Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
There is water leaking from the bottom of the fridge
There is water (more than 2 towels can dry up in a 24 hour period) coming from the bottom of the fridge. It seems to be coming from the far right side. This is a side by side Kenmore 27.
  • 163 Answers
Hi!!! It seems that your drain line in the freezer section is plugged remove the bottom tray and check for ice or water if you do the unplugg your drain line with a hair dryer..good luck..
Posted on Jan 04, 2009
Fridge not cooling after doors left open for at least 2 possibly 5 days. What should I do? Turn off for 24 hours? I have limited skills when it comes to repairing anything. Thanks!
It would have been far easier to switch off and just scrape the inside with a pladtic scraper ...then give it a good wipe and after a couple of hours plug it back in.
Jul 04, 2015 | GE Refrigerators
A lot of water leaking
You probably have a clogged drain line. Unplug the fridge for 24-48 hours with a towel by the drip pan for a simple fix.
Jan 22, 2012 | Kenmore Side by Side Refrigerator
HMG1947 with ice maker. Intermittent problem getting worse! I am getting water on the inside bottom, which will leak out onto the kitchen floor if I don't catch it with paper towels under the bottom...
Is the freezer section cooling properly. If yes, then problem is drain hole blocked in freezer section.There is a water drain hole, which runs to the drain line.But if the drain hole is got clogged by ice, then water will leak from other end and you get water in bottom drawer.-------- try manual defrost procedure.----------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check, do you notice the same problem, if yes then defrost assembly board is faulty.But in most cases defrost reset procedure helps.----------- Thanks.Helpmech.
Sep 16, 2011 | Admiral Refrigerators
1996 Frigidaire Fridge/Freezer.... The fridge is leaking underneath suddenly, soaking a full sized towel every 2 hours. The water rung out of the towels is slightly brownish in color. No leaks can be...
I'd check the water supply line to the fridge. If kinked of damaged, may be the source of the leak (make sure that the the connection point to the building's cold water pipe isn't leaking - and simply running down the supply line to the fridge!)
Of course, it could be a cracked solenoid valve (turns water on and off when the ice maker calls for water for ice), loose or broken clamp, broken filter (if equipped), etc. All these connection points in the water supply lines should be visible.
Unplug the fridge as soon as you can reach it before working on a wet floor with live electricity.
Please rate my reply if it was helpful - good luck!
Aug 19, 2010 | Frigidaire FRT21P5A Top Freezer...
Water drip
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Nov 01, 2009 | Refrigerators
My dishwasher is model DD603 and it turns on by
There is a water leak in the bottom housing and a leak sensor detects to give a F1. Pull out the tube and put your hand in the front from the left ( only on this side has enough room to access) with the small towel to dry out the water on the bottom housing. After dry out, unplug the power for at least 24 hours so the sensor can be dried out and reset. However, make sure to fix the leak from the top seal, otherwise, it keep happening.
Oct 10, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Side by side leaking water from under freezer side
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint HSS25GFP Side by Side...
Water is pooling under the veggie bins- watere even came down via freezer door gasket to the floor. I have been noticing water in the right meat bin and in veggie bin, and under them for 2 weeks. most of...
Sep 12, 2009 | Liebherr European Right Hinge Fully...
Dishwasher "F1 and a small wrench symbol" blinks continuously
The unit has a leak causing floor sensor activated.
1- Unplug power cord.
2- Pull oull half way the drawer so an access from the bottom left could be obtained.
3- Use Paper towel or small towel to dry out the water on the bottom housing.
4- Wait for 48 hour so the sensor can be dry out.
Plug in the power cord. The unit will act as normal.
Your problem is solved.
However you can't operate since you know you have a leak problem. Let me know how it in progress and you decide to call service to fix it or I can guide you to fix it. Good luck.
Apr 05, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
248 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
