Question about Car Audio & Video
Diagram for [ioneer car equalizer
I have a piomeer eq-3000, and I need a wiring diagram so I can install it.
  • 77 Answers
Greetings. with most stereo manufacture's you can get all the information you need from thier website, in this case check out http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo
hopefully you'll be able to find it here.
Ryan
Posted on Feb 18, 2009
The low frequencies adjustment is not working when i turn the sub frequency on low it lowers the volume of the bass completely
check the rca cables on the back to see if you might have the sub woofer cable in wrong rca spot
this is how it should be wired from your radio front output a set of rca cables go to the radio input of the eq. if you have sub out on radio it will not be used ... eq takes place of it ... turn off subout on radio ... to use eq or preamp you must have at 2 amps 1 for mids and tweets and 1 for subs to work eq right
then from the eq you have another set of rca cables comming from the front output to your mids and tweet amp and then if you dont have a second amp u wont need rear output move over to the suboutput and run a set of rca cables from eq's sub output to sub amp this is how the audio cable section should be connected if you still dont get it to work proper then then it has a electronic issue and need to warranted out if still in warranty or buy new one .... here is a link to the install manual with a wire diagram for repair shop .....http://www.poweracoustik.com/pa2006/manual%20and%20catalog/Processors/PWM-20.pdf
Dec 27, 2010 | Power Acoustik PWM-20 4-Band Car Equalizer
Need wire diagram for pioneer eq-6500
Pioneer EQ-6500 9-Band Car Equalizer .i want to buy this equaliser.i need 10 pieces ,please send me through my email febiano22@yahoo.com
Nov 24, 2010 | Pioneer EQ-6500 9-Band Car Equalizer
Wire diagram for hifonics triton eq
well their are 3 outputs if they have been rewired. Don't worry it will say acc+,ground,remote.just look it at edge of your equalizer.
Jan 05, 2010 | Hifonics HFEQ Car Equalizer
Need wireing diagram for pioneer deq 7600 4pin plug
I need to see a diagram how or how to setup my equalizer and reverb to my amp all pioneers old stuff sg60 and sg540
Jun 28, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
I need to find out the weiring diagrame to install it
Equalizers Like a crossover, the equalizer gets installed between your receiver and your amplifier. The outputs will be preamp connections to your amplifier. You'll find EQs that are designed to be installed in the dash, above or below your receiver. Others are designed to be mounted in a remote location, like the trunk. Either way, the wiring connections required will be the same. To install:
1. Mounting the equalizer:
A remote-mount EQ can be securely mounted with just a few screws. Anywhere between the receiver and the amp is fine. Most people mount the EQ in the trunk near their amp, especially if you have more than one amp. This also makes it easier to add additional amps later. You should mount it where it will be easy to get to so that you can make adjustments without too much trouble. Don't mount your EQ directly on steel — you will invite noise problems. Instead, install it on a non-conductive board and attach the board to the car body (or use rubber grommets under the screws to isolate the crossover).
An in-dash EQ can be mounted above or below your in-dash receiver, assuming that you have space available in the dash. This will require custom installation work. Another option is installation below your dash, in a universal under-dash mounting kit. To install the under-dash mounting kit, attach it to the mounting surface using the supplied self-tapping screws. In most cases, the use of an under-dash kit will require modifications to the kit or to the mounting surface.
3a-xover.jpg Locate the remote turn-on lead behind your radio (usually a blue wire). 3b-xover.jpg Connect the turn-on lead from your amplifier wiring kit to the blue wire. You can wrap the bare wire ends together and cover with electrical tape, or use solder. 2. Making the power connections:Your EQ will require 12-volt power, ground, and turn-on signal connections.
  • To obtain 12-volt power: Cut a length of small-gauge cable (16 gauge is typically sufficient) long enough to reach from the EQ location to your vehicle's fuse panel. Strip one end of the wire, and attach it to the EQ's power input. This may require a crimp-on connector, or bare wire might be sufficient, depending on the equipment you're installing. Route the wire from the EQ location to your car's fuse panel. Using a fuse tap, connect the wire to a source of switched 12V power.
  • To ground the EQ: Remove a bolt near the EQ mounting location. Crimp a ring terminal to one end of a length of small-gauge wire, and then bolt the terminal tightly to the vehicle's metal chassis. Scrape away any paint and clean the bolt location thoroughly. If you can't find a convenient ground screw or bolt, drill a hole for one — be careful not to drill into the gas tank or a gas or brake line.
  • Making the turn-on connection: In most cases, you can tap into your in-dash receiver's amp turn-on lead to get a turn-on signal for your EQ. Remove the receiver from the dash to access the turn-on wire (usually a blue wire). For step-by-step instructions on removing your vehicle's radio, see your vehicle-specific Crutchfield MasterSheet™, or read our In-Dash Receiver Installation Guide. Strip the insulation off a small section of this wire coming from the radio. Strip the insulation off another small-gauge cable that's long enough to reach from the in-dash receiver to the EQ, then connect the two with crimp caps or solder. Wrap the solder or crimp connection with electrical tape to guard against a short. Using wire ties to secure the wire, route the turn-on lead behind your dash all the way to the EQ mounting location.
3. Making the signal connections:
In most cases, you'll be routing RCA cables from your in-dash receiver's preamp outputs to the inputs of your EQ. While your receiver is out of the dash to access the turn on lead, connect a set of RCA patch cables (long enough to reach your crossover in its mounting location) to these outputs, taping them together so they won't come apart. Route the patch cables (again using wire ties) behind the dash, and to the crossover mounting location.
May 14, 2009 | Alpine Car Audio & Video
How do I wire an car stereo to an equalizer
from what you have explain you have a no experience to do so get your system installed by an audio installer safety come first and u have no clue for your safety seek a qualified person to do it
Mar 13, 2009 | Car Audio & Video
Need wire diagram for clarion 500EQA equalizer
Your installation manual is not anywhere to be found since the product you are inquiring about was made 1985-87... however, by deduction, you can figure it out yourself...
You need a Power 12V Constant.
A 12V Switched
A Ground
And Signal Cables.
Reply with the wire colors available to you, and I will tell you what is what.
Yellow is usually constant 12V.
Red is Ususally switched 12V.
Black Is Ground.
RCAs are self explanitory.
If your EQ has HI Level outputs, the color scheme is a little more complicated.
Jan 03, 2009 | Clarion EQS560 5-Band Car Equalizer
Gemini Sound Products EQ-3000 equalizer
please connect as the following-----1-mp3 out-----to cd in in your receiver.
2-receiver rec out (tape put)----to equalizer in.
3-equalizer out----to tape in in receiver.
Sep 17, 2008 | Gemini Sound Products EQ-300 Home...
HOOKING UP???
im looking of wiring diagram of proline equalizer model GP-870XII
pls can i have a favor to send at my yh act serra_ricky@yahoo.com
tnx!~ and more power!
Sep 15, 2007 | AudioControl EQL 13-Band Car Equalizer
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
