Question about Sony VAIO PCV-V200G PC Desktop
Vaio tv wont work
Cable is hooked up. I get no picture . I keep getting error messages like Gigabite data base damaged and tvsetup-fail start service()function(0x80070422) . I go to the control pannel and click tv setup and nothing happens ??
  • 4 Answers
Mate the only thing i can think of is the graphics card in your computer is not able to run with the tv its not big enough perhaps,or it doesnt support the feature
Posted on Jan 02, 2009
Hitachi rear projection hd tv. message on screen says invalid cable card installed. remove to restore video access. there is no cable card installed as we have cable service through a cable company. j
Two things to try here---first is unplug the set for a while and plug back to see if the microprocessor in the set will reboot.
Second look to see if slot for the card has anything at all in it or is dirty.
if dirty blow it clean and repeat unplug procedure Note: very few of these sets have a hard reset feature but if all else fails call Hitachi customer service with the model number---they have some very good people answering the phones and an extensive data base on sets/problems.
Apr 11, 2012 | Hitachi 57F500 57" Rear Projection...
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
Media test faiture, check cable error message ,
The error is related to your network interface card. In a lot of laptops this is integrated to the motherboard and can't be switched out at home. You will need to take the laptop in for service to have the card replaced.
Sep 27, 2009 | Sony VAIO Notebook
I have a 32" LCD TV that I can't seem to get any of my DVD players to work on. Keep getting error message "no video signal" but They use to work. help
How do you have your DVD player hooked up to your TV(i.e. composite, s-video, component)? Some DVD payers and TVs have menus to switch inputs and if you somehow switched off the input your players are connected to, you'll get a "no signal" message.  First try hitting the input button on your TV or the Input/connection option in your TV's menu.  If that doesn't work try hooking up the DVD player(s) with the composite Cable(yellow), the component(red,green,blue) and S-Video(black/round) at the same time. If you scroll through your TV's inputs you should get a picture on one of these connections and the TV should display which one. The display will usually be in the corner of the screen.
Apr 27, 2009 | Televison & Video
Not to computer saavy so please keep it simple. I have a Sony Vaio VGC RA840G desktop with 5.1 surround sound. Also have a Samsung LN46A850 S1F HDTV. Also a home theater system. This is hooked up to cable...
From the looks of the TV manual you have everything right, so it's very odd you're running into this problem.
Have you tried swapping through the sources? I find with one of the TVs we have on display at work that any time I'm having some troubles with it I will change the source from PC to something else, then back to PC.
If that doesn't work then I'd suggest you try reseting the sound settings back to factory default. The instructions are on page 45 of the TV manual. From the TV menu select "Sound", then "Sound Reset", then either "Reset All" or "Reset Sound Mode". I would suggest reseting all.
Last option would be to try using the headphone jack in the side of the TV, though this is a last resort kind of thing since you would have to unplug it every time you wanted to use the cable box.
Hope this helps :)
Apr 16, 2009 | Sony Computers & Internet
What is ini file error: app path data fail? my laptop wont start
REstart your computer and keep pressing F8 till you get the option to boot in safe mode. IF this works then it means a driver or some piece of hardware you added is conflicting. If it still wont boot i would think bad RAM.
Dec 14, 2008 | Acer Aspire 3690-2196 Notebook
Sony Giga Pocket, error: GP666-computer pcv-rs 430G
I had this problem and I renamed the GigaPocket V5 directory and restarted Giga Pocket. No more problems with GP666, now I just need to learn how to re-import the old videos into the cabinet.
Wingblur
Mar 25, 2008 | Computers & Internet
Sony VAIO PCV-V100G PC
yes reinstall the tv tuner software.
there might be some other applications conflicting the same.
Feb 04, 2008 | Sony VAIO PCV-V200G PC Desktop
Xp wont start on sony vaio v94vq
Try booting into safe mode completely. Then shut down completely. Unplug for a couple minutes and plug back in and see if it will boot normally. If not, then go back to safe mode and use a restore point in XP. If that does not work then either XP is corrupted or the hard drive is going bad. You can try restoring your system with the restore discs. NOTE: This will erase all data, pictures, letters, financial info, etc. you have saved.
If that does not work then you can try replacing the hard drive.
Hope this helps!
Nov 28, 2007 | Sony VAIO PCV-J200 PC Desktop
Sony VAIO PCV-V200G PC Desktop Logo
83 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
