Question about Radio Communications
Palomar 150watt bi-linear amplifier for c.b. radio-won't transmit
This RF amp. used to dead-key 3watts & swing to 150watts pep. Now, the unit is turning on,lights are working,pre-amp. is working. But when I key up my c.b., (dead-key set at 1watt) the relay inside of the amp. engages, But won't put out anymore than 1watt. I did find a snapped resistor(470 ohm) & replaced it,but didn't solve problem. Can you steer me in the right direction,to bring this ''SCREAMER'' back to life? Mark Hopkins
  • markhopkinsj Jan 06, 2009
    Dear trapsenault: After I replaced the snapped resistor, I found a crack in soldier leading to "pill". Unit is back to being a "SCREAMER". Thanks markhopkinsjr47@gmail.com
  • 170 Answers
3W to 150? Now you got 1 W in and 1W out and a snapped resistor. I would look at the driver and or final, either something heated up bad and cooked the resistor or you might have a break in the pcb.
Good Luck, Tom
Posted on Jan 02, 2009
How to adjust cb for linear amp installation
That is a broad question. It depend more on your choice of amp. Typical setup cobra 29 with 2 watt dead key or carrier into 150 watt amp. We must pay attention to the total swing a more powerfully radio could still hurt this size amp if the pep wattage was to hi no matter the dead key being low. The cobra is no threat to this size amp as long as dead key is reduced.
May 26, 2014 | Radio Communications
No transmit signal
Does the unit work when it is not hooked up to the linear? The obvious choice is that you have blown finals in the RF output section of the radio.
Apr 02, 2014 | Connex 3300 240-Channels Base CB Radio
How do i know if my palomar 250 is a high drive or low drive amp
If it is made by Palomar and it is a small amplifier, you can bet it is a low drive. Check those transistors. It could have the new Mosfet 655's in which case definitely low drive 3-6 watts input max.
Mar 30, 2014 | Palomar 250 SSB/AM Linear Amplifier for...
How many fet tranistors are in this unit and what is its max amp draw.?
There are 5 transistors in that unit that you are asking about. The amperage draw is about 50 amps
May 23, 2013 | Palomar Redman Cb Stop LD 450-fet LD Low...
Need to know how to hook a palomar 450 HD to a connex 3300hp
If its in a car or truck use heavy gauge wire to power it. I use a 3ft jumper between the radio and amp. Should use a grounded antenna system. Not a "MAG MOUNT" type. Those can "feed back" rf to your radio and cause problems. If using in the house, a large power supply will be needed.I own a palomar elite 400 hd.It uses every bit of my 30amp power supply. Your hd amp should like the hp radio.
Dec 04, 2012 | Palomar Redman Cb Stop Hd 450-fet Hd 10...
Cobra 2000 with a d 104 mic and a palomor tx100 bi linear amp...how can if possible make the amp key up with less than one watt on the ssb side..Radio has a 4 watt dead key on am and i have ajusted the...
Hi, my name is John. Adjust the radio to key 1 watt, then switch to SSB on radio,then switch to SSB on amp, key down and adjust to 1 watt on amp. enjoy !!!!!! ...hope this was very helpful....
Aug 31, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Tunring up a cobra 150 gtl/dx
Um... What?? This is hooked to a switch? CB radio by FCC regulations is only supposed to have a max of 4 watts total output. If you can flip it to 7 watts dead key, you are doing really good. It won't do much more then that. It sounds like its set up to run on a linear amplifier, which cannot have more then 3 watts dead key transmitting into it.
Dead key, and modulation are different. You may have a meter that only reads dead key, and won't see the modulation. This radio is probably swinging close to 15-20 watts. you need a meter that can read PEP, Peak envelope power. Cheap meters only read AVG, or average power, witch will only show your dead key.
7 watts dead key is really good for that radio.especially since stock only has 4 watts. you cannot get any higher then that without changing finals.
at 3 watt dead key, or 7 watt dead key, your modulation wattage is still swinging much higher.
Also, you will get more swing with a lower dead key any way, which is better if you want it to be loud.
Leave it alone. its probably set just right.
May 12, 2009 | Cobra 150 GTL DX Base CB Radio
Low output power
On the meter you are using, does it mesure Average power or peak envelope power?
This is very important to know when you are measuring.
AVG measures basically your dead key. It usually will very little if at all.
PEP measures your peak output, or swing. Modulation.
So even if you have a radio that has been peaked, on a meter that reads AVG, it will still read around 3 to 4 watts. And, if it has a swing kit in it, it will read even less. A swing kit lowers the dead key it increase modulation. Higher PEP.
For example. I peaked my cobra 29 and it does some where around 22 -25 watts PEP. I have variable power in it as well, but usually run the dead key at 2 watts because I have a linear. The Radio alone, when mesureing on PEP with key up at 2 watts, and then when you talk, swings to about 22 -25 watts.
If I flip the meter to AVG, it stays at 2 watts even with talking.
If you have one of those cheap pyramid meters, etc, they usually only read AVG.
Get a meter from radioshack. They have a fairly decent radio for the money. It reads both PEP and AVG and has SWR as well.
If the radio has been peaked and it has a swing mod, it will most likely be swinging to some where in the 20 watt range.
On a side note. According to FCC regulations, a CB radio is only allowed to transmit with 4 watts of final power. Most times the manufacturer will have it a hair under so that they are leagal.
Basically it is illegal to use a CB that puts out more then 4 Watts.
But its a free for all these days. There is no more funding to the FCC for monitoring CB radio, so they do not want anything to do with it. As long as you don't over do it, have over 50000 watts and terrorize a small community with RF, you can do what you want.
Now a days most cb radio's bought have already been peaked if you got it from a cb shop, or off a website that does it.
Apr 21, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Shorted out amplifier-for c.b.
well for one thing 150 watt is 146 watts higher than the fcc will allow!!!! well all i have to say is goodluck!!
Jan 06, 2009 | Radio Communications
Palomar 150watt bi-linear amplifier for c.b. radio-SHORTED
OPEN IT UP THE SHORT MAY BE WERE THE 2 POWER WIRES COME TOGETHER AS THEY ENTER THE RADIO THIS HAPPENS ALOT OR DESOLDER ONE OF THE WIRES OFF THE CIRCUIT BOARD AND CHECK FOR A SHORT ON THE WIRES AGAIN THIS WILL TELL YOU ALOT IF IT IS THE WIRES OR IF IT IS ON THE CIRCUIT BOARD GOOD LUCK
Radio Communications Logo
933 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
