Question about Xerox Phaser 7300DN Laser Printer
How to correct error message sram error missing E?
Recently had a major power outage, printer does not have battery backup. Message on screen sram error missing E--this message did not allow you to press the info button as it does with paper jams, reset print cartridge etc. Power light is a different color. Have tried turning machine off, and unplugging. During a thunder storm power was again off, when power was restored the machine worked wonderfully for most of one day. Then another power outage and the sram error message is on again. Have tried unplugging power over night and it does not reset itself. Any suggestion?? I know we need a backup power supply surge protector.
  • Anonymous Dec 07, 2007
    Same problem. Except there was now power outage. Just switched Printer from Static to DHCP. Restarted the printer and get the same msg "sram error missing E".....not suere what to do??
    Novelist:
  • 208 Answers
Hate to say this but most likely the Print Engine Control Board has failed.
Posted on Dec 20, 2007
Its a faulty engine board, i have seen it before. Call 1800 807 472. Its the real oki office. Talk to a bloke called paul in the service dept at brisbane , he can help you out.
Posted on Feb 08, 2008
Why am i getting the error message * memory rx 2P Recording Paper Jam? I can t find a jam anywhere?
Delete the fax and check paper tray rollers are cleaned. May be missing feeding which mean roller can't grab the paper and machine is expecting the paper to be at a certain point and does not see (Though sensors though out the paper route thru the machine so it thinks there is a paper jam) Also mite want o clear the memory (SRAM/DRAM) will lose one touches so make sure you have list backup
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 27, 2014 | MinoltaFax 2600 Printer
APC SmartUPS X (SMX1000)- "AVR Relay Weld" error message
I had this exact problem after a major power out: Fault, call support: AVR Relay weld.
I fixed it by resetting the UPS: Remove battery connect at rear of UPS (it is marked, just unplug the bat connect tab). Plug the UPS back in, and then turn on. Let it power up... it will tell you it needs a battery. Next, power it down and unplug. Plug the batter connect back in (see rear). Plug in the UPS.. power up. Presto.. it is reset. If it is NOT reset, there may be a real 'relay weld'.
May 13, 2013 | Computers & Internet
Some type of error message
These problems can be created by loose contacts in power outlet, RC jack, cable, sockets. Check these thoroughly and if necessary, change the RC cables. The message you see might be something related to auto shut off activated due to poor or lack of signal. This might also be from the service provider's computer.
Aug 21, 2012 | Panasonic Viera TH-50PX80U Plasma TV
Error code 78
Usually a result of a sudden power outage. Majority of the time it can be reset without replacement of the fuser. Here is an article I wrote explaining the cause and how to reset the message.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/28/brother-fax-mfc-76777879-fuser-errors/
Dec 06, 2010 | Brother MFC 8300 Laser Printer
The machine is showing the "sram error missing e" message. Is this something I can clear myself? thanks.
If you power-off the printer, wait a few seconds, and power-on the printer, and still get the same error-message, the answer is 'NO'.
Take the printer to a qualified technician for remediation.
Oct 29, 2009 | Xerox Phaser 7300DN Laser Printer
I have a peavey pro-fex 2 preamp/FX ver 1.3 controller and when powereing up, get DSP interface error. Do you know what this means or how to fix it?
Your Profex likely has a dead NiCD battery. You are getting this error because this battery maintains your personal effect settings on an SRAM chip that requires constant power to "live". You can try reinitializing the SRAM on your unit by doing the following:
1. Power off your Profex.
2. Press and Hold the "PLAY" and "GLOBAL" buttons while powering the unit on.
3. You should see a message on the display that reads "MEMORY INITIALIZED". Afterwards the Profex should act normal.
4. If your internal battery is getting low or is already dead, it is going to start leaking (if it hasn't already). YOU NEED TO GET THAT BATTERY CHANGED NOW!!!!! If enough battery acid leaks onto the circuit board, it will ruin your Profex forever.
Aug 03, 2008 | Audio Players & Recorders
Eror code on sharp copier AR-M276
UNRELATED PROBLEMS.
H4 = MAIN HEATER LAMP ABNORMAL LOW TEMP. THE FINAL UNIT BEFORE PAPER EXITS. HAS TO BE HOT. LAMP OR THERMO-FUSE? CHECK CONTINUITY LAMP WIRE IN THROUGH WHOLE PATH TO OTHER LAMP WIRE OUT.
E1-15 = IMC board Page Memory error/SRAM
error. MEMORY FULL? Mfr. says "Print Buffer Page Memory or Work SRAM abnormality"
SORRY NO MORE.
Jun 24, 2008 | Office Equipment & Supplies
Error message
Cause:
This message is related to the on-board SRAM on the Print Engine Control Board Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Replaced the Print Engine Control Board,
Dec 19, 2007 | Xerox Phaser 7300DN Laser Printer
Sram error missing E
Better if you have other person to help you.
Turn off the printer, hold 0 3 5 6 7 buttons, turn on the printer, wait until the *s disapair.
Jun 07, 2007 | Xerox Phaser 7300DN Laser Printer
When should I replace my backup battery?
The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Xerox Phaser 7300DN Laser Printer Logo
2,074 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
