Question about Casio Exilim EX-S600 Digital Camera
Replaced LDC but won't turn on
I cracked my LCD screen and ordered a new part, replaced it and connected everything the way it originally was but for some reason it won't turn on. I was testing the camera without the LCD before it arrived and put the camera on the charger and all is working okay, I just can't figure out why it won't turn on. Any ideas?
    Genius:
  • 2,985 Answers
Polarity in the connector perhaps or screen intalled up sidedown perhaps. Or even blown the board powering it with the screen.
Posted on May 26, 2007
SOURCE:
Replaced cracked screen and seen LCD has slight crack,but phone worked perfectly before I put new screen on.Black screen now,and nothing shows up.Can anyone help please !
You need to change it again, because some screen and lcd are not function perfectly, maybe the flix of the lcd has a damage or a broken connection, because some supplier are still selling it,even that they know are defected
Sep 13, 2015 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
I phone 5 i cracked the screen inthen replaced with new now all i het is a blank screen can anyone help with a solution plaese
Iphone 5 has a very different screen than the previous ones. In order to replace a broken screen, the entire lcd has to be replaced. You might have not connected all the wires from the new lcd to the motherboard, or you didnt replace all of the parts necessary
Nov 10, 2013 | Apple iPhone 5
No backlight on laptop LCD screen
The only solution I can think of is that your 40pin cable from the motherboard to the screen is damaged. They do fail just through use (opening and closing the laptop lid can put strain on the cable) Try replacing this cable.
Leon
Feb 09, 2013 | Sony VAIO Computers & Internet
I only have a white screen,connect to another moniter still no screen.
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
1-laptop-white-screen.jpg Here's an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning. In my case it was a Toshiba Satellite M45 laptop but this problem may occur with any other brand.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
3-video-cable.jpg I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful.
4-reconnect-video-cable.jpg I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard.
5-disconnect-lcd-screen.jpg The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
6-test-with-another-lcd-screen.jpg For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen.
7-white-lcd.jpg After I assembled everything back together and connected the original LCD, it's still white.
CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced.
For more information:
http://solvetheproblemhere.blogspot.com/2011/05/laptop-lcd-screen-turned-white.html
May 10, 2011 | Samsung N150 Notebook
When i power on the laptop nx 6110 it brings a white screen on the LCD.
May 09, 2011 | Compaq NX6110 TFT XGA Notebook
Hi, my son dropped my LZ2 camera and now it starts when I power it on, all menus and functions seems to be ok, but no image is displayed in the LCD. Any ideas what's going on?
The LDC screen most likely broke the screen did not crack by the actual underlying LCD screen broke the only option is to replace the screen or have it replaced at a local camera shop
Mar 05, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
Acer 6920g had a cracked screen...ordered a new one..doesn't work
racist maybe? hah. just kidding. but you should check to see that the connecting part of the screen (where the screen connects to the "computer") and see if there was anything loose (due to shipping) or if there are any anomolies in the chinese screens as compared to the original korean one.
(also, i was wondering if you could PLEASE tell me how to remove the screen, i know there is the keyboard bezel, but how do i remove it?)
Jun 10, 2009 | Acer Aspire 6920 Notebook PC
Can a cracked notebook screen be replaced?
you don't have to purchase a new laptop/all you have to do is call your computer manufacture and get the LCD replaced.
or else
you can connect a desktop monitor with your laptop if you have a desktop
as its cracked so only thing we can do is either get the LCD replaced or connect a monitor with it to use your system.
Jun 09, 2008 | Dell Latitude D600 Notebook
LCD Screen
Sounds like the new Samsung LCD screen is bad. The back-light on the Samsung LCD may be burned out. Check out this website; http://www.lcdsearch.com/
Mar 30, 2008 | Computers & Internet
Casio Exilim EX-S600 Digital Camera Logo
71 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
