Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
BLUTOOTH DATA CAN PAIR DEVICES BUT CANT FIND THE DATA ON MY PHONE
  • 1 more comment
  • trae776 Jan 13, 2009
    HOW CAN YOU TRANSFER FILES ONTO MEMORY CARD
  • BASSEY EKA Jan 14, 2009
    Can't find files in my device transferred via bluetooth?
    Also, can't sync files with my laptop. Keeps saying - rndismpx.sys - missing. How do I get this file/drv? I use XP Pro OS.
  • Anonymous Mar 30, 2014
    I BOUGHT A NOISE HUSH N500 AND IT DOES NOT WANNA PAIR UP WITH MY PHONE WHAT CAN I DO TO FIX IT OR DO I HAVE TO BUY ANOTHER ONE
    OR OS IT FIXABLE
  • 3 Answers
Main menu - shortcuts - file explorer. They will be there but not assigned to a program so the omnia doesnt know what to do with it. I havent worked out hoe to assign a program to these files yet but will keep you posted
Posted on Jan 04, 2009
  • ikell Jan 13, 2009
    If you go to USB connection mode (settings - USB connection mode and select "Mass storage" your pc will see it as a usb storage device. You can then select my storage from your pc and store stuff on your phone there.
I can't get my Braven 570 bluetooth speakers to connect to anything using bluetooth
Hi,these devices like bluetooth hand set or speakers must be paired in the master device,for example turn the speaker on make sure its blutooth is visible too all and find it with your phone device if your phone can see it try to go to option and make a new pair device,if your phone cant see it you may have problem with the speaker,try to read manual,if you still have problem,something goes wrong with device,and if it works successfully you can pair it in the laptops or PCs
kind regards
Apr 16, 2013 | Computers & Internet
Paired backberry 8520 with parrot ck3100 but contacts will not syn with parrot. tried to transfer contacts to parrot but message just says refer to handsfree maunal .have looked into this with no luck...
Hello chicks,
Pairing both devices from the Parrot Product:
Select Setting / Advanced Settings / Pair with phone / Other phones
* From the phone:
* Select MENU / OPTIONS / BLUTOOTH / ADD DEVICE / SEARCH
* The phone will search for available devices
* Select the Parrot Product name from the list, and enter the PIN code '1234'
* The phone will pair with the Parrot Product and auto connect
Sending contacts via Bluetooth For all contacts sending
* From the phone:
* Select MENU / MANAGE CONNECTIONS / BLUETOOTH OPTIONS
* Select the Parrot Product from the list of paired devices and go to OPTIONS / TRANSFER CONTACTS
May 07, 2011 | RIM BlackBerry Curve 8520 Smartphone
How do i download photos from a mobile phone to a laptop
Find on the intenet a PC SUITE software compatible for your mobile phone unit...Install this to your computer..
Pc suite is a software that your mobile phone will be using to communicate with your computer. With this you can transfer files from your computer to your phone and vice-versa..There are two ways to connect your pc and your phone..First, is via usb data cable, data cable usually comes with your phone when you purchase it.. If there is none, purchase one that is compatible with phone and install the driver that comes with it. Second, is via blutooth. blutooth is a usb device capable of wireless transfer of signals, you also will need to purchase it with its driver...Some laptops have built in blutooth, if you have one it will be easy for you to access your phone through your computer..
Run your PC SUITE software and pair the phone with your computer. When pairing is successful you can now transfer your files from your phone to your laptop
thanks.. much appreciated if you rate this help..
May 29, 2010 | Computers & Internet
How to ACESS INERNET TO LAPTOP THROUGHT MOBILE
First of all you will need to have settings save to your phone sent to you by your phone provider. If your phone can access the web, then that means your phone already have the settings for surfing the net.
Secondly, you will need pc suit software or any other mobile suit software compatible for your phone. Install the software to your pc..
Third, you must specify the mode of connection that you want for your phone and pc.. If you will be connecting your phone to your pc via blutooth... then you will need blutooth device installed and connected to your cpu.... If you will be connecting via usb data cable.. then you will need driver installed for your data cable.
Fourth, on control menu.. double click Phone and Modem.. Install your phone as your modem.
Lastly, If all is done.. run your pc suit... pair your phone to your computer.. Access dial up via phone modem... and there you go.. just make sure your phone is loaded so the connection wont stop..
Good luck.
Much appreciated if you rate this help. thanks.
May 21, 2010 | Computers & Internet
I HAVE A HI TECH 700 PHONE. PHONE MEMORY IS 761k. WHEN EVER I WANT TO RECEIVE THROUGH BLUTOOTH IT IS SAYING DISK FULL. HOW TO STORE IN MEMORY CARD INSTEAD OF PHONE MEMORY?
Go to DEVICES under your blutooth settings, delete some devices. To store in Mem, set your blutooth memory to Memory Card
Nov 18, 2009 | Cell Phones
Garmin 760 Blutooth pairing
I also have the 760 & the first gen Boulder (before the front speaker was added). I had the same issue with the M07 firmware (the latest you can get over the air), but took it into a Verizon store & updated it to M09. I am now able to pair the two devices.
Jan 04, 2009 | Garmin Nuvi 660 GPS Receiver
BlackBerry won't pair with device anymore via Bluetooth
1. Go to Options/Bluetooth
2. Select device found
3. Select device properties
4. At Trusted select yes
It'll never ask again
Dec 30, 2008 | RIM BlackBerry Curve 8310 Smartphone
Problem pairing
just after turn on both's blutooth. turn on blutooth search of headset also by pressing vol key for 3 sec.. then the blue light will turn on for few sec .. make search on mobile for blutooth device and u will pair it...
Nov 07, 2006 | Motorola Mobility HS801 Consumer Headset
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
91 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
