Question about Maytag EPIC MFW9700S Front Load Washer
I own a Maytag Model A710 top loader.
It stopped during the spin cycle w/ a little out of balance movement and now I have NO power to the washer. I have tried different settings w/ no luck and also plugged in a lamp and had power. Checked the fuse outside and it was good.
Is there a reset button, or and ideas?
Thank you
David in Temecula.
duby1990
  • 370 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
dh1200s
  • 335 Answers
SOURCE: Neptune FAV6800aww Will not go into spin
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium and heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Posted on Dec 15, 2008
appldoctom
  • 311 Answers
SOURCE: Installing damper pads on a Maytag a710 washer
by damper pads you mean three curved felt pads that come in one package.if yes yes i can tell you but it wont be the funnest thing you ever did .on a service call i would complete this job in about one hour,but you have more time than i. had to move on to the next call and did not want to return[to let glue dry enough and then reassemiable]here goes older maytag two belts under neath! 1 remove front panel and screws from top, so can hinge back. 2 there are three or four big springs that go from tub to floor.next,you need to mark the spot that the nuts are tightened too on those eye bolts that springs are attached too. take black tape and wrap around treads above the nut on the eye bolts so will know where to re tighten too. 3 loosen and undo hose at tub that goes to pump and at top of washer tub where water comes in .4 then under neath the washer remove those nuts that you applied black tape to the eye bolts i thinks 7/16 or 3/8[will have to spin belts off also]now tub should move freely.5 here's the trick,i use a 4'' round pvc coupler on its end and place under neath the washer,center trainee pulley and pull the washer up onto it , this then lifts the whole tub assemblie up so now can get to snubber pads.6 peal off old pads and clean ,glue in new pads and let set for long time[hours],[i did not have that time on service calls so when droped tub back down,some time pads moved]7 when dry add your silicone grease that came with pads.8 put unit back together.now if tub to loose you can tighten those nuts on the eye bolts more,but don't too much because tub dose need to move so the energy when tub out of balance can be transferred to springs and not all the way thru to the bottom deck,which would happen if springs to tight.i hope this helps God bless ,tom.....ps the glue l used for pads was the same glue i use for dryer felt seals.that glue came with the felt seals so i always had it around[free] im not sure which glue to advise you to use,but needs to be good stuff,tom.........also if i have been helpfil please remember to help me with my ratings
Posted on Jan 06, 2009
SOURCE: Out of balance
Installed no slip carpeting underneath machine, worked fine.
Posted on Feb 16, 2009
milten1
  • 1304 Answers
SOURCE: I have a Maytag Performa top loader that won't stay in balance
make sure you locking the legs,
put it in spot tilt it forward so the rear legs are off the ground about 3'' the drop it,, this should lock your back legs and take care that
Posted on Oct 06, 2009
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
NOISY DURING SPIN CYCLE
If this sound starts slow and gets faster till its helicopter sounding you probly have a verry worn spot on the drive belt when that spot goes around the pully it will thump the faster ti spins the more frequent the sound If you tilt the washer back you should be able to see the belt to examine it if this the problem
replace the belt
Hope this helps
please leave feedback
Nov 27, 2009 | Maytag Legacy Series Top Load Washer
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
Rocks and bounces during spin cycles
You don't state what type and model of washer you have but following is the Whirlpool service manual for top load direct drive washers.
Check the sections on the base and suspension springs and pads.
If one or more of these is not connected, or the pads are damaged, the washer will vibrate during the spin mode.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 22, 2009 | Washing Machines
Maytag top loader stopped during spin and now won't start.
ok check the lid switch,,did it knock it out of place,,unplug and take back off ,,,
Jan 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
179 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
