Question about HP T30 DK411AABA Network Terminal
I have an HP c4180. My pc is Windows xp. Would like to print through my wireless hub. Internet and printer are connected hard to the hub. PC won't see the printer.
I have the same printer, & it prints fine on my desktop pc but to get it to print from my laptop wirelessly I just had to enable printer sharing on both pcs, & then when adding a new printer on my laptop I just had to set it to print over a network. the only problem I get is I have to select the printer when starting a print session.
Posted on Feb 01, 2009
How to set up wireless printing with disc
Here are the minimum details needed to answer this kind of question:
1. Operating System :
Windows XP, Windows 7, Windows 8, Windows Vista?
2. Printer make/model:
(this is important to determine the wireless properties of printer)
3. Network Connection:
(is the laptop connected to the same network as the printer)
If you are working with a new printer (see item 2) and you have a network on which you have your notebook connected, there are so many possible ways to connect the printer to the network that it's hard to say.
If you are working with an established printer that has wireless services running, you may need to know either the Network Name of the printer or the IP Address of the printer.
Your best bet is to make use of hp's extensive Wireless Printing Center (see link below).
Wireless printing center
Feb 26, 2014 | HP Pavilion dv6000z Notebook
I cant print wireless on my hp Laserjet 1015 Printer. I have it like a Directed connected shared printer to my PC. By the way, the operative system of my pc in which i have it connected is XP, and it does...
With that, you need to install the printer into your windows 7 computer and windows vista computer.
Even though the printer is installed into your windows xp computer wirelessly and set up as shared printer, you still need to install it on to your other computer because you need to install the driver and other printer's software to maximize the features.
Since the printer is already connected, you just need to run the appropriate installation package, the one that's compatible with your Operating System, and install it via Wireless or via Network. For the correct installation package. You can download it from the hp website and check the Support and Driver's section.
Cheers!
Jun 22, 2011 | HP LaserJet 1015 Printer
IP address of my Photosmart C4180
HP PhotoSmart C4180 All-in-One is a not a network supported printer. This is just a USB printer.Hence you will not be able to assign or locate the IP address of this unit.
This unit supports: USB 2.0 Hi-speed in Microsoft Windows 98 SE, 2000 Professional, Me, XP Home, and XP Professional; Mac OS X 10.3 and later
I request you to use Wireless Printing Upgrade Kit (Model number: Q6259A) to connect your unit wirelessly.
May 25, 2010 | HP PhotoSmart C4180 All-in-One Color...
Print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access Piont: My Home Wifi (kaba)
Host : ip address of you printer
user : Blank ( tried my windows username,no use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Damien_1977
Jan 07, 2010 | Polaroid PoGo Digital Photo Printer
How to set font size for each printing or default print font
Font size for printed documents is usually controlled by the application from which you are printing, and not the printer itself.
Good luck.
Mar 29, 2009 | HP Photosmart C4180 All-In-One InkJet...
C4180 ON A NETWORK. BOUGHT A NEW LAPTOP AND WANT TO PRINT
Install the software on the laptop first and when it asks to connect the device, continue without connecting. Once finished, ensure the printer on the desktop is being shared in the printers folder. Then on the laptop add a device and search the network. If your 2 computers have the network established it should see it.
Mar 24, 2009 | HP PhotoSmart C4180 All-in-One Color...
HP C1480
Please perform the below steps to clear the queue and print from the computer.
Before performing the below steps try to make a copy from the all-in-one to check the hardware functionality.
Remove the USB cable from the computer.
Now click on start --> control panel --> printers and faxes --> right click on the HP C4100 printer icon and delete all the pending documents.
Now again click on start --> run --> type services.msc and press enter --> locate print spooler in services window and right click on the print spooler and click on refresh or stop the spooler service and then restart the spooler.
Now open the printers and faxes folder, right click on the printer icon --> properties --> advanced tab --> enable print directly to printer and click OK.
Now connect the USB cable back to the computer and then try to print from the notepad and check for the result.
May 29, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP All-in-one printer C4180 network readiness?
the dell must be set to host or peer to peer on the network for the other computer to find it through tcp/ip or ipp protocol. it comesdown to software set up which is always the biggest headache second to the userintroducing a problem. good luck
Mar 30, 2008 | Computers & Internet
Sharing HP PSC 1410V All-In-One
Yes, you can and it is pretty easy.
You should get the HP Wireless Printing Upgrade Kit
(Q6236A#A2L)
Price: $69.99
Here is there product description from HP.
Get everything you need to print wirelessly in this simple upgrade kit! It includes a printer receiver and PC receiver for a wired desktop or notebook PC, and it's easy to both install and use.
Works with most HP printers and All-in-Ones, plus all PCs, wired or wireless.
* Print from virtually anywhere in your home or office via the wireless 802.11g connectivity
* Eliminate ugly cable clutter but still get the same print speeds as via USB
* Retain full all-in-one wireless functionality: print, fax from your PC, scan, and access photo memory cards access and PC status
* Set up fast: just plug the receivers into your printer and PC; there's no configuration
* Protect your signal from interception with the secure wireless connection
* Use with a network, or just one PC
* Compatibility: most HP printers, all PCs (wired or wireless)
** I checked and your HP is on the compatibility list - it is ok***
What's in the box?
1 printer receiver
1 PC receiver
William
Feb 15, 2008 | HP PSC 1410v All-in-One Printer
HP T30 DK411AABA Network Terminal Logo
176 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
