Question about EnGenius SN 920 Ultra Cordless Phone
ID Conflict base 1
I have (had) 4 Engenius 920 working side by side for several months now. One day a few weeks ago 2 of the phones stopped working. When I try and re register with the base unit, I get the "ID Conflict Base 1" error message. I am following the registering process per the manual and still nothing. Any ideas? Is there a chance that the base units are broken? thanks in advance Matt
  • Matt Mulder May 11, 2007
    1. Right soft key into ?Menu?
    2. Select option #6 ?Register?
    3. In Reg Menu, select Option #4 ?Reset Handst?
    4. Wait until handset is reset then follow directions for registering handset with base station.
  • honey castanares Feb 29, 2008
    i can't register to the network pls provide me the code sir
3 Suggested Answers
SOURCE: ID Conflict with Base 1 error
hold the volume and intercom buttons together the in use light will come on and then go to menu on handset press 6 then 1 to regester that should work i just talked to a friend with a telecom buisness and he told me what to do with mine good luck
Posted on Jan 31, 2007
SOURCE: cordless phone EnGenius SN 920
. A new handset arrives with a handset ID number of 00, to register this handset to your system take the following steps:
  1. On the EnGenius base unit press and hold down both the "Volume" & "Intercom" buttons for about five seconds. You will hear a beep from the base unit. You can now release the two buttons.
  2. On the EnGenius handset (00), press the following buttons: "menu", "6", "1".
  3. A new handset ID number (ie: 12, 13, 14…) is automatically assigned by the base and registration is complete.
Posted on Apr 04, 2009
Caller id stopped working
Dial *31# followed by the phone no and send and see if it would show the id, if it shows i will tell you the next step
Apr 26, 2016 | Panasonic NEW Expandable Digital Phone...
Can not get the second handset to register to the base
This is the registration procedure
Step 1: press MENU-6 and select 3 “SET BASE”
Step 2: press the REG key on the master base
Step3: press register to finish the registration procedure.
• After the registration complete, handset 11 and handset 21 can
2-WAY intercom with each other
If issue persists reset the unit start registration by using 2nd unit that currently unable to register. if issue continues please inform for further troubleshooting
Good Luck
Jan 01, 2008 | EnGenius SN 920 Ultra Cordless Phone
I have a phone it recieves calls but can't make them it was working until 2 days ago
Several things can go wrong. Do they need to dial an extension to access an outside line? Make sure they know this. Also, make certain to remove any area code in the menu settings. The phone could be trying to make a call, yet it dial the area code each time and screws up the PBX, so no outside line. There are more possibilities, but they require on site tests.
Jun 09, 2014 | EnGenius DURAFON1X DuraFon 1X System Phone
Register handset to base unit on sn-920
press menu 6 on handset then press base station reg key for 2 sec till L1 L2 L3 L4 LIGHTS FLASH
handset should now show registration no between 10 and 99
Sep 30, 2008 | EnGenius Lands Phones
EnGenius SN-920 Ultra
Might just be a stuck key or switch. Take a dry cloth and gently rub and press down on the keys like you are wiping it off. Then, if there are any switches on the phone, click them back and forth a few times. Then, take a spray can of air or a small air compressor (100PSI or less), and blow around the edges of the keys/switches. Good luck.
Jan 18, 2018 | EnGenius SN 920 Ultra Cordless Phone
No connection
deregister headsets and then run register again
Jun 09, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
Cordless phone EnGenius SN 920
Feb 29, 2008 | EnGenius SN 920 Ultra Cordless Phone
EnGenius DuaFon 1X
Registration:
a. Press MENU-6 to enter the registration mode
b. Press and hold the base’s Registration (REG)
button for 2 seconds until 4 LEDs light up. (Located on the base where you plug in the phone jack)
c. Press handset key “1”, this completes the
registration process. When you register the
handset to BASE 10, the base will assign a
handset ID between 11 and 19. The assigned ID
will be displayed on the handset LCD, indicating
successful registration.
d. Repeat above steps for all additional handsets.
e. The first two handsets registered will be given ID
11 and 12, which gives them administrator
privileges.
Jan 04, 2008 | EnGenius DURAFON1X DuraFon 1X System Phone
Jan 08, 2007 | EnGenius SN 920 Ultra Cordless Phone
EnGenius SN 920 Ultra Cordless Phone Logo
43 people viewed this question
Top EnGenius Lands Phones Experts
Damen Wong
Damen Wong
Eric Sutherland
John L radiodude365
Are you an EnGenius Lands Phone Expert? Answer questions, earn points and help others
