Question about Marantz PMD222 Handheld Cassette Voice Recorder
No playback sound for my Marantz PMD222
Hi, I have a PMD222 and I haven't had much pracetice with it. I really have no clue...but anyway. I have tried to simply play a cassette tape in there and I have no sound. I tried to plug in little desk top speakers and I still hear nothing. I see the tape rolling and the VU meter jumping but I just don't hear anything. Can you help?
2 Suggested Answers
SOURCE:
SOURCE: How can I digitize cassette tapes using the Marantz PMD670?
Take a set of RCA Jack cords (4 jacks) and on the tape recorders "out" jacks attach one pair and on the PMD 670's "In" Jacks attach the other pair. Set the tape a few seconds before where you want to record , set your levels to where you want them, start the recorder then start recording with the PMD.
You may need to test record a few seconds to make sure the recording is at the level you want it to be. Plug in a set of headphones to the PMD and listen in from time to time to make sure it's recording OK.
There you go.
Best,
Dan
Posted on Jul 13, 2010
I have a marantz sr3001 and the sounds and image is good but the picture is in black and white. How do I get color?
If you're using component cables I would suspect one is not connected or working. Isolate by swapping them around. OR bypass the whole receiver. What does it really do for external source video anyway besides offer opportunities for cable issues and degradation?
http://www.retrevo.com/support/Marantz-SR3001-Receivers-manual/id/2536ag201/t/2/
I always run my video directly to my TV.
Sep 11, 2011 | Marantz SR3001
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Hi,i have connected phono cables from mixer to anolog in on marantz dr4050 and from anolog out on marantz dr4050 to input on amp,there is no sound unless you turn levels to max and then it is very quiet...
So you're saying an unnamed mixer is feeding a potential analog signal to a CDR. You're monitoring the CDR output at an unnamed amp.
You haven't established that there is any signal to BE heard.
WHAT is the actual source sound device (BEFORE the mixer)? Is the source input visible on the CDR when it's in Record Mode?
Have you perused the manuals?
NEVER USE EXCEPTIONALLY HIGH VOLUME SETTINGS FOR TROUBLESHOOTING. If a signal is inaudible at half volume it's effectively not there. YOU WILL BLOW SOMETHING UP WHEN YOU FIND THE MISPLACED CONTROL AND FLIP IT.
Jun 07, 2011 | Audio Players & Recorders
Hi, I have recently purchased an SR7005 which is connected to an HD PVR via Audioquest Cinammon HDMI cable. While watching programs, I lose audio immediately after an advertisement break. If I pause...
If you are watching adverts that implies a broadcast TV sound signal. What happens is that the broadcaster will switch off sound especially Dolby signals during add breaks. Therefore it could be your TV that stops sending the sound to the Marantz. So check the sound settings of you TV. It might have an auto feature that detects the signals, that could be switched to manual or just a wrong sound signal that causes the problem.
Jun 12, 2017 | Marantz SR7005 Receiver
I want to use the mic xlr it is not working
Lets verify the simple stuff first. Make sure that the unit is set to use the "external" mic rather than the internal. If it is set that way, then there may be an internal problem. I will look up the service manual and get you more specifics should they be required. Please update this with the status.
Thanks,
Dan
May 12, 2010 | Marantz PMD222 Handheld Cassette Voice...
What would work better for Marantz SR 4200 Apple Composite or component cable? In order to play music through the amp as well as watching videos
Component Video is a big step up the food chain in quality. Component Video inputs are for video only, not for audio. I don't see Component Video inputs on the Marantz SR-4200; only Composite and S-Video. S-video would be a step up from Composite and it carries analog stereo sound.
You don't give any clues as to the source's audio capabilities.
Digital Audio of either flavor is preferable. Grab the best possible TV-related audio from your Cable/Satellite box to the Marantz and run a pair of RCA audio cables to your TV just in case you want to watch the weather channel without hi-fi sound.
Mar 18, 2010 | Marantz SR-4200 Receiver
Marantz CDR-510: Playback is good , recording is distorted
If this brand of media is new to you and the symptom is unique to it, I'd try a different brand.
Monitoring during record would never reveal media problems as there is no immediate playback after record as on old-school 3-head tape recorders.
I've had similar intermittent problems and I never could find a pattern to it except that it always seemed to be on low-end media. My best advice would be to try to find a pattern in your instance and make a change that avoids it. Then publish what you learned for us.
Good luck.
Mar 14, 2010 | Marantz CDR510 2-Disc CD Recorder
Radio channel coming through on cd zone
Sounds like an internal prob within the reciever, since recievers have radio tuners in em, maybe a prob in the input switching in it. I assume you are running unbalanced rca cables out of the dvd player into the reciever as it probably doesn't have balanced input capability, unbalanced lines are susceptible to R.F.I. ( radio frequency interference ) but I doubt if that's the problem here unless maybe you are running very long cable lengths from the dvd player to the reciever. Try using a different input and see if the problems still there, can use any input other than phonograph really as they are all line level inputs.
Aug 02, 2008 | Marantz ZS5300 6-Channel Amplifier
Popping sounds in stereo during playback of burned cd's
Is it just the analogue inputsthat do this? Soulnds like a faulty input board.
Sep 16, 2006 | Marantz CDR631 CD Recorder
Marantz PMD222 Handheld Cassette Voice Recorder Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
