Purchased wireless router and it does not work. I was told by tech support from the router that I "need to upgrade my adapter"?
  • sonofspy May 11, 2010
    manufacturer and model of your network card.
    manufacturer and model of your router.
    Novelist:
  • 176 Answers
Yes, it may be that the wireless card that you have is defective or its disabled. If you can connect by using a direct network cable (cat5) connection to the router (if its a combo router ) from your PC's network card ( not necessarily your wireless card unless its also a combo) then the router is good. You may also need to upgrade your wireless driver or may just need the correct driver.
Posted on Jan 02, 2009
Link sys not working
Go here for support.
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G
Then click on Access Live Chat, bottom right side of page.
Info needed Model #, Serial #, and Version # on back of router. Also if you did any upgrades!!! Do not do a reset unless told by tech!!!
Sep 26, 2010 | Linksys Wireless-G Broadband Router
WRT160N Wireless Router : i just bought a new laptop and a lynsis wrt160n......
The wired and wireless speed will always be different.
The maximum wired speed will be 100 Mbps. That means the wired connection is working properly.
Wireless connection speed will depend on the router and the wireless adapter on your computer.
If you are using B-Adapter then max speed will be 11 MBPS. IF it is G-Adapter then max speed will be 54 Mbps.
The N-adapter will give you more speed.
Check in the Device manager which adapter you are using on your wireless computer.
One more thing you can try changing the wireless channel on the router.
You will need to access the router settings page.
Update the drivers of your wireless adapter on the computer.
You have WRT160N router.
This router has issues with the Firmware.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
May 07, 2010 | Linksys WRT160N Wireless Router
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
Oct 05, 2009 | Compaq Evo N610C Notebook
Netgear wireless adapter wg111t will not work work
It's impossible that the wireless router cannot detect your wireless adapter wg111t.
You try to test another one if still have a problem connecting with your wireless router.
If that router can see another wireless network available then maybe your Netgear wireless adapter have a problem incomplete installation or the wireless device is defective.
I have encounter like this before so maybe it's the same with.
Hope my tip will help you a lot.
Please rate me.
Thank you.
Sep 14, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | Computers & Internet
Have two computers but only one will get internet access
The tech is right, you can only have 1 modem on your residential line. The 2-wire router/modem should
have 4 ports in back to share with other computers AND a wireless signal too. You can run an
ethernet cable to your bedroom or get an adapter (either USB or PCI card) to connect to your router and
share the modem. If you go wireless, the 2-wire router is by default an encrypted signal. The password
is on the sticker, usually all numbers. Look at manual for changing configuration.
Jul 09, 2009 | Gateway Wireless-B Router (wbr-100)
Router will not connect with on demand direct tv
I had the same problem. I fixed everthing by updating the router's driver. Try that and see if it works.
Mar 01, 2009 | Linksys WRT160N Wireless Router
I installed my linksys g pci wireless router after uninstalling at the advice of the linksys tech. I use free wireless network. The tech installed a security enabled wireless network VU1V3 and now post...
wooooh wooooh
Marcia...............Is this a small home system here. Was this an onsite tech. ISP is Internet Service Provider and not so sure that is the issue. WOW this can get confusing. Perhaps this tech can redo his work for sake of your time. An adapter does allow the ISP to see how many PCs you are using.
Sorry Marcia .................Really would be nice if Mr. Tech could reassist you on this.
Bill
Apr 24, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
