Question about Electronics - Others
I need a wiring diagram for a Intermatic T104 40-amp timer
I need to know how to wire the timer to make outside lights work.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Habit-Forming:
  • 112 Answers
Http://www.intermatic.com/images/instruction_sheets/T104.pdf
http://www.intermatic.com/Default.asp?action=cat&cid=91
if the 1st link doesn't work, use the 2nd and look for ur timer model there for the diagram.
if u need more help than this just ask
Tip: i usually use a photo cell in combination with the timer. i set the time for winter hours and let the photo cell take care of the rest.
Posted on Jan 11, 2009
Intermatic/GE 15071 digital wall timer - Connection Problem
1) GE 15071 (Tork SS20) is single-pole timer, and cannot be wired as 3-way timer
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
2) Check wire nuts are tight
Remove light bulb and spray WD40 into socket. Reinstall light bulb
3) Reset timer using paper clip or tooth pick, then reprogram to see if functionality is restored
4) Move timer to different location and see if it controls different light
5) Buy another 15071 from home depot.
Remove bad timer, take photo of wires, and install new timer same wire-for-wire.
Return bad timer to home depot in new package.
This is GE's extended warranty plan, but do not mention warranty at return desk.
5) Intermatic and GE are fierce rivals in the timer business.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Intermatic makes their own products. GE timers are generally made by Tork. Both companies sell timers worldwide.
Feb 09, 2013 | Hardware & Accessories
I need installation or wiring diagram for Timer Intermatic T101
Copy following link for 120Volt T101 timer wiring options:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Nov 29, 2011 | Home
Can you send a scematic showing how to wire an intermatic pool pump timer to a polaris intermatic timer so that when the pool pump shuts off so will the polaris pump yet the polaris timer clock continues...
No. I don't have a wiring schematic without knowing what voltage you are using, specifically what Intermatic timer you have, specifically what wires you have coming from breaker box, what wires are on the pump, and what pump rating plate says, what the wiring diagram shows on side of pump, whether you are wiring a 2-speed pump to a single-speed timer, specifically what is the polaris timer clock, and why this pump needs two timers if that's what you mean.
Add a comment with specific information so electrician is not guessing.
http://www.poolcenter.com/polaris-booster-install-OM.pdf
Open following link for 240Volt T104 timer wiring diagram.
Aug 25, 2011 | Intermatic T104 24h 208-277v Mechanical...
I have disconnected the internal wires from my Automatic Sprinkler Timer model R8806P 101C . and don't know where they are supposed to go. Is there a diagram of that? Specifically, where does the...
Thank you for including model number of product.
R8806P101C is 240Volt timer with 4 wiring terminals.
You removed factory wiring and want to reattach.
The on-off-auto switch does not have separate wiring diagram.
Intermatic offers tech support phone: 815-675-7000
Add a comment and say what you discover.
Open following links for resources:
http://www.intermatic.com/customer%20service.aspx
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8806p101c%20-%20english.ashx
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Aug 19, 2011 | Intermatic R8806P101C -...
Need wiring diagram for T104M 208-277v Mech. Time Time Switch
Here is the basic instructions:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Below is a larger and better diagram of a 240V connection Terminal connections are White to White on 3 & 4 Black to Black on 1 & 2:
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
More info: http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
I am assuming you have the 240 VAC clock motor so the clock timer motor wires are connected to terminals 1 and 3.
If you only have the 120 VAC clock motor the wires will be connected across terminals 1 and 2.
Thanks for choosing FixYa,
Kelly
Jun 27, 2011 | Intermatic T104 24h 208-277v Mechanical...
I replaced a Intermatic light timer with a GE 15086 timer. I have read several solution, but none fit my wire sceme. This is hooked up as a 3-way switch so the second switch can turn outside lights on...
1) GE 15086 is not a 3-way timer.
GE programmable timers are for single-pole switch replacement only. I have tested this timer, and own several GE timers, and many other brands.
2) Open following link to identify timers that work for 3-way switching.
3) After buying correct timer, then you need to review wiring diagrams carefully because the timer replaces 1 of the 3-way switches, but other 3-way switch has to be wired exactly right to match your brand of timer.
4) Links on page above show manuals for each of the 3-way timers. Compare wiring for each timer with Intermatic wiring that you are replacing, because Intermatic is wired differently than Aube.
5) Or just buy another Intermatic ST01C or EJ500 or EI400, etc, and wiring with change out 1 for 1.
6) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Vacuums
I just bought an older electronic Intermatic timer at a yard sale. Model ET7215C. Timer power can be 120/240/277. There are 5 terminals for this, numbered 1-5. Looks like a variable tap power transformer....
I think you have the ET70215C SPDT
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
If this is not your timer, then add a comment.
Manual for ET70215C (same manual is for other models too)
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et70215c%20-%20english.ashx
Just as you figured, timer has selectable voltage.
Page 28 shows wiring diagrams and jumper settings:
Timer comes with a jumper, and then you select with voltage by installing jumper
Sample wiring diagram below shows 120Volts:
ET70125 appears to have 8 terminals.
Some models have 5 terminals.
There are many ways to wire this timer. Off hand I can think of 10 different ways.
Add a comment if you need help with a specific project.
In any case, the clock terminals are 1 and 2.
To put voltage to the timer switches in the simplest wiring options, is to put a jumper wire from terminal 2 to 3
If you are using 240-277 voltage with two hot wires, you still need to jumper from clock terminals to switch terminals. For example one jumper wire from terminal 2 to terminal 3 & then second jumper wire from terminal 1 to terminal 6
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 08, 2011 | Intermatic Hardware & Accessories
Looking for wiring sequency
1) Intermatic has manuals for each product. Manuals have wiring diagram, but you have to identify product number. Look for product number and wiring diagram inside timer door.
2) If you know product number, and are still confused by wiring, then repost question providing as much information as possible. You also need to post what voltage wire you are putting timer on.
3) Here is link to manual page:
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
4) Here is link to product page: for example sprinkler timer: Click on product number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Sep 18, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Clock doesn't work
The wiring diagram for that timer is somewhat misleading. The 120 volt clock timer motor is connected internally to the "A" (neutral) terminal and the #3 terminal. The "A" (neutral) terminal is to the immediate left of the #1 terminal.
Here's how to do the wiring for your use, (assuming a 120 volt supply circuit and a 120 volt lighting or other load):
Connect the incoming power (line) black wire to terminal # 3. Connect the incoming (neutral) white wire to terminal "A".
Connect the outgoing (load) black wire to terminal # 4.
Connect the outgoing (neutral) white wire to terminal "A".
Mar 08, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
Electronics - Others Logo
185 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
