Question about Microsoft Windows Vista Ultimate Edition
Runtime error with Microsoft digital image 10
Not too computer literate - running vista business - can u et me know how to solve above problem - it is not letting me open programme - have taken off and reinstalled twice - still happening? Cheers - Josh.
PS. How do I get t the RUN command in vista? Thanks!
  • 42 Answers
Go to start and in the type filed put "cmd" and enter. That will open command prompt. If you want to find it in the start menu it's under programs, accessories, command
Posted on Jan 04, 2009
Computer crashed - installed new hard drive and quick books pro9 2001 - opens but when clicking on its closes says programme closing
QuickBooks from 2001 will probably have serious compatibility issues unless your operating system is from 2001 as well.
If you have a new operating system (Windows Vista onwards) you may be able to install and run QB in compatibility mode. I have it running on Vista Professional.
Right click on the executable and select Run in Compatibility Mode and then select Windows XP from the options.
If you do not have the option to run in Compatibility Mode, you will need to update QuickBooks, or your OS or best of all, both.
If you have no luck running in CM, uninstall the program, reboot and then install the program from the disc by using the same compatibility technique. You will need to disable autorun if the program tries to install itself when you put the disc in the drive
Oct 05, 2014 | Computers & Internet
My HP Officejet 6300 All-In_one series will not install on my new laptop computer which has a Windows Vista Business Running program
can u insatall ur printer in a your buisness software there was a printer satting in a your busness soft ware installl your printer in a your busness software
if not happen then u wolud to reinstall your printer in your windows vista
if problem occers then u have to call ur business software engg
might i hope your problem will solved
Mar 25, 2008 | Computers & Internet
Sound not working
Hi
Try this one and let me know if the issue is solved-
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?lc=en&cc=us&softwareitem=ob-40619-1
Download the setup, run the setup when downloaded. You may have to restart the computer, then test your sound again. and let me know if you need more assistance.
Sep 11, 2009 | Compaq Presario 1200XL104 Notebook
Won't let cancel print job once started
If you haven't solved the issue yet, try this link.
I think this will resolve your issue.
http://www.topfreestuff.com/printSpool.shtml
If you're running Vista instead of XP, the command Run is in the startup folder Accessories.
Aug 12, 2009 | HP LaserJet 1020 Printer
Operating system restore
You can go to this site and create a Vista recovery cd. The instructions are on this page,then you will be able to recovery your Vista OS.:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 14, 2008 | Microsoft Windows Vista Ultimate Edition
Drivers for use with Vista 64bit
Thank God that I don't have Vista! Everyone I know who has it has had it taken out and XP put back on. Vista has an agenda all of its own. I know a computer repair man who has at least six customers a day who want it taken out! It may be an idea to do the same. I have never had any problems with XP. It's not really an answer, but maybe you should try it? John.
May 13, 2008 | Panasonic NV-DS65 Mini DV Digital...
HP Cue Status Root has encountered a problem and needs to close.
ça m'etonne plus que chez HP ils licencient un max , c est une réponse à la con et le mec y ferait mieux d"aller à la peche que de te repondre des conneries pareilles .
sous Vista.
methode rapides .
1 /Panneau de config
2 / outils administration
3/désactiver le service HPCUE
et voilà tu ne seras plus embeter parce truc de merde .
il doit avoir une autre solution pour virer définitivement ce probleme , on verra plus tard fais dejà ça et ton pc va demarrer normalement et plus vite .
Apr 15, 2008 | Office Equipment & Supplies
Windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
How to make a bootable Windows Vista ISO DVD media
1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
3. Exit from the Install Windows screen.
4. Download CDimage 2.52
5. Extract CDimage from CDimage.zip to the C:\ root directory.
6. Open a command prompt shell, and run the following command:
cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK)
1. Complete step 1 - 3 as above.
2. In the command prompt window, run the following command:
oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
3. Burn the ISO image file by using last step above.
Mar 24, 2008 | Computers & Internet
HP Officejet Pro problem
Hi, try this.
go into My computer/ Locate The Disk In the Drive D:-/E:-/F:- et,c.
right click, open/open folder to View.
Locate a file towards the Bottom, installshield Wizard Or setup.exe. or similar, try launching the program from there.
If it does,nt work, or still gives you incompatability warnings, Try START/RUN/DRIVE D:- E:- et,c setup.exe.
If none of the above work, contact hewlett packard customer services for an updated driver, via thier website.
Mike @ Compurepair.
Feb 25, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
