Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony e55a20 tries to turn on then flashes pwr light in sets of 6
The unit is approx 18 months old and just went dark and now won't turn on at all. Any advice would help. Thanks
  • 149 Answers
Really sorry to say but you need a tv repair man. This unit has something wrong internally. Also there is usually a reset button on the back of the tv. This is your only other option. try resetting the tv, if there is not button on the back hold the power button for at least 1 minute.
Posted on Jan 02, 2009
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
My sony kdf E55a20 does'nt come on ,has two red light's on blinking, the other not
the set may or may not have the self check feature--set off with the Sony remote hit display, 5, vol down and power.
Oct 29, 2012 | Sony KDF-E55A20 55 in. LCD Television
My Sony Grand Wega KDF-E55A20 will not turn on with the remote or manually. The red light flashes 6 times then off.
6 times is the lamp thermal fuse or lamp. its a thermal that sits on the bottom of the lamp area.
remove the fan and you will see the siler disk with black base cut the wires and slide the new one in on the side secure it on the old thermal and your fixed.
Nov 04, 2010 | Sony KDF-E55A20 55 in. LCD Television
Unit keeps turning itself off.Sound comes back on a little while after set turns itself back on. Sony LCD model #KDF-E55A20. Help it was just taken out of the factory box six months ago I had it and bought...
This Unit is a LCD Rear Projection and most likely the Lamp is causing the problem. I would replace it with a Sony Lamp only. You can order it from Sony at 1800-222-SONY.
I hope this helps,
Skyassoc
Sep 20, 2009 | Sony KDF-E55A20 55 in. LCD Television
Red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Jan 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony KP61V75
How old is this set please?
Jan 03, 2008 | Televison & Video
Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Dec 04, 2007 | Sony KDF-E55A20 55 in. LCD Television
Horizontal (dashed) line across screen
On the KDFE55A20 this sounds like a bad Q-Box. I would get an estimate from a Sony authorized servicer as this part may be quite expensive. On the 55A10 model this may be the B-Block and is also quite expensive. Getting an on-sit estimate would be the first step I suggest. Again go with an authorized Sony servicer. Call Sony or go to Sony.com for customer service. Good Luck
Nov 21, 2007 | Sony KDF-E55A20 55 in. LCD Television
Losing picture and sound
It needs a new bulb, same thing happen with me. jut get a bulb for this model and change it. if you call sony service, it will cost you about $500.
Aug 09, 2007 | Sony KDF-E55A20 55 in. LCD Television
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
