Question about Honeywell Programmable Thermostat Heater
Pilot light won't ignite, gas company came out, got gas
House fan works, thermostat will run the fan, the blower in the unit won't turn on, pilot light won't work. Rheem. 2.5years old.circuit breaker is on.
  • popatop6598 Mar 11, 2009
    I have a Rheem that is over 5 yrs old ,when pilot light(glow plug) was working,the heater would turn on and quickly shut off at times. Now the glow plug wont work at all,but blowers seem to be working.
  • dwkcool May 11, 2010
    does the exaust blower start if it does check the presure switch ,that is the round peice with the rubber hose going to it with the two wire
    Sergeant:
    Champion:
  • 239 Answers
The glow plug or thermocopler is bad
Posted on Jan 03, 2009
No flame
Several steps here to check...
turn power off unit and back on
set thermostat to heat
watch for pilot to ignite..igniter should glow orange or cherry red or spark if its a spark type ignitor
Did you see a pilot light ignite?
If not you probably have a bad igniter.
If pilot lit....in a little bit you hear a click of the gas valve opening..then the main burners will ignite
If you see the pilot and the main burner lights but goes out in a few minutes or immediately you may have an issue of the "high limit" switch tripping.
Is the blower fan turning that blows air out of your vents?
are all your vents open in your house? too many times i see homes with almost all vents shut.
Jan 08, 2011 | Goodman GMS90703BXA Heater
Fan turns on, pilot on left side turns on red light at bottom stays solid during entire time then pilot goes out and blower stops no heat please help
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remaing solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Oct 05, 2010 | Goodman GMS90703BXA Heater
Burners not burning, pilot light is off. How do I start the pilot light?
There is no pilot on this unit. It is electronic ignition.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
Mar 29, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Goodman unit. when i turn it on the blower fan and the exhaust fan comes on butit does not lite no flames at all. i don't even hear the gas click in.
Feb 15, 2010 | Intertherm P3RA-048K Air Conditioner
Fan comes one, should hear whooshing of ignition,
Jan 27, 2010 | Goodman Heating & Cooling
Goodman model gms8 will not light fan comes on then turns off
Jan 26, 2010 | Goodman GMS80453ANA Open Flame Mid-Size...
HEATER IS NOT HEATING. WE REPLACE THE THERMOSTAT AND THE PILOT IS ON FAN WORK. ITS JUST NOT HEATING!
Not much to go on without a make and model number but:
Jan 16, 2010 | Heating & Cooling
My Home propane tank was empty, I just had it filled, but when I go to turn on the heat, a flame icon comes up. I noticed on the heater it has an on/off switch for the automatic pilot light. I am not sure...
Make sure all switches are on and open. It may take a few attempts to get gas to the burners so you may have to reset the furnace by either the Emergency switch or circuit breaker. If it takes longer than 3 tries, you may have a gas regulator problem and will need to call your gas company for repair. The regulator belongs to the gas company so they shouldn't charge you to repair or replace.
Jan 04, 2010 | Coleman Propane Forced Air Heater...
Carrier furnace, pilot does not light, fans run for a couple minutes and then flashes code 31
Nov 28, 2009 | Carrier 38CKC042 Air Conditioner
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Heating & Cooling Logo
246 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
