Wlan button problems
Am having a problem with my wlan button
    Problem Solver:
  • 4 Answers
Hdgdghjmfxdhjmn
Posted on Jan 02, 2009
The wlan and internet buttons are flashing
They will flash when working properly. It sending and recieving info to and from other equipment.
Dec 17, 2012 | Linksys Wireless-G WRT54G Router
WLAN and Mute button lights are not on
Usually the wlan button is off because you're WLAN is not on, you need to locate this button and press it to enable your WLAN. The button is usually located on either the upper left or upper right corner of your keyboard. You will know if you hit the correct button because you'll get a pop up on the lower left corner of your screen saying that WLAN is on.
You can click on Start > All Programs > Accessories > Run > on the Run Window type in services.msc > press enter > then scroll and look for WLAN Configuration > it has a start or stop option, make sure that the button start is grayed out or press on start to enable wlan
you sould be getting a message again telling you that wlan is enable or already on
Hope this help you a bit. Have a great day
May 18, 2011 | HP Pavilion dv7-1245dx Notebook
Hi i have a u135 and it hasbuilt in blue tooth but i donot know how to activate could u help
Not sure if this will work for your model but its worth a try. Copied from MSI support faq website
You have to press the WLAN button located right next to the power button in order to enable/disable the Bluetooth function. Press WLAN button once, Enable WLAN. Press WLAN button twice, Enable Bluetooth. Press WLAN button thrice, Enable both WLAN and Bluetooth. Press WLAN button four times, Disable both WLAN and Bluetooth.
Aug 26, 2010 | MSI U100-422CA Notebook
Wlan not connecting
Its possible that your wlan switch is set to the off position try to find a wlan switch and slide or press the button to turn wlan on.
BTW Sony has the wlan switch on the right side, Acer usually has the switch on the front HP has a button on near the keyboard Compaq also has a button near the key board
Sep 17, 2009 | Sony VAIO VGN-FZ250E/B Notebook
I have a compaq presario c700 that has the WLAN disabled and it wont turn on i need help getting it on to find my routor it was working 2days ago now its not any help i have compaq c795tu laptop and my...
in very laptop there is a switch button that determines if your wlan is on or off. Try finding it and switch it to On. I hope this will help you,, if it doesnt work let me know.
May 30, 2009 | Compaq Presario 700 470024-192 Notebook
WLAN Problem
Remove battery and disconnect power.
Hold down the power key for a minute.
Reconnect battery and power and start the computer. Try using the wireless button again. It should work now.
Mar 14, 2009 | HP Pavilion dv4-1140go Laptop
My PSP Wlan Button And Memory Card
you have to get fix send back to sony , my sun have thath same probleme yvon !!!
Dec 31, 2008 | Sony PlayStation Portable (PSP) Console
FS e7110 wlan problem, got drivers but cant install
i have the same laptop then i had no problems with installing the wlan drivers tho, go to device manager select networkdevice or what that thing was called again and select update driver the click on no, then click next and click the one who's farrest down taht says select form list or folder or something like that then select the folder you wlan drivers at, then you shuold be ready to go
Oct 26, 2008 | Fujitsu LifeBook E7110 Notebook
Wlan disabled
If you have vista click the start button and in the start search type "hp wireless assistant". It should show up in your list while you type it. Click on it. Once the assistant box shows up, click on "properties". A "settings" box should show up. The main one you need here is "independant controls for installed wireless device". Check that box. The other ones are icons and indicators that you can check at your discretion. If in doubt, check them all. Hit the "apply" button. Then in the upper right hand side of the box hit the button that says "turn on". This should activate the device and if you have a light up indicator on your computer, it should change color or light up. That should do it. Kind of weird how it gets to that point.
Feb 26, 2008 | HP Compaq Presario V2000 Notebook
Acer router forgot password
The reset button might have to be held in for 10 seconds or more and should reset to default, but the password if you have not changed it; could be 'admin'.
Jan 12, 2007 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Computers & Internet Logo
David Payne
David Payne
