Question about Fisher and Paykel GWL11 Top Load Washer
Our clothes washer has a bad screeching sound & loud spin cycle
Also goes out of balance easily. Thanks, meatguy@pleasantprairiemeats.com
  • Sold to Him<3 Jan 05, 2009
    Replaced pump. Didn't fix problem. Motor and other parts were bad. Shop said it would be $500+ repair. Bought a used Fisher Paykel. Thanks for trying. Need a pump?
    President:
  • Fisher and P... Master
  • 2,651 Answers
Screeching sound generally form a bad pump, which if didnt pump out correct amoun tof water would probalby send off balance more. unplug unit, ddrain out asmuch wateras possible and tip unit back, you will see the pump in the front right corner, there is a small plastic reles tab, after releasing it the pump simply twists out counter clockwise, perhaps ther is something in the pump/sump. you will see tis when oyou remove the pump, simply reinstalls the same way
Posted on Jan 02, 2009
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
When water drains and machine goes into spin cycle it starts to make a loud clonking noise. It sounds as if the drum is going to fly out of the machine.
I've experienced this on occasion. stop the washer, redistribute the clothes, etc. so it is evenly balanced. The "rocking" occurs when the balance is uneven.
Apr 10, 2011 | Kenmore Washing Machines
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Jun 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Loud Sound
bash11385,
Welcome,
You said, during the Spin Cycle it starts thudding very loud as if someone is pounding on it. What's wrong with it?
You must check tht the wheels are properly installed and lock nuts are tight.
Your washer load is more than likely out of balance or over loaded .
Try moving the clothes around so the weight is balanced .
And remember not to over load the washer with to many articles!
let me know how it goes.
Huuum Please remember to leave a rating.
Below is the Kenmore site for your washer manual if you do not have one!
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0512076.pdf
Oct 09, 2008 | Kenmore Oasis HE 27082 Top Load Washer
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
Problems with Spin Cycle
Sounds like the "out of balance" mech has been destroyed. Check for that first
Jul 23, 2007 | Kenmore 27032
Fisher and Paykel GWL11 Top Load Washer Logo
90 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
