Question about HP Photosmart C5180 All-In-One InkJet Printer
Unable to see the ink level
Before i was able to see the cartridges grtting empty
    Sergeant:
  • 237 Answers
Onscreen Help
The onscreen Help provides detailed instructions on features of your HP All-in-One
that are not described in this Basics Guide, including features that are only available
using the software you installed with your HP All-in-One.
For more information, see Access the onscreen Help.
Posted on Jan 04, 2009
  • zabrina liang Jan 04, 2009
    To access the ink level gauge, follow these steps.
    1. Press
      Setup
    2. Press
      to select Tools
      , then press
      OK
    3. Select
      Display Ink Gauge
      and press
      OK
      . The ink levels are displayed.
      Figure 1: Ink levels
      • Each
        icon corresponds to the cartridge that is the color of the icon. The
        icons are also in the same order, from left to right, as the cartridges
        in the printer.
      • If an icon is empty, the corresponding cartridge may need to be replaced soon.
      • The
        ink levels in non-HP, refilled, and remanufactured cartridges cannot be
        read by the printer. Instead of an icon, a question mark is displayed
        for these cartridges. HP cannot guarantee the quality or reliability of
        non-HP ink. Printer
        service or repairs required as a result of printer failure or damage
        attributable to the use of non-HP ink will not be covered under
        warranty.
Reset ink level after top off of ink? canon MG3500 series
You cannot refill ink cartridges anymore. There is a computer chip in the ink cartridge and when it goes empty, it stays empty forever. The printer companies were losing money when you refilled the ink yourself, so they installed a computer chip to stop customers from doing it.
Nov 08, 2015 | Canon Office Equipment & Supplies
I changed ink cartriges and it won't let me print it says ink is empty. How do you reset the ink levels?
There is no reset for ink levels. When you open the cover do the cartridge lights flash indicating the cartridge is empty. This problem can arise from using compatable cartridges. Try a set of genuine cartridges and the problem will probably be solved.
May 04, 2011 | Canon PIXMA MX350 Wireless All-in-One...
I am unable to print on my HP Officejet Pro 8500. i have recently replaced the 940 black cartridge and since then have been unable to print. i notice there are print cartridges in the main body as well...
you can check the ink level from following steps Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
If the ink level is low and the cartridge is new please contact the dealer from whom you got the cartridge and if it shows that the ink level is good enough please comment so that i can give you another step to perform
Dec 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Full refill ink cartridge,but full level is empty
There is no way to reset the ink levels on this type of cartridge. As long as your printer still prints the cartridge is functioning properly. You should be able to check a box that says "ignore ink levels" when your computer pops up the box saying your cartridges are empty. Print until the ink runs out.
Jan 29, 2010 | HP DeskJet F380 All-In-One Printer
My refilled ink cartridge still displays empty and will not print
The ink cartridge is most likely chipped & you would not be able to reset the ink level. Purchase an original or a good compatible cartridge. Refiling newer cartridges is not a good idea.
Oct 21, 2009 | HP Photosmart C4180 All-In-One InkJet...
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Replaced ink cartridge and it still says low ink
There is no way to reset the ink levels on this type of cartridge. Therefore, your printer will always think refills are empty. You can choose on the dialogue box to "ignore ink levels" and run the cartridge until it is empty. This is just one thing you will need to deal with on refills of this cartridge type.
Oct 18, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
False error empty cartridge
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jun 01, 2009 | HP Photosmart C6280 Printer
Printer level gauge shows cartridges aas empty even when they are
hi,
many times the ink gauge is not true, if u wanna see the actual level of ink, try to print the self test page..........
regards,  raj_p5983
Jan 21, 2009 | HP Photosmart C5280 Printer
I have a new HP Deskjet F4280 bought 3 weeks ago & the blank ink cartridge was empty & I refilled it in a store & placed it back but printer recognise that the cartridge is empty & it does not have a chip.
You cannot reset the ink level for the HP 60 ink cartridge. Simply ignore the ink level indicator if you refill your cartridges. It is only an estimate of the ink level anyway. See pg 72 of the user manual.
Jan 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP Photosmart C5180 All-In-One InkJet Printer Logo
82 people viewed this question
Ben Johnson
