Question about HP LaserJet 1320 Printer
Printer dosen't print
The middle light (triangle with !) is on steady and I can;t seen to ew-set the printer. Any suggestions?
Thanks.
    Genius:
  • 2,120 Answers
If you remove the toner cartridge and do not see jammed paper, it's probably jammed in the FUSER. Repost and I can help you remove the fuser.
Posted on Jan 02, 2009
Why does my hp envy 5535 stops in middle of print job
Please try following the steps below and let me know if that may help:
  1. Open the HP Envy 5535 software, then click the Printer Home Page (EWS) link.
  2. Click the Network tab.
  3. Click Networking , and then click Network Address (IP) .
  4. Click Manual IP , and then click Suggest a Manual IP Address . A manual IP address, Subnet Mask, and Default Gateway displays.
  5. Be sure to take a note of the IP address and Confirm the changes, then close the EWS page.
  6. From the HP Envy 5535 sotfware click the Utilities tab, then click on Update IP Address.
  7. Type the manually configured IP address, click on Save and confirm.
  8. Open the control panel and go to Devices and Printers.
  9. Right click the HP Envy 5535 icon and select Printer Properties.
  10. Open the Ports tab.
  11. Click teh Add Port button, select Standard TCP/IP and click on New Port.
  12. Follow the steps by typing the manually configured IP address and confirm the changes.
Read More... HP Printer Support
Thanks,
Jul 23, 2014 | HP ENVY 5535 E-ALL-IN-ONE PRINTER
My printer will print one page and stop printing in the middle of the second page.
I think you are seat only one print one time so plz check it. Go to printer option and setting. One time you check printer after your printer which mode show like active print mode, print error, hold print mode etc.
I suggest you Full uninstall printer driver and re-again install printer driver. If not solved then change printer cable.
If more help contact Dell printer Support Technician. and TechSupportPrinter expert team.
Thanks.
Jan 11, 2014 | Dell Photo 926 All-in-One Printer
Display bad, jumbled, cannot read screen. Lex
If you're using a Macintosh, you should be able to check supplies by going to System Preferences > Print and Fax > Options and Supplies > Supplies Level. If you're using Windows operating system, there's no other way to check it unless the printer is on the network. It can be seen by accessing the embedded web server(EWS) page. To access EWS, go to Control Panel > Printers/ Printers and Faxes. You should see something like this:
You need to look for the IP address of the printer. On the image, it's the one that says http://10.194.200.217. After getting the IP address, open internet browser (e.g. Internet Explorer) and type the IP address in the address bar as shown:
After typing the IP address in the address bar and hitting "Enter" on the keyboard, you should see the EWS page with the supplies level. Otherwise you need to have OP panel serviced to check supplies. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Apr 26, 2010 | Lexmark C760 Laser Printer
I have a HP LaserJet 1320n printer and it will not print. An orange light keeps flashing by the triangle with an exclamation point in it. I printed a test page and it was okay. It will not print...
Possible Solution to your issue!
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state
Feb 23, 2009 | HP LaserJet 1320n Printer
Printer is offline
go in control pannel> printer> right click on your printer there was option use printer online click on it
Jan 17, 2009 | HP Deskjet 3915 InkJet Printer
My printer icon on taskbar has a yellow triangle and wont print a
If you haven't already done so, might I suggest you uninstal the printer and re-instal as per the instalation manual.
This normally resolves these issues. Also make sure this printer is set as your default printer.
Hope this helps
G
Jan 13, 2009 | Dell 922 All-In-One InkJet Printer
What does the light mean?
the ! in the triangle means manual feed or "continuable error" which means that the printer is manual mode. or there is a paper feed problem.
you need to check the HP print software, make sure all the printer setting are correct.
if so, then check the printer paper tray, make sure they are in working order, and there is no paper jam on the paper path from the tray to the output.
The manual feed use different paper path, so check the tray path.
then unplug the printer from the computer and shut down the printer.
wait 2 minutes, power up the printer and connect the printer tot he computer.
Dec 16, 2008 | HP LaserJet P2015dn Printer
Problem. Help please
If the light is steady, the manual says possible problems are
  1. it is out of paper
  2. paper is jammed
  3. one of the doors is open
  4. the toner cartridge is missing
Jul 17, 2008 | HP LaserJet 2100 Printer
Laserjet 5L Hangs on Single Sheet Input Jobs
This probably means that the document you printed is set to manual and the printer is waiting for input
try this:
print the document, when the data light is on, press the button on the printer, does it print? if yes go into word and under page setup set the printer to "Auto select" for the paper tray.
or remove paper, print, when the data light comes on, insert the paper into the single sheet tray
hope this helps
thanks for rating
Jan 16, 2008 | HP LaserJet 5L Printer
HP LaserJet 1320 Printer Logo
128 people viewed this question
Seeker5211
Seeker5211
