Nov 09, 2006 | Hughes HDVR2 with 105 Hrs DirecTV DTV...
Open Questions:
Humax DRT800 TiVo 80-Hours Video Recorder Logo
473 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
