Question about 2wire 2700HG-B Router (2700HGB)
Stronger Wireless Signal with 2701HGB Router?
I had a computer savvy friend install a wireless router in-line with the 2wire to get a stronger signal with it's external antenna. The lap top reads the signal and will connect to it but there is no internet through the 2nd router. The 2nd router is a Netgear WGT624 by the way.
  • poobear1227 Apr 11, 2009
    I have a similar problem. WIreless adapter from two other computers does not pull a strong enough signal , can I buy a dlink router to boost signal?
  • 2,460 Answers
Netgear's web site has an excellent tutorial on how to do this. It involves turning off the DHCP on the Netgear, and linking the LAN prots of the two routers. There is no connection to the WAN port of the Netgear.
Here's the link http://kbserver.netgear.com/kb_web_files/n101236.asp
Carl
Posted on Jan 02, 2009
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear RangeMax Dual Band Wireless-N...
How do i change channels on my router
You change the channel in the router's wireless setting.
This does not give you a stronger signal BUT you can select a different channel so you do not get interference with other wireless routers in your area that are broadcasting on the same channel.
Oct 15, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Only get 1 bar on my i phone 4 cloe to the router
What you can do here to correct this problem is to access the router setup page and play around with its wireless settings that will provide a stronger signal for your wireless network , the most possible settings that you can change to improve the signal from the wireless router is to change the wireless channel of the router and see which channel works fine with your wireless network and with your IPHONE.
Mar 04, 2011 | Linksys WRT300N Wireless Router
I have a verizon westell 7500 gateway router. Will I be able to use a netgear WG111 2v wireless adapter to get a stronger signal from it for my laptop?
I'm not sure what you are trying to do. Is the signal too weak?
You could use the router to extend the range with the proper configuration. Either that, or purchase a wireless extender that does just that.
You won't get a stronger signal. A router does not boost a signal. It can pick up the signal and rebroadcast it using a different IP.
Jul 23, 2009 | Computers & Internet
Linksys wireless b router
Weak signal problem can be fixed by firmware update however, if the client computer is too far from the router, it can't be helped. What you need is a wireless range expander. What it does is give you another 100% signal or atleast stronger signal to the spot or area where you have a weak or dead signal.
Jun 29, 2009 | Linksys Wireless-G Broadband Router
My Linksys network adapter is very slow to connect
Ask them to review you connection speed to make sure your getting the speed you ordered. Linksys is usually pretty good. See if it's faster WITHOUT using the wireless (plug directly into the modem). If it is I can only think of two things... Ether you need to relocate your wireless modem to acheive a stronger signal OR if your signal is strong on your adapters end, you could always upgrade to a different wireless adapter that can handle faster conections.
Jun 27, 2009 | 2wire (1000-400108-001) Router
I have a ACER TRAVEL-MATE 800LCI...with wi-fi wireless...sometimes the wireless works some times it doesnt...what kind of router or what ever will help me get a stronger signal from my house...please help...
put up the high level things then you get it very stronger signal now you not get be'coz of the signal low strenght is not there so he can't caught the signal so pls change it in the high level
Feb 22, 2009 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Get a stronger signal
You are pushing your luck at 70ft. You can probably get booster ariels for your router that can boost the output signal for approx £10.
Dec 13, 2008 | Encore ENUWI-G2 802.11G WIRELESS USB 2.0...
Choosing a stronger router
You can get this one its WRT300N this a router that uses the latest wireless N technology which means a wider range and faster speed but using this router in order for you ro use the wireless N technology you may need a wireless N adapter also on your computers.
But if you want since you already have a existing wireless network juts get a wireless range expander to repeat the signal of the router so it will reach your XBOX this is the model WRE54G.
May 16, 2008 | Linksys Wireless-G WRT54G Router
Wireless router
I think 2wire routers are good in providing signal strength. Contact the 2wire vendor regarding your requirements.
take care
May 01, 2008 | AT&T High Speed DSL Modem
2wire 2700HG-B Router (2700HGB) Logo
1,236 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
