Question about Raymarine Ds500x Color Fishfinder: Ds500x Color Fishfinder With Bronze Thru Hull Transducer
Screen fog When fishing in cooler weather the sceen fogs up. The moisture is on the inside of the screen.
Hi there... mine did the same the very first morning I took it out. I rang and sent it to the manufactures. It was a very common thing and they fixed it within 10 days. I have not had a problem since. It should not of happened in the first place though. I have read a heap of forums on this exact matter and i think you would be the 10,000 person with this very problem. I have also had big problems with my transducer... so overall I am not impressed with Raymarine.
All the best mate.
Posted on Feb 24, 2009
Canon XF300 issue. I have an XF300 and the front glass has fogged up on the inside a couple of times in bad weather.. Was using the camera indoors.. Anyone any thoughts?
There is air inside those lenses and if you go from one extreme to another temp wise you can have moisture condense on the inside of the lens. Gotta wait for temps to equalize for "fog" to go away.
Apr 04, 2017 | Photography
I have a 2005 Impala. The windows fog up on the inside when it is cold outside or it is raining. They really fog up bad, to the point you can't see.
a fix for this is to run the ac
this although make it cold removes the moisture from the air inside the car and reduces the fogging up
if you have climate control run it or if not run the heater at the same time to take the edge of the cold
The air conditioner works by removing water vapor from the air through a condensation process there by making the air feel cooler
that restricts the moisture available to fog up the windows
Nov 26, 2015 | Cars & Trucks
Why do the windows on my 2009 caravanfog uponce Istart todrive?The windows will beclear after I warm it up but once I start drive they fog up.I do not smell antifreezeand the heater core lookslikenew.
windows fog up on the inside simply because of the hot breath of the occupants
this heat is cooled by the screen and condenses and so a fog is created
simple physics really - hot moisture + cold air =rain to over come this quickly run the air conditioner ( climate control) and that takes the moisture out of the air in the car and then the windscreen clears
you are going to say that it is too cold for the ac to run well at the same time run the heater until you have a pleasant temperature that is dry ( climate control--when it gets too hot the ac cuts in and when it gets to cold the ac switches off BUT the moisture that causes the fog on the windows is gone )
Nov 11, 2015 | Cars & Trucks
Fogged up windows
Are you using the fresh air option ?
If you are, you could have excessive moisture inside the cabin. Running the hvac on defrost should kick on the ac compressor and bring in fresh air too.
Feb 10, 2014 | 2009 Dodge Charger SXT
Cloudy screen
It's possible that you have moisture on the inside of your camera, causing the sensor to fog up. It is also possible that you have fog on your lens as well. I have had cloudy images with my Nikon when it fogged up inside. The best thing to do is to make sure it dries out. This usually solves itself so long as you are in a dry location, but if not I would take your camera to a local repair shop to have it looked at and fixed. It really does sound like a moisture issue however. Do NOT dry your camera using heat or anything! If it doesn't dry on it's own, take it to a pro to get it fixed.
Jul 09, 2013 | Nikon Cameras
Toyota Camry 2004 Defroster fogs windows.
2 possibilities:
1 - HVAC External Drain Tube stopped up with dirt, bee nest, etc. Hard to get to w/out a car lift. Need to clear and drain HVAC box.
2 - Leaking heater core inside HVAC box. Moisture from defog will smell sweet and be hard to clean off glass. Requires Dash removal and AC service to replace Heater Core. Very time consuming and Expensive A-Freeze fumes are also lethal if inhaled.
Try Solution #1 First, Least Expensive, Non-Lethal Condition.
Oct 16, 2012 | 2004 Toyota Camry
Window fogs and smells like cooler fluid, have no leak and evry couple of months i need to add cooler fuid.
If you need to add coolant, you do have a leak. Since your window fogs and have a smell,you heater core is leaking The reason the window fogs is that your coolant is moisture getting blown on to your windshield.
Sep 11, 2010 | Jeep Grand Cherokee Cars & Trucks
In cold weather the inside of all the windows keeps misting up
the fresh air door is stripped at the motor, jaguar has a bulletin, about glueing .....works for a while,
long term fix replace heater plenum assy......
Or rig the door to stay in a midpoint postion, access below the pollen filter
Jan 08, 2010 | 2002 Jaguar X-Type
Scope fogged up on the inside and i cant see out of it. while hunting in the winter the scope fogged up. now that it is getting warm out it cleared up.
The gas inside the scope has leaked out. Moisture condenses in the cold weather and fogs up your optics when this happens. Send the scope to the manufacturer and they will warranty it. All scope manufacturers have real good competitive warranties. TP
Apr 16, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
Raymarine Ds500x Color Fishfinder: Ds500x Color Fishfinder With Bronze Thru Hull Transducer Logo
323 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
