Question about Disney DVD2100-P DVD Player/VCR
Have a disney electronics DVD2100-P dvd/vcr combo. Won't turn on
It is properly plugged in to a working outlet.
snakehead
  • 1074 Answers
SOURCE: Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
Posted on Jun 04, 2007
SOURCE: Dvd Recorder+VCR Combo Model#DRC8320N
-----Original Message-----
From: RCA Support [mailto:rcasupport@1800customersupport.com]
Sent: Monday, May 12, 2008 2:52 PM
Subject: RE: DVD stopped playing
Let the unit sit with the AC power cord out of the wall for a couple of hours. Then hit the power button 10-15 times (with the AC power cord still out of the wall socket!) and then try again. If you continue to have problems unfortunately it sounds as though it is within the electrical assembly. It is hard to say exactly what caused it or exactly what the problem with the circuits are.
Posted on May 14, 2008
SOURCE: Lightning Mcqueen TV/DVD COMBO
I have the same problem it wont play any DVD and if it does they stop playing shortly after !!!!!
Posted on Aug 26, 2008
SOURCE: DVD VCR combo has no power
I found out what the issue was with my Samsung DVD-V5500. It was the rectifier diode on the 15V tap of the high frequency transformer. This is the same issue that someone else with a later model V5600 had talked about. The diode had shorted and behaved like a piece of wire.
Seems to be a bit of weak point in the power supply. The issue can be diagnosed by using a multimeter to measure the resistance between the diode cathode and ground. If the meter is measuring 1 Ohm between the cathode and ground, your diode needs replacing. I just replaced it with a UF4003 diode from Jaycar, which is basically an Ultra Fast 200V 1A diode suitable for switching the high frequency (20-30kHz) output from the transformer.
The diode is located at the rear right hand corner of the board on the output of the power supply section. A picture below shows the new diode between orientated east-west between the large capacitors. The original diode that failed was an SHG2D SHS.
Posted on Oct 04, 2008
SOURCE: Need code for Emerson TV,DVD,VCR Combo
called comcast
Posted on May 28, 2009
Will not read dvds
Hello
If the set reads CD and MP3, and not reads DVD discs only, replace its laser pickup unit. It is faulty.
Mar 02, 2012 | Disney DVD2100-P DVD Player/VCR
It won't power on
I have the EXACT same problem. Did You ever get an answer? Thanks. zannamu@aol.com
Feb 14, 2010 | Disney DVD2100-P DVD Player/VCR
Our dvd2100-pa will not close. how do i fix it?
I would try to push it manually but very gently so not to force it. I used to have this problem and I pushed it in with my hands and it worked. I hope it works for you.
Jun 30, 2009 | Disney DVD2100-P DVD Player/VCR
Incorrect disk error
Here are a few things you can try.
1. Check the DVD's and make sure that it is not scratched.
2. Check to make sure it accepts that brand of dvd disc.
3. Call technician. Number shoud be on the DVD player or on your manual. How long did you have this player? If you have warranty on it, I would return it if # 1 & 2 is not the problem. It could be a mechanism problem.
Good Luck!
Jan 09, 2009 | Disney DVD2100-P DVD Player/VCR
Emerson dvd/vcr combo little leaps code
I went to the Little Leaps website and went into customer support and viewed a link that provided additional codes. I have the Emerson dvd player with video cassette recorder EWD2203 and the code 027 which was listed in the additional codes at Little Leaps website worked for me.
Here is that list of additional codes from the Little Leaps website:
018,030,035,005,150,151,043,058,011,147,148,016,004,002,144,007,009,146,013,020,027,133,042,129, and 149.
These codes were listed to try with any players.
Good Luck.
Nov 17, 2008 | Disney DTD1363-CAR 13" TV/DVD
Sylvania 6720FDE combo tv/dvd/video
The codes for a combo set are found in the DVD settings or the VCR settings. Try the rca codes for DVD or Vcr and it should work. Although you may find that not all the functions will work properly ( ie: fast forward, open door, etc ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Disney DVD2100-P DVD Player/VCR Logo
78 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
