Question about HP OfficeJet 6110 All-In-One InkJet Printer
Bogus paper-jam message in HP 6110 all-in-one
My printer says there's a paper jam, but I've looked in every nook and cranny and can't find any jam. One of your users said he had the same problem and someone told him that it was the result of an out-of-position sensor. So how do I fix this problem? What does the sensor look like and where is it supposed to be? How does it get out of position? Thanks for your help. Bob J bobjarboe@mris.com
The faxs don,t work and i can,t scan and it said the paper is jam and the paper is the worng size
Posted on Jan 06, 2009
Paper jam in printer keeps coming up we have cleared all paper out and it still comes up. Can you help?
use a bright light (LED flashlight, for example) and examine all nooks and crannies in the paper path to find that one tiny shard that is causing the jam indication (or blocking the detector). You may find it necessary to use tweezers to remove the paper bit by bit.
May 04, 2016 | Office Equipment & Supplies
HP 6110 Officejet all-in-one will not print from the glass top. It will make prints coming from the computer after I press "enter" from message "paper jam". I also can fax. Please help.
You will need to open the top and look inside where the paper travels through and attempt to free any paper pieces that have gotten stuck in the pathway. You probably have a bad board in your control panel, since you are able to print from the computer.
Feb 20, 2013 | HP OfficeJet 6110 All-In-One InkJet...
It reads that there is a paper jam but I have checked everything and there is no paper stuck in it.
press cancel on ur printer..
off it.. n try it back..
make sure the paper fit with ur printer size
Oct 24, 2009 | HP Photosmart C4150 All-In-One InkJet...
6110xi paper jam, or something worse?
Actually, the "paper jam" message can be displayed due to a variety of jam locations and other causes. Starting by looking in the back of the printer is a good first step, but you can have a jam in the front or even in the automatic document feeder (although that one should be apparent because it's sticking out the front end.
HP.com has a web page that goes into a lot of detail about where to look for a paper jam and what other conditions in your product might cause such a message to occur. The solutions are available as well. Take a look here:
Paper Jam error
Try those solutions and post back your results. Good luck.
Nov 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
go to hp.com, support and troubleshooting, type in your pirnter model number and download the user manual. follow the direction to disassemble the printer. you might not need to disasseble the printer, if you can see the jammed paper.
follow the direction and clean the roller and the printer head.
it should work.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper Jam Error Message
I would try to clean the tires with alcohol, it's probably trying to pick up the other sheet but is slipping.
take out the tray and look inside for the pick-up and seperation tires.
Oct 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Paper Jam at 2
Its probably not picking up paper from that tray, thus the jam error. For me that is typically because the tray isn?t pushing the paper up high enough to be caught by the pickup roller or the pickup rubber band is worn.
Feb 02, 2007 | HP Color LaserJet 2600n Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
83 people viewed this question
Ben Johnson
