There is a message center number which is assigned automatically by your service provider. You may have accidently deleted or modified the number. Unless the message center is correct, you may not be able to send any messages.
Now, what you need to do is contact your service provider and get this number.
Cheers
for sending text messages : 1.go to your message settings and check the message center number to see if it is correct 2. call to your network operator customer care 3. request the message center number... 4.note it down 5. go to message settings>message center number 6. insert the number which is noted by you and save it
This could only be caused by a couple of things. The message center number in the handset may not be correct, which will cause the messages to fail. The other possibility is that the feature is not active on your account with your wireless provider. What you need to do is test a couple of things. See if you can send a text/sms message to yourself, in doing this you can verify that you can not only send, but receive text/sms messages. If you cannot send, or receive text/sms messages, then that verifies that the message/service center number is off, and will need to be corrected. If that works, and you can receive text/sms messages, then your service center number is correct, and you will move to the next troubleshooting step, which is to test your web browser. If you cannot launch the web browser on your handset, then this is an issue, because the MMS service requires that you have both SMS, and web browser service to send a MMS message. If you can access the internet and you have the ability to send/receive text/sms, then you need to call your service provider as the issue may be with their service.
Hi, go to your wireless provider web site and got their proper number "SMS Message Center Numbers".
On the phone, go to Options/SMS Text, move down to the Service Center line and put in the proper number remembering to put the + plus sign in front of it.
So if you get a Protocol Error and a Red X when trying to send SMS text, check this to fix it..
If you mean SMS messgaes (text) you probably need to enter the SMS message center number. Existing and New AT&T customers The message center number for all existing and new AT&T SIM cards is +13123149810. If experiencing problems with text messaging, please contact Customer Care.
Former AT&T Wireless customers
The message center number for all former AT&T Wireless customers is +19703769301.
Former Cellular One from Dobsoncustomers
The message center number for all former Cellular One from Dobson customers is +13305310005.
go to message setting, text message, text meassage center, then try changing to another center, ( i've got 3 dif centers to pic from but only the first one lets me send text messages)
I had the same problem and came to this site for help but the solutions didn't solve the problem of "cannot send text message" on htc touch hd. All service numbers correct. Went to START/SETTINGS/CONNECTIONS/ADVANCED NETWORK/SMS SERVICE then changed from "gprs" to "gprs preferred". Double checked and had reverted to "GSM" but sms now works - finally!!! Hope this helps.
Kindly check the message center number from your mobile phone if its already there or you can contact your Network Service Provider to provide you the specific and correct message center number. Usually, you don't have to touch these numbers. If you suspect they are incorrect, contact your mobile service provider and ask them to send an Over The Air (OTA) message with the correct information in it.
Please be informed that the SMS Message Center Number is a phone number that acts as a gateway for transferring SMS messages between cellular devices.
From the Options pulldown menu, select Preferences.
The SMS Message Center and SMS E-mail Center number should appear. (Treo 600 note: tap on the tab that says SIM). If you do not see any numbers, it means your mobile service provider does not allow you to change these numbers. But usually you can edit these numbers and your Network Service Provider will provide you the correct and specific one.
Messages > Settings > Text Message > "Send long text as"
If your text is longer than 2 pages, it'll try and send as MMS automatically if you haven't changed it when you had the phone. So if your phone isn't set up for MMS it'll refuse! lol.
This may be the problem...
Go to messages,
press menu ( - )
go to message setup,
then MMS message setup,
then go on composing MMS,
change the reply type to short reply
after sending text got reply 537HV669 message blocked. what does this mean?
