when my maytag heavy duty fills up it does not shut off when water level gets full it just keeps filling til it goes over. when i shut off water supply and then turn it back on it does quit. Any solutions?
The water level switch is causing the prob, it could be sticking for one reason or another, for example it could be a partial blockage in the pressure chamber or the hose from the chamber to the switch.,it works on air pressure,so it must be clear of any restriction.
You need to check this before anything else.
Hope this helps solve your prob.
Plz rate my solutiopn.
thanks.
I have inherited a Hoover Nextra HNF6147 with no operating instructions. Need to know which setting...
(More)
I have inherited a Hoover Nextra HNF6147 with no operating instructions. Need to know which setting in best for my requirements. Thank you, Donna
i have a Hoover washing machine heavy duty 10.1 kg Giant Capacity Plus with same problem, cold water...
(More)
i have a Hoover washing machine heavy duty 10.1 kg Giant Capacity Plus with same problem, cold water doesn flow but warm water yes. Please help
The springs on the drum doors have now both gone. It has been difficult to open for a while. Now I...
(More)
The springs on the drum doors have now both gone. It has been difficult to open for a while. Now I can't close it as if I press the grey knob the door just presses into the drum. I think both springs need to be replaced. How do I replace the springs and what are the part numbers. Thank you, Gill from Scotland.
