Question about Kenmore 44072 Front Load Washer
Kenmore washer need to put rubber gasket retaining spring back on. Any tricks, seems impossible. Peter
I assume that you're talking about the inner spring. It's very tight, so you have to get the rubber gasket (bellows) fitted on the its frame, then push the bellows inside out in toward the tub. Start with placing the spring in its groove at 12 o'clock. Wedge something between the bellows and the white colored weight ring of the tub. You'll need something approx 3/4" in diameter to wedge the top of the spring in place. (I've used a 1/2"X90 degree copper elbow I had laying around that had an approx outside diameter of 3/4"). This will hold the spring in place as you work it around. It is still very difficult and you may have to stretch the spring ever so slightly to get it back into the groove. Once the spring is back on, remove the wedge, fold the bellows back out and attach the fill hose and attach bellows back to front panel.
Posted on Jan 04, 2009
Frigidaire(ATF6000FS-wow) have to install a door lock and switch assembly..(PS2367737).....need to know how to get to the part.......(have to get past the rubber seals ) so i don't damage anything.
Welcome to FixYa.
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front (impossible if a dryer is stacked on top...aside from removing the dryer of course) or the way I prefer, remove the front bellows spring/retainer.
1) **UNPLUG THE WASHER FROM THE WALL OR TURN OFF THE BREAKER.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear and I'll try and help in any manner I can. If this does indeed resolve the problem please take a moment to write a brief testimony and a favorable rating is also appreciated.
Thank's again for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
May 03, 2011 | Frigidaire Washing Machines
WE have Kenmore elite He3t Model Nol. 42926 203. We get an error code dL F. How do we correct this?
It is a door lock failure and it flashes after the door locking routine fails to lock the door after 6 attempts. Replace the door lock/latch assembly (part number 8182634) to solve the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jan 07, 2011 | Kenmore Elite 45986 Front Load Washer
How does front panel come off (safely) to swap out door switch on kenmore washing machine 41744152400
The front panel does not need to be removed when replacing the door switch. What needs to be removed is the door gasket. Open the washer door. Get a pair of needle nose pliers then look for the retaining hoop securing the door gasket to the lip of the door opening. Stretch the hoop retaining spring at the bottom of the lip of the door opening then carefully pull the hoop out. Make sure not to tear the door gasket or else water will leak through it.
Remove the two screws securing the door switch to the front panel. Peel off the door gasket near the door switch then pull the door switch off the front panel and out of the washer.
Disconnect the wires from the door switch terminals then connect it to the new door switch. Secure the new door switch back to the front panel then put the door gasket back over the lip of the door opening. Properly secure the door gasket to the lip of the door opening with the retaining hoop.
Mar 11, 2010 | Frigidaire ATF6000ES Front Load Washer
The rubber in front of the machine has come out so has the metal spring that goes around it
take lid off put rubber back in place and put the metal holder around the rubber with screw loose try have the clip connection to the top as this helps with tightening. tighten screw and jobs a good un
Jun 23, 2009 | GE WSXH208A Front Load Washer
Rubber is off it's track and water leaks out during the wash
remove the spring and reseat the gasket, then replace the spring clamp spring side down. this part will be kind of tough but may help to wet it to make it slide on. not doing this will cause leaks
Mar 25, 2009 | Kenmore Elite 45986 Front Load Washer
Put front gasket back on
start on the door side of the appliance put the top of the circle in first this should allow you to stretch the spring a little to make it go on
its a pain and it kills the tips of your fingers try not to overstrech it because it will fall off all the time
Mar 12, 2009 | Bosch WFMC 3200 Front Load Washer
Gasget came off the washer and i can't get it back on
I have the perfect solution the placing of the Retaining Spring back on the Bosch Nexxt 500 Door Gasket. It only took me only 5 Minutes after fighting with it for hours and getting nowhere. What I did was purchase a set of 12 inch hemostats (long Clamping Pliers). The ends of the Hemostats I wrapped both of the jaws with Electrical tape to prevent the Spring on the retainer from sliding up the jaws of the hemostat. When the ends of the retainer are placed on the ends of the jaws and the hemostat opened the spring is stretched. I found that If you use your knee to hold the hemostat open while placing the retainer in the groove of the gasket you can slowly release the springs and set the retainer back into the gasket without the gasket pulling off the tabs.
Mar 01, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Rubber gaskets came out
remove spring retainer ruber door boot remove the rubber.looking for the clamp loose it put the door boot back in the tub(drum)tie the clamp go revert the procedure(take out)good luck
Sep 29, 2008 | GE WSXH208A Front Load Washer
Rubber gasket Bello!
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
Apr 29, 2008 | Bosch WFMC 3200 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Kenmore 44072 Front Load Washer Logo
103 people viewed this question
Sal De
fordexpert
Robert Rankin
