Question about Milwaukee 5615 21 Factory Reconditioned 1 3/4 Max Hp Bodygrip Router W/ Case
I am unable to get a tight fit on my router bit.
The bit is not tight when running my wood through the router. The bit comes loose and raises.
  • 2,176 Answers
Could be a couple things. First how is the shank on the bit e.g. is it worn down, second is it the right size for the collet being used (have to ask) and what is the condition of the collet and collet nut. What I would do is make sure there is nothing to prevent from completely tightening the collet nut. Also make sure if the collet locks into the nut that it is properly installed. Lastly make sure that you use the wrenches provided to tighten the assembly. If this doesn't help please provide the model number and brand and I will do some more research.
Posted on Jan 03, 2009
Collet stuck in shaft.
On some models the collet stays put on purpose. You don't have to remove the nut either. But if you really do have to remove the collet and it is the type that is supposed to come out (maybe you need to use the 1/4 inch collet) then just stick a bit into it without the nut and give the bit a sideways whack with a piece of wood. If the collet has been pressed in tight by the nut without a bit in place, then you won't be able to fit a bit into it, and maybe the collet is ruined. Find the largest diameter shaft you can to fit into the hole and pop that sideways. Good luck.
Dec 28, 2012 | Bosch 1617EVS 2 Router
Taking spindle nut off 01 escort
You mean the big axle nut? You need a stout 1/2 inch breaker bar and the proper sized deep well socket on the nut. Loosen the nut while the car is still on the ground, you may even need a cheater bar on the breaker bar-the axle nuts are torqued down mighty tight-about 200 foot pounds. Once you break it loose, then raise the car on jackstands, remove the nut and washer, and push the axle back from the spindle. If the axle shaft is stubborn and won't move yet, put a piece of wood on the end of the shaft and rap it pretty hard with a mallet or hammer.to break it free from its tight fit inside the spindle or knuckle.
Nov 09, 2012 | 2001 Ford Escort ZX2
How to change a router bit
How and when:
With the power off & unplugged, loosen the collet and pull the bit out. if is is stuck, tap it gently with a piece of wood.
When installing the new bit, insert it fully into the collet and then withdraw it a couple mm. This will allow you to tap it loose later.
Leaving a bit in the router until next time is asking for a fused bit.
Jul 07, 2012 | Tools & Hardware - Others
When i use my router the blade works up and goes thru the wood iam workig on i tighened the the chuck as tight as i can and it still works loose.
Hi, can you put the bit hard in so it can't work up and set the table deeper to suit? If not, drop a spacer of some sort in behind the bit. Hope this helps, regards Phil.
Jul 24, 2011 | Craftsman Tools & Hardware - Others
Will not start, has no compression,bought new june-2010
If little or no compression problem may be stuck valve/s. Easy fix/ harder fix. Remove sparkplug and spray wd40 into cylinder and replace plug (hand tight because you may need to repeat), try to start. The oil will tend to raise the compression a bit if lucky enough to start, too much will wet plug, just clean and try again. If it starts you can keep spraying wd40 into carb till it runs better. Harder fix, remove plug wire, remove valve cover and pull starter rope slowly to see if valves are moving and rocker arms are not too loose. Loose rocker arms indicate stuck valves. If stuck, lightly tap top of valve/spring with wood handle of hammer or large screwdiver to free valve. Generally only a couple of taps are needed. If these procedures do not help a trip to small engine shop is indicated. Good luck
Sep 03, 2010 | Briggs & Stratton Power Products 5,550...
What is the router bit depth for a shop fox dovetail jig
Usually with router dovetail jigs one has to find the depth by trial and error as the fitting is very critical and any discrepancy doubles as the cut is on both sides of the joint.
I think you may have to play this game.
You will need offcuts of the same size as the finished work that are long enough to go into the clamps of the device and then just fit the joint by trial and error. It is the way we do it in the trade. Sharpening of the cutter and different thicknesses of wood all affect the fit of the joint.
If my memory serves me raising the cutter up toward the machine makes the joint looser and lowering it makes it tighter. If I was in my workshop with the machine in my hand I would remember for sure
May 31, 2010 | Tools & Hardware - Others
I have this Grizzly G1035 1 1/2 HP Shaper, and it seems like it doesn't have any torque. I have used it only a few times, and it is running in 110V mode now, but when trying to make a piece using a raised...
Check the wire size to the machine...if you are running on 110v and a 1-1/2 hp motor you should have at least 10 ga wire running to it...if not when you try to make it work and it pulls more current the small wire chokes down the voltage and you loose power..
heatman101
May 06, 2010 | HP Grizzly G1035 1 1/2 Hp Shaper
Should a moutaneering shell jacket should they fit loose or tight, I am size large and sometime extralarge thank you
It should fit snug, NOT tight and not loose! A good way to tell is try it on and raise both hands above your head, if you can see your wrist then too tight!
Oct 01, 2009 | Mammut Makalu Jacket - Men's
Ive got a kenzo router and the router bits do not fit . ive got quarter inche cutters and when the collet is done up tight the cuters are still not tight. its not a half inch router as ive measured it. any...
Your router bits must have a 6mm shaft, whereas your router with the collet closes down on a 1/4" or 6.4mm shaft. You will need to get a metric collet for your router spindle, or get a new set of 1/4" bits
Sep 28, 2009 | Freud FT2000E 3 Router
Omnijib 24" - Dovetails too tight on half blind dovetails
I haven't used one for years, but I seem to remember we used to have to dial in the thickness of the planed material just right to get the joints to fit correctly. Doesn't make a lot of sense, particularly if you're using composite boards. And make sure everything is clamped in the jig nice and square, and flush where it's supposed to be.
Also make sure you are running the guide collar right up against the fingers when you cut, maybe take a second pass through. Make sure the bit you're using hasn't been resharpened....Take pains to be sure the bit is centered in the collar.
If you've done all that, I'm afraid you just have to play with it until you get it to work...use some test pieces and you'll see that the depth setting does affect the fit, but they're not as versatile as an infinitely adjustable jig like a leigh. I'm afraid I'd have to put my hands on it to remember and see what wasn't working...
I hope that may help in some way or another...
Here's a link or two that might help as well:
  • http://www.newwoodworker.com/dovetails.html
  • http://woodworking.about.com/od/dovetailjigs/gr/PorterCable4212.htm
  • http://www.woodmagazine.com/woodworking-tips/techniques/joinery/9-steps-to-great-looking-half-blind-dovetails/
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 10, 2009 | Tools & Hardware - Others
Milwaukee 5615 21 Factory Reconditioned 1 3/4 Max Hp Bodygrip Router W/ Case Logo
197 people viewed this question
Top Milwaukee Tools & Hardware - Others Experts
Joseph Mueller
Joseph Mueller
Lawrence Oravetz
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a Milwaukee Tool and Hardware - Other Expert? Answer questions, earn points and help others
