Question about Thermador UCV36A 36" Universal Cook 'n' Vent Downdraft Kitchen Hood
Can fan be lower when operating at full speed
My ecv 36 does not do the job even though i have the right size flue ,when i lower the fan it wont come on until it is fully extended upright,can this be by passed.to come on at full speed in a lower position,so ican catch al lthe steam @smoke.thanks joe
  • 3 Answers
Improper air flow was also my problem. The contractor did a terrible installation job. The duct work was incomplete at the transition piece (he used the under cabinet space as part of the duct) and did not seal the duct to the fan assembly. Both items were not readily visible. Once the duct was correctly installed, the unit works fine. Remember a down draft is never as good as an overhead vent.
Posted on Jan 12, 2009
Heater on fiat ducatto only works on maximum setting.how to fix??
that sounds like fan switch you didn,t say what year some are vacuum operated will require finding connection under dash, if electrical just change switch
Feb 25, 2015 | Fiat Cars & Trucks
My goodman cental air system is having problems. First, the blower inside (furnace) keeps running for hrs after the outside condensor shuts down. Now, the condenser blower motor wont operate at full speed....
the cause of your indoor fan running all the time or for long time after your heat pump has stopped heating is the fan delay relay. It has welded its internal contacts together. If you take off the side below the control panel, the fan delay relay is normally mounted on the header where the fan discharges. Good news, the fan delay relay are fairly inexpensive and easily to change.
As far as the condensing fan motor not running at full speed, when it was changed, did the technician install the correct fan motor. Most condensing fan motors are either 875 rpm or 1175 rpm. They are exactly the same size and if the technician did not look closely he could have installed the wrong rpm motor. There is another possibility, he may have used the wrong capacitor. I have seen the condensing fan actually operate backwards at a lower than normal rpm. The fan if properly installed will discharge air upwards.
Jul 17, 2012 | Goodman CLQ36AR49 Air Conditioner
Temperature needle indicats car is hot even though no leaks and car is full of water
what is the temp? is the radiator fan operating? The fan wont come on until approx 225f
Jan 01, 2012 | 2001 Cadillac DeVille
Model Ford Tourneo Kombi. fault: a/c works but fan only operates on max speed (positions 1 to 3 fan wont work) any clues welcomed
Sounds like an blower motor resistor. It regulates voltage going to the motor depending on what speed you select. Speed one , or low only lets so much voltage to the motor and full lets all the voltage through. If it is blown, it cannot regulate voltage and acts like its not there. I would start with that.
Aug 14, 2011 | Ford Transit Connect Cars & Trucks
Blower only operates at full speed ; what needs to be done so it will operate at lower speeds?
you need to change a part on the blower syatem , that a resistor is mounted near the fan . that will give you the lower speed
Jul 26, 2010 | 1992 Honda Accord
Air conditioner won't run
it sounds like you have a bad fan, they are typicaly easy to replace. Just find the old one either on the fire wall of your car or under the dash.
Feb 03, 2009 | 2000 Buick Regal
Bay Model # 526-012 Fans what size speed control
I can't see any reason why a Leviton fan speed control couldn't be used on any ceiling fan, after all, I don't even think Leviton makes ceiling fans. Second, you may be able to try using the 1.5 amp fan speed control and see if you can get by. The worst that could happen is the speed control wouldn't work or would only work for a short time and be junk.
Jan 03, 2009 | Hampton Bay (261025) Dual Mount Ceiling...
18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
Kitchen Ranges Logo
180 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
