Question about HP Compaq Presario V2000 Notebook
Note book fails to boot/power up
My situation is, having disassembled and then reassembled my HP V2325AP notebook, after two weeks of no noticable issues(i.e. everything worked as normal), it now refuses to boot up. It just starts(I can hear the hard drive begin to turn) for about 3 or 4 seconds before stopping- not even enough time for the screen to start.
I carelessly neglected to keep track of where each screw went when dismantling my notebook. There were three different types of screw I think- about 13 in all... Perhaps you would be able to point me in the direction of a "blue print" that tells you the correct place for the different size screws ? Additionally, the "charging battery" light lights up as normal when charging so I assume it is charging as normal...
Any advice would be appreciated- and happy New Year
    Novelist:
  • 176 Answers
Unplug all your devices from the motherboard - Hard drives, optical drives, memory, PCI cards, video card. Basically get it to where just your power supply is hooked to your motherboard. Again, make sure you have your main power connector and cpu connector seated correctly. If it stays on when its just the power supply, cpu, and motherboard, then you know it is one of your devices that is causing the problem. Just put each device back in one at a time and boot up until you notice the problem.
Posted on Jan 02, 2009
    President:
  • 2,692 Answers
Stihl pole saw will not spin when pole is extended. Shaft will not stay out.
You must disassemble the shaft assembly.
**NOTE: take a photo of each step of disassembly so that you will have a record of how to reassemble and where all the pieces go.
I have worked with them for over 20 years, it is hard to remember, and there is no book!
More than likely you have an inner shaft driver or bearing that has failed, the shaft my be excessively worn. It is hard to say without seeing what is inside.
Dec 01, 2016 | Stihl Garden
I was recieving warnings upon booting to contact hp about a replacement battery. ignoring this my notebook stopped working. The power led's on the side of the note book indicate it is getting power,...
Did you try using another power cord to see if it starts? Could be a weak power cord or intermittent failing power cord.
Could also be a short in the system preventing power to flow through the laptop
Aug 27, 2011 | Computers & Internet
I need to reset power on password for an hp530 laptop
You should take a little risk, to reset password , because this password is the back door password behind the BIOS chip.
Click on the bellow link
http://repair4laptop.org/laptop_and_notebook_bios_password_reset.html
You need to to disassemble the note book ,click on the link
http://www.insidemylaptop.com/disassemble-ho-530-notebook-pc-remove-top-cover/
Hope it will help you.
Jan 07, 2011 | HP 530 Notebook PC
Hpa pavillion dv4-1220us has very high fan nosie and overheating problem
Make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Sep 29, 2010 | HP NB199UA Pavilion Notebook
Laptop is producing too much heat than usual
Sep 23, 2010 | HP Compaq 6735s Notebook
I DO HAVE NOTEBOOK NX7010 COMPAQ RESTART
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 19, 2010 | HP Compaq nx7010 Notebook
Operating system is .............
power on the computer, immediatly tap f8 until you get to the boot menu. Choose "last known good configuration". If this fails, your master boot record is corrupt.Boot into safemode, copy all of your data to an external hard drive, then reload your operating system from the secondary partition on your hard drive or insert your OS restore disk and follow the directions.
Mar 20, 2009 | HP Pavilion dv6000z Notebook
Power/battery problem
hi, try removing the batt press and hold the power down for 1 minute, dont replace battery yet, plug in charger, boot up then shut down. replace battery and boot.
if this fails you could also try changing your power settings in control panel. change to minimal power managment.
remove the adapter while laptop is on and allow to completly drain(untill it switches off)
then try reboot.
Dec 19, 2008 | HP 530 Notebook PC
Hp notebook failure
call hp invent no and ask them to bench the comp and if u r in warret then they will do it for free
Jul 06, 2008 | HP Computers & Internet
No power - no boot
for this two resasons is there one is your power and other one is your ram in your note book can do change the both the thing for testing purpose . or check it the power adapter to other note book. after that you get it.
Jun 11, 2008 | HP Pavilion dv1000 Notebook
HP Compaq Presario V2000 Notebook Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
