Question about SanDisk Sansa e250 MP3 Player
Music from burnt cds...won't go to assigned folder
I have created folders and stacked my music in each according folder on my computer but when i turn on my sansa e250 it deletes the assigned folders and throws all the burnt music into an "unknown artist" folder. i would like to be able to dictate where my songs are stored on my mp3 player and seperate them by artist but it's just not letting me. it's ridiculous and frustrating. what can i do?
Danny
  • Packy427 May 11, 2010
    I think i can help... but i need to know how you are getting your music onto your device. Are you using a program such as Windows Media Player or are you going into 'My Computer' and copying the music files into the device's drive?
  • 34 Answers
Thats the way the software works. I'd suggest using an option like within winamp - where it looks for media tags and fills in all the appropriate information as to artist and genre for you. Winamp will do this with songs that have absolutely no information in them whatsoever (like burns) but it cant with homemade files like your buddy's garage band. The only way to seperate it besides folders is within playlists.
Posted on Jul 22, 2009
I deleted the music folder and nt able to play the songs in mp3
When I had the same accident this is what worked for me. I disconnected my sandisk player from my computer. After waiting until the sandisk software completed it's termination programming, I re-connected it to the computer.
Because I use Microsoft Windows XP, a window pops up asking if I want to open the device in Windows Explorer. Answering "yes" and then selecting the "Folders" from the tabs at the top of the window will display the sandisk along the left column as "Sansa e250". By double clicking on the folder labeled "PPI NAND" a drop down list of subdirectory folders should be displayed. If the folder "MUSIC" is not there, you will need to create a new folder and label it "MUSIC".
Here is how to create a new folder.
With the folder "PPI NAND" highlighted, move the cursor up to the upper right hand corner of the "Windows Explorer" window and select the tab "File". From the drop down menu select " New Folder ". This should cause a folder to appear in the window to the right of the "Sansa e250" window. The new folder should be highlighted and labeled "New Folder". Select the "New Folder" and rename it "MUSIC". When renamed, select the PPI NAND folder and the new folder "Music" should be listed as one of the folder in the subdirectory. If so, you can select it to see if the Music folder contains and music files. If not, you will need to copy or drag your files into the new "MUSIC' folder.
Once I did all of this and disconnected my sandisk player, the player and let the software complete the programming work before shutting it off, it worked fine. My original problem was caused by shutting my sandisk player off after disconnecting it from the computer before the sandisk software completed its work.
Hope this helps.
Mar 12, 2009 | SanDisk Sansa m230 MP3 Player
Can't view my Music folder?
got this solution by google :D
go to settings on your mp3 then usb mode then click msc then reconnnect to computer go to my computer then tools folder option, then view tab, then hidden folders then click show hidden folders!
HOPE THIS HELPS!!
bigman14
Jul 10, 2008 | SanDisk Sansa e250 MP3 Player
How to remove songs....i dont get it still
hello!
here's how you will delete songs off your Sansa e250
step 1: Go to"MY COMPUTER
Step 2: Find and open the sansa drive
Step 3: Look for the music folder.
NOTE:
If you dont see a music folder you will need to go to the top where it says tools>then >folder options>then click on show hidden files>
Step 4: You should now see the music file. Go into it and simply delete any songs you don't want.
May 08, 2008 | SanDisk Sansa e250 MP3 Player
I some how deletted everything can i get it back ?
you can fix the problem by having the original sansa files when you format it it deletes everything
get a friends sansa files or do this
and just because it would be a pain looking for the original files i uploaded here for people who deleted them put these files into a folder named
DATA http://www.divshare.com/download/4002990-1d7
WMDRMPD http://www.divshare.com/download/4003086-013
REFS--no files
and put them in into 1 folder named SYSTEM--make it hidden then put it on sansa
then create a music folder make it hidden
then create photo folder with thumbnail and my album folder make my album hidden
then create pictures folder make it hidden
then create playlists folder make it hidden put this file in it
http://www.divshare.com/download/4003139-94b
make a record folder with 2 folders named radio and voice
make a folder video
captilize all these except the one listed below
make a tmp folder
this should work :)
Mar 06, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e250r - cannot delete mp3 files
I have had this problem for some time now and finally got through to tech support for Sansa and now have the solution:Worked for both 230 and 240.
Take out the battery in the Sansa player; Put on lock on back side of Sansa player; Connect Sansa to the computer, Once computer recognizes device cancel out of that media program; Go to my computer on desk top; Right click on recognized Sansa device; Click format; Click ok to delete files.
Jan 13, 2008 | SanDisk Sansa e200 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
How do i delete songs off of my sansa e250?
You can manually delete the music thru My Computer. Just click on the device name, and open the Music folder. If you dont have a Music folder, you need to enable hidden files and folders on your computer. Best of Luck.
Sep 23, 2007 | SanDisk Sansa e250 MP3 Player
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
Deleting files from Sansa e250
The only way I know to delete music files or voice or FM recordings, is straight from the User's manual on the CD: 1. Set the e250 to MSC mode. 2. Plug it in to your computer with the USB connector. 3. Open the Sansa e250 drive in My Computer and browse to the MUSIC folder (or RECORD folder)and delete the files there. (That's where you also add music files, by dragging from other explorer windows.) To delete (or add) photo and video files, you have to use the Media Converter, which you install from the disk that came with the e250.
Feb 18, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
62 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
