Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Cant remove clips from whirlpool gold ultimate care II washer we see answers to what to look for but not how to get the clips off these are on the top of the washer. Have tried to push them down and to pry them off. no luck please PLEASE can someone answer how to get these hateful things off?
  • 9 Answers
Stick a flat bladed screw driver in the front side of the clip and the handle of the scew driver will be leaning toward the front of the machine, push the tool toward the back of the machine and the clip should pop out of the top.
Posted on Jan 28, 2009
How do you open a top loader
You have to hinge console back by loosening screws in back corner of console. Then remove two gold clips that hold cabinet on. Pry with flat head screwdriver. remove wiring harness from lid switch and the whole cabinet will pull forward
Jun 13, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
How do I remove and replace a lid switch on a whirlpool ultimate care II quite wash and what tools will I be needing.
You got two star screws on each side of the console then flip the console disconnect the quick plug on the right hand side. Next you got two gold colored clips to take off. cabinet tilts forward. Two screws holding the lid swich and unclip it on the inner cabinet. Sounds more difficult then it is. An expert should take him no more than 15 min.
Jun 04, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer leaking in floor, appears to be coming from a clear/white plastic piece near the pump, Ultimate Care II top Load Washer
it's the pump housing anot an exspensive part and for my washer removing it was as easy a poping 2 black metal clips
Mar 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate care II doesnt' advance through
Lean washer on its back and check for broken wire from the motor wire harness up the back panel.
If you find the wire repair it and make sure the wire harness is secure in the provided clips.
Jan 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Replace lid switch
remove the screws on the control panel
pull the panel forward to unseat it then under it pop the clips that hold the top to the back of the washer the rest is self explanitive
May 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How do brass (gold) clips go back into the slots when trying to put Whirlpool Ultimate Care II back panel back on after repairs are done?
they can only go in one way it's a matter of figuring it out. Believe me I've taken more time trying to figure this out when I did not pay attention as to how they were before removing.
Apr 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How to remove back & top of a whirlpool ultimate care II washer
I'm not sure of the model number of the stove but usually slide a putty knife under the control panel between the bottom of the control and the top of the base. There is a clip on each side then the panel will tilt back and you can take it off. After that there are 2 gold clips that hold the back on to the base. Remove them by snapping then out of the base. The the whole thing is loose and the base (where the lid and sides are. Comes out as 1 big piece. If you get the model number from under the lid, you can go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
and it will show you a breakdown of the machine. Let me know if you need anything else.
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I need help in opening my Ultimate Care II washer's housing
two screws on top usually on front take out flip up top you will see two gold clips on each side.take a flat tip screw driver put them in slots and pop loose remove unplug spin switch and lean cabinet forward and slide off .leak could be coming from pump tilt back first look inder it have a paint can or coffe can or tilt it way back and look under it pump on motor is probably leaking then take off case
Sep 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal De
