Sony KDS60A2000 Thermal fuse location
Where is the thermal fuse located on the Sony KDS60A2000?
2 Suggested Answers
  • 4 Answers
SOURCE: Where is the thermal fuse
It's actually pretty simple to replace.
Go to
http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70
and request the troubleshooting package. It has step by step on how to replace the thermal fuse and where to get the parts.
No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
Posted on Dec 04, 2008
Not heating
The Most common problem is a bad thermal fuse.
1 the thermal fuses are located in the cabinet of the dryer under the drum
they can also be located on the front of the blower wheel housing. on the back wall of the dryer or along the heating element can.
2. some kenmore, whirlpool machines have these fuses located in the rear of the machine.especially when the lint filter is located in the top of the dryer.
3. the heating element can also be bad.
4. if you have an ohm meter you can check the continuity of the thermal fuses,as well as the heating element.if there is no continuity on any of the above mentioned parts. Replace the faulty parts.
Also check my tip on thermal fuse locations
Jan 09, 2011 | Whirlpool Dryers
Where is the thermal fuse locates in the sony KDF-e60A20?
Hi, the thermal fuse i located right next to the lamp is actually mounted on the lamp casing, deep inside the tv, you will need to disassemble the tv in order for you to get to it, if don't have any skill is better that you call the repairman and you are looking at $250.00 repair.
good luck
Jun 22, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Help with my sony tv
The thermal fuse is located close to the front of the set just to the right of center, looking from the rear of the TV. Mounted near the lamp. Part# 191002393. Once you have the new part, it should not be difficult to find it in the set.
May 16, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony Grand WEGA 60" LCD TV Problem
TO FIND YOUR THERMAL FUSE ITS LOCATED ON TOP OF THE LAMP FAN HOUSING SHOULD BE 2 BLACK WIRES RUNNING TO IT IT'LL HAVE A LITTLE BLACK SQUARE ON THE END OF IT THATS YOUR THERMAL FUSE
Jan 06, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Thermal fuse
the thermal fuse is located on the heater box,the main fuse is located on the blower box,let me know-mike
Oct 07, 2008 | Kenmore 73952 Gas Dryer
the thermal is on the heater box on the right side it has two white wires going to it
you need to remove the high limit stat and bracket and the heating element to get to the safety stat
Jun 13, 2008 | Crosley CDE6000 Electric Dryer
Thermal fuse
Someone said it is the thermal sensor.
Jun 12, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Thermal Fuse
The thermal fuse is usually located near the lamp to prevent the lamp overhaeting and damaging the set. Sony uses two types of thermal fuses: the first type is a circular metal type, about the size of a quarter with two metal tabs for push on lugs that connect to the TV. The second type is a small plastic half moon type woth wires coming from the base. Contrary to what you might read elsewhere on this site, it is VERY IMPORTANT that you mount the new fuse where the old one was, for safety reasons.
May 21, 2008 | Sony KDF-E55A20 55 in. LCD Television
6 red light blinks-possible thermal fuse prob.
The thermal fuse is located under the optical block. However the optical block needs to be removed to replace it. So unless you are very familiar with the disassembly of this tv I suggest you have a Sony ASC to do the repair work for you. You don't want to take a chance of damaging the optical block.
Jan 28, 2008 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
249 people viewed this question
Top Televison & Video Experts
Electro Med Services...
