Question about Motorola Mobility HS850 Consumer Headset
Can't connecto to headset again...
In the past when I couldn't get connection from my phone (Motorola RAZR) to my headset (HS850) I would simply reboot. I would turn off my phone and headset completely and then when I powered them on again everything was fine. Not this time, though. AND when I press the button on my headset with the boom closed, the blue light does come on after three seconds but when I open the boom to pair the device the blue light goes off. Help please!
    Problem Solver:
  • 13 Answers
You are not alone in this endeavor. A lot of people have this problem. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Posted on Aug 02, 2007
NEED TO PAIR BLUETOOTH HS850 TO RAZOR V3
a With the headset’s boom closed, press and hold the Multifunction Button E until the headset indicator turns on (about 3seconds). The headset indicator turns on.
b Release the button, then open the headset boom. The headset indicator remains on.
2. Perform a device discovery from the phone. 3.select motorola hs850 and click pair 4 When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone. The device ID is now stored in the phone’s memory. Pairing is successful when the headset indicator flashes 10 times rapidly.
Feb 07, 2010 | Motorola Mobility RAZR V3
I have a Motorola Razr 3 cellphone and would like to pair it to a Motorola N136 Headpiece
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:>>>>>>
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
May 17, 2009 | Motorola Mobility HS850 Consumer Headset
How do i connect motorola hs850 with lgcu720 (shine)
1. With the headset’s boom closed,press and hold the Multifunction
Button E until the headset indicator turns on (about 3 seconds).
2. Release the button, then open the headset boom.
3. The headset indicator remains on.
4. Perform a device discovery from the phone.
5. Select the Motorola HS850 from the discovered devices list and confirm following the on screen prompts.
6. When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone.
rapidly.
Hope this helps
- Ted G.
Jun 25, 2008 | Motorola Mobility HS850 Consumer Headset
Pairing motorola hs850 headset with nokia 6680
there's some error in your mobile
Feb 25, 2008 | Cell Phones
Motorola HS850 Headset gone silent
I bought a new HS850 and guess what, I got this hearing problem on the very first day ...phew ! I did the pairing with my Motorola A1200 phone and it worked for once, even the sound was coming in the earpiece and then I put it to charge for the first time and once done, I again started it up and it got connected with the phone and after that there was no sound in the ear piece. I was going nuts....about what could be the problem.
So i decided to delete the earlier paired profile from my phone and do the pairing again and guess what...It Worked....:) So you can try that out too....
Dec 06, 2007 | Motorola Mobility HS850 Consumer Headset
HS850 Signal Light Wont stay on to be able to pair w/ V3 razr
When I paired my headset to my Blackberry - I had to do the following... Set my phone into the pairing mode.. quickly press button on HS850 and when blue light comes on, hold button and open boom - It has worked this way several times for me.
Aug 14, 2007 | Motorola Mobility HS850 Consumer Headset
Pairing Motorola RAZR with the HS850
No, living outside of your cellular "home area" has nothing to do with the bluetooth pairing. You're problem is a common problem. Lots people have this problem you are not alone. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Aug 02, 2007 | Motorola Mobility HS850 Consumer Headset
Answering Calls with Motorola HS850 on Sony Erricson T630
i think rapid connect should work with moto phone only, isn't it?
Jan 28, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
71 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
