Question about Canon MP610 Photo All-In-One Printer
I have a Canon MP610. Is it possible to somehow Fax with it?
  • 66 Answers
The fax component is not in the printer so you cannot fax with it.
Posted on Jan 02, 2009
Need service manual for Canon PIXMA MP610
Hello friend, you can find the canon mp610 service manual in below link:
Canon mp610 service manual:
http://goo.gl/yB52u6
thanks
Oct 12, 2011 | Canon PIXMA MP610 InkJet Printer
My Canon Pixma MP610 won't power up. I've
You've eliminated all other options, so obviously your printer is defective.
Call canon if it is under warranty, otherwise you will have to replace it.
Apr 08, 2010 | Canon PIXMA MP610 InkJet Printer
My Canon Pixma MP610 printer will not print. It
Possible causes: Empty cartridges or new cartridges with cover strip still on the contacts, plugged printhead, wipe with warm water on paper towel to see if all colors are there, also physicallyclean the black cartridge. Try to print. If not working, use the printhead clean and or prime in the printer's maintenance tab.
Mar 09, 2010 | Office Equipment & Supplies
My canon laser jet fax L380 will not receive faxes. The line has been tested and is OK, but just rings out when called. The machine is set to "fax only" so should receive faxes without any problem.
There are only 3 possibilities that I am aware of that can cause your issue. 1) Is the fax only setting you mentioned which is correct and it should answer. 2) The machine has somehow been set in distinctive ring mode. This causes the machine to ignore a normal incoming ring tone and wait for a special tone. If you have your manual you can look up this setting there. 3) The modem has gone bad in your machine. These can rarely go bad on their own or can be damaged by power surges or lightning damage(just in case you have experienced either of those)
Oct 21, 2009 | Canon FAX-L380 Plain Paper Laser Fax
Cannot scan to mp610, but can print (both using bluetooth)
Regrettably, scanning over bluetooth is not possible. Both theoretically and practically. Scanning requires huge amount of data packets to transmitted that is not possible over bluetooth.
Sep 04, 2009 | Canon MP610 Photo All-In-One Printer
Paper Abrasion
first open the printer option by cliking start -->settings-->printer and fax,right click on canon pixma printer cancel all printings, then off the pring again on it.
Aug 13, 2009 | Canon PIXMA MP610 InkJet Printer
Need to find printer part
From http://www.canon-europe.com/Support/Consumer_Products/services_locator/index.aspx
Electroversal
Photo Printers, Inkjet Fax, Scanner, InkJet Printer, Laser Printer, InkJet MFP
Electroversal provides a return to base service for A4 Bubble Jet Printers, PIXMA iP90/iP90V, Selphy, CP, DS & PIXMA Mini Printers, the Fax B820 & B840, JX200/500, PIXMA MP110, MP130, MP140, MP150, MP160, MP170, MP180, MP210, MP220, MP450, MP460, MP470, MP510, MP520, MX300 & MX310, the LBP2900, LBP3000 and Scanners (except the dedicated 35mm Slide Film Scanners 2700F, FS2710& the FS4000US – Canon UK RCC).
Unit 2
Sedgwick Road
Luton
LU4 9DT
Tel: 01582 582023
Fax: 01582 582 087
Web: www.electroversal.com
To obtain a repair quote for products serviced by Electroversal, please call Electroversal Customer Service department on 01582 582023 or email sales@electroversal.com
CRC (Tasktron Ltd)
Photo Printers, Inkjet Fax, Calculator, Scanner, InkJet Printer, Laser Printer, InkJet MFP
CRC Tasktron Ltd provides a return to base service for Calculators, A4 Bubble Jet Printers, PIXMA iP90/iP90V, Selphy, CP, DS & PIXMA Mini Printers, the Fax B820 & B840, JX200/500, PIXMA MP110, MP130, MP140, MP150, MP160, MP170, MP180, MP210, MP220, MP450, MP460, MP470, MP510, MP520, MX300 & MX310 the LBP2900, LBP3000 and Scanners (except the dedicated 35mm Slide Film Scanners 2700F, FS2710& the FS4000US – Canon UK RCC)..
Unit 3 Wintonlea
Monument Way West
Woking
Surrey
GU21 5EN
Tel: 01483 776 060
Fax: 01483 721 389
Web: http://www.crc-tasktron.co.uk
Cura Technical
Personal Copiers, Laser Fax, Inkjet Fax, InkJet Printer, Laser Printer, InkJet MFP, Laser MFP
CURA Technical provides on-site service for A3 and PIXMA iP90/iP90V, laser Beam Printers, PC/FC Copiers, Multifunctional Printers and Fax machines. On-site service can be arranged by dialing 0844 369 0100.
Please note that Cura Technical do not service the following products: Selphy, CP, DS & PIXMA Mini Printers, Fax B820, B840, JX200/500, PIXMA MP110, MP130, MP140, MP150, MP160, MP170, MP180, MP210, MP220, MP450, MP460, MP470, MP510, MP520, MX300 & MX310 and the LBP2900 & LBP3000. These units are repaired at our Return to Base Agents, Electroversal or CRC Tasktron Ltd.
Cura Technical
Uniter House
3 Radford Way
Billericay
Essex
CM12 0DX
Tel: 0870 400 2080
Web: http://www.curatechnical.co.uk
Dec 17, 2008 | Canon PIXMA MP610 InkJet Printer
Canon MP610 Scans blurry images and photos
I had the same problem with one of these units. I had another one that worked great so I knew it should work. I called Canon and after some questions about the problem they sent me a replacement unit which works fine.
Dec 07, 2008 | Canon MP610 Photo All-In-One Printer
Printer driver for Canon MP610 to work with Windows 98 please?
there are no drivers available Windows 98 or Windows Me,this operating system may not require a driver or in this case of older operating systems may no longer be supported. try upgrading your windows,THERE ARE DRIVERS FOR WINDOWS 2000, XP,VISTA. SORRY FOR THE BAD NEWS
Sep 27, 2008 | Canon MP610 Photo All-In-One Printer
Canon MP610 Photo All-In-One Printer Logo
old marine
old marine
