F/02..
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
4X4
On
these issue, there are few solved help links for troubleshooting the
issue easily.-------
Click
the link below: ---
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction
control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light
flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These
details will help.
Thanks.
4X4
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
On
these issue,there are few solved help links for troubleshooting the
Click
the link below:---
No 4x4 light on dash?
4X4 Truck makes roaring
noise in the front end?
Car will not go into 4WD
high or 4WD low?
4 wheel drive system will not disengage?
4WD light is flashing and
beeping? NO 4WD high?
2002 Jeep Wrangler: 4WD Idiot Light is ON?
Traction
4WD light
2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing?
4x4 front differential will not engage the
axle on ford?
4x4 will not engage on Ford F150?
http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4
light keeps flashing
4X4 LOW LIGHT
IS FLASHING ON DASH
Ford 4x4 front wheels will not engage?
These
details will help.
Thanks.
http://schematicsdiagram.blogspot.com/2011/12/heating-knob-light-bulb-under-dash.html
Parking lights, tail lights and dash lights
not working?
http://technoanswers.blogspot.com/2012/01/parking-lightstail-lights-and-dash.html
How to replace Instrument panel and dashboard?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
Tail lights and dash light fuse keeps blowing?
http://technoanswers.blogspot.in/2012/02/tail-lights-and-dash-light-fuse-keeps.html
This will help.
Thanks.
