Question about Sony TRV-285 Digital-8 Digital Camcorder
Images can't show on the screen
I have a problem with my digitalhandycam drc-trv245e, it only shows blank screen when i am recording though only records the voices, it on write on screen to be on standby but when i play the previous recorded visual tapes everything is alright, i just can't record anything, i can't be able to see on screen want am trying to record.
  • shawn kas Sep 06, 2007
    thanx for the information, actually i had checked but i can see i don't think the iris is opening, so i wonder if their is a solution for this problem. and if what you talked of about the sesor, can it be taken even if the camera is about 2 to 3 years old? just wondering if they can do it for free. thanks again and looking forward if you can of any help again.
  • 169 Answers
First check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....go to a sony service center for replacing that...i know it is free for replacing that sensor cause that is the recall product not only on sony but in other brand because the manufacturer of their sensor is only one company...
Posted on Sep 02, 2007
  • christian tope Sep 07, 2007
    ah i think the iris is stock up..it is a possible that the ccd image sensor is ok...you need to clean the iris using a lighter fluid cause of some oil in the iris that why is sticky and cannot open..if you are a not technician don't attempt to fix it... better go to a respected service center...
I have a JVC video camera modelGR-D290U. I can play and view tapes previously recorded.But when loading a new blank tape the screen does not show what is being recorded and remains blank when rewinding and...
Sounds as though the imager may have failed but make sure you are in video postion instead of memory mode. Little switch behind the lcd screen. Larry's Electronics
Apr 25, 2010 | JVC GR-D290 Mini DV Digital Camcorder
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
Can't watch show while recording
It doesn't do. No can do.Whatever channel you SWITCH ON TO AFTER you started recording be it timer or manual GETS recorded. Whether you switch onto inputs on your TV remote or cable remote IS the one getting recorded.
Jun 15, 2017 | Sony Televison & Video
I have a Sony Handycam DCR-HC27E Camcorder which was working great until a few days ago. my problem is its suddenly not showing my recorded tapes, I was watching footage only a few days ago from my recent...
The gray strips usually mean the camera has dirt video heads - if it hasn't been dropped. Get a head-cleaning tape from Radio Shack or Best Buy, and run it a few times. If that doesn't do it, it'll have to be cleaned by a repair shop. Off brand tapes sometimes can cause this.
Jul 06, 2008 | Cameras
Screen is Blank..Nothing shows up
Hey mneeth,
I would first try formatting the memory card, but remember when you do this it will erase all the images on your memory card so upload your images to your computer first. If this doesn't work I would try resetting the camera to its factory settings which can be done from the setup menu. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 01, 2008 | Nikon COOLPIX L10 Digital Camera
Blank screen
did you press the disp. button?
May 08, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Camcorder Dropped
Sounds like your display screen is broken, but a least it can still record, which is most important; just don't use the zoom feature and point the camera at the action.
Oct 21, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Sony TRV-285 Digital-8 Digital Camcorder Logo
77 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
