Question about IBM ThinkPad X41 Tablet PC
Click on hp laptop dv6000
The left click of my mouse (laptop hp pavillion dv6000) as of 3 days now. is messed up....
when i drag the mouse and left click in google search to search or to type a web address it wont let me type instead it offers me all editing options, cut undo....or back...if i want to type i have to hold down the mouse and type with one hand then it will allow me to write its ridiculous...hope this is enough info...
    Scholar:
  • 155 Answers
Could be a bad driver or a damaged palmrest.
Try to reinstall the touchpad driver.
Go here and click 'synaptics touchpad'. Go through the process and restart when prompted.
If it still doesn't work, it could be a damaged palmrest. Call HP at 800-474-6836 to see if your warranty covers the replacement. Otherwise, they can further diagnose the issue and refer you to service centers for parts replacement.
Posted on Jan 02, 2009
How i can transfer U tube video in SD card of my tablet? can u guide me
transfer it to say a pc or laptop , that's simple 1st know file name of video (memory )
remove sd card from tablet (just a push and out it pops) now insert it into same slot on Pc or laptop wait for driver to autoinstall (1 min) then access drive in file manager in pc/laptop find drive letter (E: maybe?) left mouse click it twice find file name of video in new window that comes up left click it once right click drag to copy then find spot to add it too in pc/laptop on left side of page , me id suggest (videos) and left click that to open it , then right click anywhere inside that window and drag down to "paste" a window will come up showing the file's flying over when its done safely remove the sd card and re install in tablet , now there's a copy on both the tablet and laptop/pc for you too view anytime , one note for others reading this (yes I know there's a wifi network way of doing this but its more complicated than this method)
Jan 22, 2016 | Tablets & eReaders
Where is volume control on dell laptop
Hi there! this might work :)
1.Click once on the speaker icon in the lower right corner of the laptop screen on the task bar to open the volume control.
2.Click and hold the slider control with the left mouse button or the left button on the touch pad, then drag the control higher to increase the volume on the built-in speakers.
3.Click the "Start" or Microsoft flag button in the lower left corner to access the Dell's Control Panel. Click twice on the Control Panel.
4.Click "Hardware and Sound" then click "Adjust System Volume" under the "Sound" listings.
5.Click and drag the slider control to adjust the sound level, then click the "X" box in the upper right corner to close the application.
Sep 30, 2011 | Dell Tablets & eReaders
How do I download photos from my laptop (Toshiba Satellite) to my ipad?
To transfer photos from your Toshiba laptop to your iPad:
Step 1: Connect your iPad to your Toshiba laptop using the USB data cable that came with your iPad.
Download Install and run iTunes and select your iPad device from left panel under "Devices" section.
Step 2: Click on Photos tab, Check the "Sync Photos from" checkbox and select "Choose Folder..." option from drop-down menu. Locate the folder with the photos you want to transfer on your computer and hit "Select Folder" button.
Step 3: When folder listed in iTunes, select all pictures that you want to copy to your iPad and hit Sync/Apply button from bottom right corner.
Jul 12, 2011 | Apple iPad 32 GB WiFi Tablet PC
5 vertical lines on the right hand side of my hp pavillion zd7000 laptop what does this mean
If youve changed the resolution and its still there that means iether video proccesser damage or screen damage.
Mar 13, 2011 | HP Tablets & eReaders
Am having an HP laptop.Now i am having a problem with my mouse touch pad..the touch pad is working,but i am not able tpo clink on anyfile using mousepad.The coursers are moving when i scroll on th mouse...
Your laptop needs to visit a laptop service/repair centre.
However you can purchase and make use of a USB mouse; it'd serve.
If you own one, use it instead.
Oct 13, 2017 | HP Pavilion TX2000Z Tablet PC
My laptop is Hp TouchSmart tx2,the problm is :-The pointer moves unwnted icon it click by it self.
The problem is very simple. The sensitivity of the mouse pad is too high in your laptop i guess. Try adjusting the sensitivity of the mouse. Go to control panel-> mouse options->mouse sensitivity. Try changing the double clicking speed, mouse sensitivity etc and check your mouse operation now.
Aug 03, 2010 | HP Tablets & eReaders
Faulty HP laptop
It mainly comes due to improper mouse orientation. U can download a lot of softwares to orient your mouse. Even after that it is not getting corrected better you consult the HP service center and u can find the nearest service center in www.hp.com. Dont try anything like removing the mousepad by yourself or something like that. For urgent purpose u can use the external USB mouse which is very cheapily available.
Thank U
Dont find a fault ,find a remedy-Henry Ford
Please rate me as it wil just one click for u
Oct 26, 2009 | Tablets & eReaders
CD DVD stopeed working
Windows XP
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
May 12, 2009 | HP Pavilion tx2120US Tablet PC
Pen Problem
First try updating to SP2 and then get the latest Windows Updates from Microsoft.com.
If that doesn't fix it, here are some Win2000 drivers for your laptop.
http://www.fujitsupc.com/www/content/exe/PenW2k1.4.exe
http://www.fujitsupc.com/downloads/mobile/st3400_pen_w2k.exe
If that doesn't fix it, try these Wacom drivers.
ftp://198.145.255.42/drivers/IBMPC/consumer/503/PenTablet_503-3.exe
Oct 17, 2007 | Fujitsu Stylistic LT C-500 Tablet PC
Open Questions:
IBM ThinkPad X41 Tablet PC Logo
707 people viewed this question
Top IBM Tablets & eReaders Experts
Steven Wander
Steven Wander
Are you an IBM Tablet and eReader Expert? Answer questions, earn points and help others
