Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
I have a Jenn Aire SVE47100 that keeps beeping
I set it on a clean cycle and had to stop it in the middle of the cycle. At first I couldn't get the door to open from the "lock" mode and the fan would not stop running. I turned off the breaker and left it off for about 24 hrs. It appeared to reset but then the next day I came home and it had started beeping again but the display appeared normal.
  • renate9 Jan 04, 2009
    My stove beeps intermittently. When the oven is one the beep will turn it off. Then I have to turn it on again and the next time it beeps, the stove is turned off again. My appliance repairman brother can't figure it out. Can you?
  • renate9 Jan 08, 2009
    My stove beeps even if the oven is not on. If it is on, the beep turns it off. However, I have discovered that if you turn off the power, turn it back on, and don't set the clock, it won't beep. That's weird.
My stove did the same thing. I turned on the downdraft fan and it quit. I think it overheats the board when you are baking. try it and see if this helps.
Posted on Jan 08, 2009
After cleaning oven door won't unlock . it is a jenn aire oven
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 09, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Aire locked tight!
that relay/solenoid can get stuck quite easily..
you have a service contract on this?
Mar 28, 2008 | Jenn-Air SVE47100 Slide-In Electric...
My Jenn-Air SVE47100 slide in electric range does
Obviously it does not work fine. The thermostat sensor or the stat itself could be an issue. Can you see the sensor 'bulb'? Clean it with oven degreaser and steelwool. What is the temp in the oven with a 'oven thermometer'? Is this consistent with the oven readout?
Sep 24, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Older jenn-air stove
on the front panel does it have a button that says CLOCK if so press that then with + button see if setting changes if so when it gets to the correct time stop and press clock again .
Oct 25, 2017 | Jenn-Air SVE47100 Slide-In Electric...
No digital display oven works
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 21, 2008 | Jenn-Air JJW8527C Expressions Collection...
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Try turning the oven tempurature all the way to the right (past clean). That is what unlocks mine.
Jan 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air probe won't shut off
mine did the same thing kept beeping and flashing prb, solution was it was mounted very close to the frame of wall and house must of shifted causing the wires on the outside to make contact with each other. adjusted the unit and beeping stopped .
Dec 23, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air stove locked
Check the trouble shooting section of your owner's manual for your various fault codes. It may point you in the right direction as to your next course of action.
Oct 04, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
214 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
