Question about HP Photosmart MZ67 Digital Camera
Battery door on an hp Mz67 does not close completely and properly. lmshumway@yahoo.com I need to replace battery door on my HP MZ67. HP will not sell part and said I must take to a HP dealer. Would be easy to replace if I could get part. Two of the three catches are broken but I am still using it. Can someone get the part?
  • 3 more comments
  • Adriancito Jan 05, 2009
    I have the same problem and agree that looks easy to fix it if the part is available, I'm using a rubber band to close the battery door because I realy like the camera. I can not find the part as well. Need help....
  • ashbro Jan 17, 2009
    I also have the same exact problem and I have to tape the door shut!
  • Anonymous May 01, 2009
    My Photosmart Mz67 battery door is always open, the batteries push it out. I'm bummed. I have had no less then 4 HP related problems. I suppose this camera is already obsolete and its going to be cheaper to buy another camera, or wait... that was my HP printer! At least the camera didn't just stop working completely with no explanation... as did my HP scanner and ALSO my last HP camera. I'm so done. Sorry to complain, fellow battery door problem peeps. I'll try the rubberband... that's more help than the HP people are.
  • Anonymous May 03, 2009
    Yup, battery door. Stop china from dumping their **** on US,lol.
  • marcecilia72 May 10, 2009
    I have the same problem as you, I need to buy or repair that door because it wont close right. Please let me know how you got this part to be replace. Thanks marcecilia72@hotmail.com Cecy
I use a samll part the we normally use to attach the camera to a tripod......it works well and once you screw in the knob it fixes the problem...I couldn´t fin a new door or fix the litlle thing ...but once I use the part that only cost 4 dollars the problem was solved the batteries remain inside and it doesn´t affect the look or the volume of the camera.
Posted on Aug 12, 2010
Sue hp for not selling parts for there stuff
Posted on Apr 14, 2009
R927 BATTERY DOOR.There is no solution HP tries to talk you into buying another piece of garbage and tells you they will give you a minimal credit on the broken camera. I spent 127.00 on mine a year ago. I expected at least 5 years of life from it not 1
Posted on Aug 09, 2009
I lost the manual need new one
You can download one from the manufacturer's web site. Go to http://www.hp.com and search for "MZ67".
Feb 07, 2010 | HP Photosmart MZ67 Digital Camera
Battery door latch broken
Unfortunately HP will not sell you a camera battery door. If you can find another camera that is broken with a good battery door you may have a chance.
To repair/transfer the new battery door, you will have to use a small jewerly store screw driver that you can buy at the dollar store and use it to push the door hinge bar to one side of the camera.
Then, pull the door hinge out but be careful not to lose the tiny spring that is installed in between the hinges. ( Make sure that you know and understand how to put it back the same way.) You can then pull the battery door from the camera.
Do the same thing to good camera. Practice on the broken camera first. The second time it should go easier for you. When you install the new battery door, push the hinge bar in all the way to one side of the camera. Hold the door to give you the proper alignment and then use the small screw driver to pry the hindge bar from the one side to make sure that it is equally in each of the black hinge connectors.
This worked for me. I was fortunate enough to find someone who had a broken HP MZ67 digital camera that had a "good" battery door. It took me about 30 minutes to complete the job. I hope this will help you. You can email me if you need more advice. I am a computer tech.
Steve (SCBENDER@AOL.COM).
Nov 15, 2009 | HP Photosmart MZ67 Digital Camera
Lens Stuck open on Mz67 hp camera Error code Mz60-022
Was this stuck fully open or was the lens partially opened, or was the lens jammed?
The lens can be removed and replaced with another lens from another non-functioning camera (See ebay). The lens component can also be dissembled. Putting the lens back together is tricky because the parts have to be aligned just right for the lens to work. If working with a Jammed lens, extra care has to be considered not to break any of the moving plastic parts of the lens or that part (if not entire lens) is junk.
With the motor detached from the lens, the lens should extend and retract freely. Use this to test the lens when you dissemble the camera. Be careful of the flash board.
Mar 15, 2009 | HP Photosmart MZ67 Digital Camera
Slider switch view to take pcture
I had the same problem I just fixed today, is really easy to do it yourself the hardest thing is to disassembled you just have to take off the four screw at the bottom and there's another one in the battery compartment between Sd card slot and the 2 batteries to hold the silver plate on top is hard to see it, after you took off that little screw you can take off the top silver cover, after you took the silver cover off you'll see one more smaller screw on top of the camera under the silver plate you took off unscrew it and then separate both sides with a blade or some thing alse in mind (do it carefully it got a few small engagements around) after you did that you are ready to align the slider switch with its proper pin, youll see it. This helps to replace the lcd screen too, ones you are there. its easy hopefully it helps you
Aug 08, 2008 | HP Photosmart MZ67 Digital Camera
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 28, 2008 | HP Photosmart MZ67 Digital Camera
No sound on my Mz67 camera
as far as i know those cameras do not have sound but they do have a mic. Try making a video,make some noise and put the video on your comp,from there it should be as clear as a bell.
May 26, 2008 | HP Photosmart MZ67 Digital Camera
Can I use the HP Photosmart Mz67 Digital Camera as a webcam? Thanks! - Robin
I've had mine for 1 day, and my answer so far is nope, at least I have not figured out a way yet.
Feb 01, 2008 | HP Photosmart MZ67 Digital Camera
HP Photosmart MZ67 Digital Camera Logo
635 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
