I erased my DVDRAM GSA-4084N software by accident. What can I do?
I have a dv5215us Hp Pavilion Notebook. I went into the registry and deleted some files to try and get my DVDRAM to work properly - it had an error code 39. Now I no longer have a DVD/CD drive showing up on my computer. What can i do?
  • jack_pirate1 Jan 29, 2009
    my dvd hard disk not display at my computer
  • JDTec
    JDTec May 11, 2010
    Do a sytem restore to an earlier restore date when the laptop was working.
    President:
  • 1,257 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
Posted on Jun 27, 2009
    Sergeant:
  • 183 Answers
Honestly, you meesed up your Registry so you need to restore them back.
First step:
Reboot your laptop
and as soon as it starts press F8 (repeatedly) untill you are taken to DOS mode
once you reach the DOS mode
choose Last Known Good Configuration Option and hit enter
now check you drive that should be there
if still remains the bug
Then
2nd step:
Insert your Recovery disk (don't worry about not being displayed drive) in DVD/cd drive
then
Click on start>Run then type in "scf /scannnow" without quotes (and there is space between scf and /).
then hit enter
it should recover your all settings back.
if this does not help then
Last option:
Go to the HP website and download(free of cost) driver for you Laptop and Install back in.
now you are good to go.
by the way, i just would like you to inform that we need to create registry back up before we start playing with it because if anything happens then we can get all registry back in seconds.
Thank you.
Rate answers and post back if anything changes.
Posted on Jan 02, 2009
HP dv6636nr DVD/CD not working
This is a common problem try this: Windows XP
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Jan 27, 2010 | HP Pavilion dv6000z Notebook
HL-DT-ST DVDRAM GSA 4084N driver is missing or corrupt
my laptop doesnt want to play my dvd its telling me im missing a plug in for windows can somebody help me please
Sep 18, 2009 | HP Computers & Internet
DVD Drive not reconized,"HL-DT-ST DVDRAM GSA-T50N"
Dear Sir,
It is not problem with your hardware,it is problem with your operating system. This happens due to invalid registry entry on the system files,you may clean the registry by using glary utiliy or any other free registry cleaning software,it may solve your problem.If it is not you have to reinstall windows operating system by formatting your system drive.
if you find any difficulty post a feedback,we will glad to assist you.
I think it helps
Have a nice day !
good luck
Sep 14, 2009 | HP Compaq Presario SR1420nx...
HL-DT-ST DVDRAM GSA-T20N ATA Device will not read any discs and has a error code 39. HL-DT-ST DVDRAM GSA-T20N ATA Device (code 39) will not work, any help pease? I have the same problem,,my notebook is a...
I read over the solution to the problem by deleting the lower keys in the registry,,restarted and it works fine again,,thank you.
The 1st time I tried it, there was now upper or lower keys because i had uninstalled the driver 1st.
Jan 04, 2009 | Intel Durabook V38263 Notebook
HL-DT-ST DVDRAM GSA-T20N ATA Device will not read any discs and has a error code 39. HL-DT-ST DVDRAM GSA-T20N ATA Device will not read any discs and has a error code 39.
try this ..
you must start regedit ( start -> run [See screenshots at the bottom] Type here: regedit )
search the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class/
search for "4D36E965-E325-11CE-BFC1-08002BE10318"
if you doesn't find anything, search only for a part of the string.
now search the propertys UpperFilter an LowersFilter and kill the value. If only one prop. is there, you must kill only the one value
on my laptop it works!!
http://www.computerhilfen.com/hilfen-26-186214-0.html
cheers ...
Oct 21, 2008 | Computers & Internet
HL-DT-ST DVDRAM GSA-T20L ATA Device
ok you can do two things to fix it
first of all go to start
go to run
type regedit and hit ok
now in the registry go to this path
and remove both upper and lower filters from the right pane
now close the registry editor.
reboot the computer and see if that fixed it or not
if not the download the drivers from this website.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3224052&lc=en&cc=us&dlc=en&lang=en&cc=us#
just select the operating system that u have and then download it and reinstall the driver and then reboot the computer
that should be it
if still not working then i guess its a hardware issue
cheers
Sep 04, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
588 people viewed this question
David Payne
David Payne
