Toshiba MES60VK Gigabeat 60 GB Portable Media Player (Black): Runs fine, but when I hook it up to my computer the screen says "Connected" and then go into "Initializing" that's it. Can't open up any music files from CPU or download new ones.
  • obnoman Jan 02, 2009
    Toshiba MES60VK Gigabeat 60 GB Portable Media Player (Black): Runs fine, but when I hook it up to my computer the screen says "Connected" and then it goes into "Initializing" and that's it. Can't open up any music files from CPU or download new ones. Tried different USB cables, they work fine.
    The Gigabeat won't get out of the "Initializing" phase, my computer does not recognize that I have it attached by USB and when I disconnect it, the mp3 player remains frozen in the "Initializing" screen. So I reboot it with its reset switch. The USB cables are fine, the computer works, it's not a battery issue . . . it just suddenly happened.
  • 495 Answers
Just try plug in the device to another computer and check if the problem still persists. You can also try installing the driver again to your computer. I think system is not able to recognize your player and thats why it is showing "Initializing". Once thing you can try is just restart your computer once.
Posted on Jan 02, 2009
    President:
  • 2,110 Answers
The Toshiba Gigabeat digital audio player can play music files in any of these three file formats: MP3, WAV and WMA (.mp3, .wav, .wma).Music files can be transferred to the Gigabeat from a computer, using the Toshiba Audio Application software that ships on a CD included with the Gigabeat.
Follow this procedure to prepare the Gigabeat and the computer for transferring music files:
1. Charge the Gigabeat's battery, using the supplied AC adapter, until the orange power light on the face of the Gigabeat turns green.
2. Before connecting the Gigabeat to the computer, install the Toshiba Audio Application on the computer that will be the source of music files for the Gigabeat.
3. Launch the Toshiba Audio Application.
4. Connect the Gigabeat to the computer's USB port.
Once the Gigabeat is connected, a blue icon will show up in the left pane of the applications window, showing which drive letter has been assigned to the Gigabeat. The Gigabeat's display will indicate that a connection has been established. Follow these steps to transfer music files to the Gigabeat
1. With the Gigabeat connected, and the Audio Application running, you can create new folders for your music files on the Gigabeat by selecting File, Menu, then New Folder.
2. Select the music files to transfer from the computer, and than click Copy from the Edit menu.
3. Select the Gigabeat folder to which you'd like to transfer the files, and than click Paste from the Edit menu.
It's also possible to drag and drop selected files from a CD to the Gigabeat folder.
Windows Media Player (version 9 or newer) can also be used to transfer music files to the GigaBeat.
    President:
  • 1,990 Answers
Try going to the Manufacturers Website and Locating a Driver for Download. Then Sync it with WMP and you should be Fine.
  • 51 Answers
It's possible that the drive letter that the PC is trying to assign to the MP3 player is already taken. Hook up your MP3 player, then right-click on My Computer and go to Manage. Click on Disk Management, then see if you see your MP3 player on the list to the right. If you see it there, right-click on it and select Change Drive Letter. Change the drive letter to a letter that is not in use. Let me know if this helps.
    Genius:
  • 1,011 Answers
Sir,
Check the drivers u must be properly installed and updated one. Check with the device manager.
According to ur problem......
The program is stuck "initializing", "connecting" or "scanning" This error occurs when the attempt to contact the connection server fails. The reason is usually that something on your machine or on your local network is blocking the SimplifyPeer process from running.
Click this link for more info.
thanks
good luck
  • 238 Answers
  • First thing to do is copy all files inside your Toshiba MES60VK Gigabeat 60 GB Portable Media Player drive. Transfer it in your My documents folder in your computer.
  • Right click your Portable Media Player drive, click format...
  • A box will appear, mark the check box "Quick Format"
  • Click OK.
  • After reformatting, copy all the files you have transferred in your computer and paste in to your Portable Media Player drive.
  • 6,487 Answers
When your player is recognize by your computer, just double click Mycomputer and then after that you should be able to dine the player listed there , just double click it and now you can copy and paste song to it....but if the player is nort showing under Mycomputer try restarting the computer while the player is connected to it....
  • Mark Gil
    Mark Gil Jan 03, 2009
    This can already be a corrupted firmware already of the player, so if its still under warranty you can take it to a service center near you or just have the device replace....
    Genius:
  • 1,269 Answers
You might have a bad USB cable. Try to use a different USB cable. Another thing you can try is plug the device to a different computer so that you can isolate the problem.
  • Michael Galve
    Michael Galve Jan 02, 2009
    Do you have music saved on your mp3 player? You can try to reformat it. Go to My Computer and look for the portable media player drive. Right-click and reformat.
I would like to copy or remove music files from gigabeat to my pc.
plug in the ipod, go to my computer and double click your ipod icon, go ta music, and then copy and paste what you want to " my music"
May 29, 2009 | Toshiba gigabeat MES60VK Digital Media...
Vista recognises Gigabeat F40 as a hard drive and not an Mp3
hi had the same problem with mine, you must use the dock and have the connections setting set to media player it will sync then
Dec 05, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
MES60VK Gigabeat - Dead
There is a switch on the bottom left side of the dock connector of the player. Flick the switch to the right and it should work. The switch is the battery cutoff switch. It is there so it will charge only. I have no idea why Toshiba though this was a good idea, but they put it there.
Nov 08, 2008 | Toshiba gigabeat MES60VK Digital Media...
Help
You require the restoration tool. Try this:
http://www.aibohack.com/giga/repair_gigabeat.zip
And read the instructions carefully.
Oct 18, 2008 | Toshiba gigabeat MES60VK Digital Media...
Help
Download the firmware recovery application from here: Gigabeat S firmware. Follow the instructions and you will be all set.
USB Connection Problem
I have the same problem. If you have a large library try letting it stay hooked up for a long time. It seems like it is taking inventory of device then it should work after a while. Sometimes this works. Sometimes I have to unplug then try again in a few minutes.
Aug 31, 2008 | Toshiba gigabeat MES60VK Digital Media...
Hi, i'm looking for a replacement lcd screen for my toshiba gigabeat x30.
i need a remplacement for the screen of my toshiba gigabeat MES60VK (60 GB) Portable Media Player, because it´s absolutly broken.
Jul 29, 2008 | Toshiba Audio Players & Recorders
Help!!!
So, what happened when you connected the thing to sync with a PC and rightclicked on the tool-tray item for the Gigabeat?  Maybe you got a menu about Upload Portable Media Center?  If not, go into applications and see if the gigabeat stuff doesn't happen to contain the bespoken user manual.  Open it...read it....  Usually there's a little button-sequence to prepare the player and another to restore the Portable Media Center program.  Happy discovering.
Jun 16, 2008 | Toshiba gigabeat MES60VK Digital Media...
My toshiba MES60VK wont turn ON
I am having the same issues, any luck finding a solution?
Apr 15, 2008 | Toshiba gigabeat MES60VK Digital Media...
Toshiba gigabeat MES60VK (60 GB) stopped working
There is a little battery cut of switch at the bottom of the device. You can unbend a paper clip and switch it off. Then switch it back on after a few seconds. Plug it back into the usb cable to charge it. It should work ok now.
Dec 26, 2007 | Toshiba gigabeat MES60VK Digital Media...
51 people viewed this question
 Grubhead
Grubhead
