Question about OKI MICROLINE 395 Matrix Printer
Printing problems I am having problems with my printer OKI Microline 395. It will print the first two lines then stop. The red alarm is flashing. What does that mean and how can I get it to print........Thank you so much Pamela Morris
  • 1 more comment
  • Anonymous Dec 20, 2007
    The alarm stays on
  • StanAnderton Nov 06, 2008
    Where is the home sensor switch located, and how do you clean it?
  • jean808 Mar 05, 2009
    I am having the same problem. Can you help?
    Jean
    Novelist:
    Champion:
  • 254 Answers
Someone else may have an exact diagnosis on this, but here is one possibility: The printhead home sensor may be defective. This sensor, either an optical device or mechanical switch senses when the head is in the home or leftmost position. This information is used to determine start point of print. A mechanical switch will be more prone to problems, but often fixed by cleaning it. Again, someone else may have actually seen and diagnosed this problem, and could give the definitive answer.
Posted on May 10, 2007
Printer prints one line, then alarm light comes on and stops printing.
Sir the printer is giving line because the cartiage or toner is not of good quality so it does not melt properly and produces line while the alarm comes and stop printing is due to the problem in charging cathode or gutter
Jun 03, 2013 | OKI MICROLINE 321 Turbo Matrix Printer
Hit select button to print one line alarm light comes on
what is the light show..........is it for ink or triangle light for warning
Dec 09, 2009 | OKI MICROLINE ML-395 Matrix Printer
I have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Nov 09, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Oki Microline 590
Try to perform an offline test print using your printer alone
To do this, power off your printer first
Press and hold the LF/FF button on the printer panel then power on. The printer will perform its own printing ( lines of pattern )
If it does it without problems ( no MENU lights came on ) the printer should be OK. If not try replacing the printer main control board.
Hope this helps
KM Hoo
It
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
Alarm light flashing
Is the front cover on the printer(ifs its not the alarm light will keep flashing as there is a sensor that will trigger the alarm if the cover is not on or not on properly.Hope this helps?
Dezzi
Jul 16, 2008 | OKI MICROLINE ML-395 Matrix Printer
Oki microline 320 turbo printer
Did you check your print queue? May be there is an error in there waiting for you to instruct it.
May 22, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Alarm red light flashing when I switch on the printer
HI ,
Is the front cover on ? becuase this printer cannot work with the cover off ?If the cover is on remove the ribbon and power the printer on if it works the ribbon could be the problem.
Dezzi
May 13, 2008 | OKI MICROLINE ML-395 Matrix Printer
Problem with oki microline 395
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer4.gif.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print4.gif.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints4.gif, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Feb 15, 2008 | OKI MICROLINE ML-395 Matrix Printer
Printer not printing the top of the characters
Yes quite possible pin broke on head, check ribbon is fitted correctly and has plastic sheild on front of it intact
Jan 18, 2008 | OKI MICROLINE ML-395 Matrix Printer
Problem with OKI ML 395
the lid has 2 small points the holds down 2 censors that indicate when it is off, make sure that there are not broken and that the censors are being engaged.
Oct 31, 2007 | OKI MICROLINE ML-395 Matrix Printer
OKI MICROLINE 395 Matrix Printer Logo
505 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
