Question about Dynex 32 in. LCD Flat-Panel HDTV
Setting the clock on the dx lcd32 09
The word "clock" is grayed out in the menu indicating i have no access to change it. how can the time be changed?
thanks,
howie
  • howsterfeld Jan 04, 2009
    tried several times to no avail. dynex couldn't help either. i guess i could live without a clock on my tv.
    thanks
  • howsterfeld Jan 09, 2009
    dynex support actually said to hook the tv to my digital box, but to do that was a real bother since my main tv was already in the entertainment center. your suggestion seems very reasonable. if i can find the resolve, i may take your suggestion.
    thanks
    Problem Solver:
  • 10 Answers
Go to your local pbs channel then turn off tv turn back on and wait for auto time set to kick in.
Posted on Jan 02, 2009
    President:
  • 814 Answers
How do I program my clock/time?1.Press MENU. The on-screen menu opens.2.Press < or > to select Time, then press v to access the Time menu.3.Press ^ or v to select Time Zone, then press < or > to select a time zone. You can select Pacific, Alaska, Hawaii, Eastern, Central, or Mountain.4.If your viewing area observes Daylight Savings Time, press ^ or v to select Daylight Saving Time, then press < or > to select On.5.You are unable to physically change the date or time as this information is automatically be obtained from the digital or cable signal received by your TV. This information is from the frequently asked question section on the customer support page for your model television.The Dynex customer support web page is: (http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) copy this web address and paste it into the address bar in your browser. This will take you to the customer support web page for you model television. This will give access to all the technical information. The Dynex customer support telephone number is 1-800-305-2204. you can call them between the hours of 7am-12am CST. I hope this information helps you with your problem.
Posted on Jun 06, 2009
According to the documentation in the manuals, the clock is only able to be set is you have an HD/digital cable service hooked up to it. the tv is supposed to auto set from the feed. sort of like your cell phone does when it has contact with the system.
Posted on Jan 09, 2009
How do i change the clock on a 06 Nissan Lafesta, manual is in japanes
Hope this helps
If you are talking about the clock on the DVD display then.....
Audio display model
1. Turn the audio unit on by pushing the "PWR"
button.
2. Push the "MENU" button until the display
indicates the clock adjustment mode.
If the "CLOCK OFF" is indicated on the display,
push the "TUNE" button to change the mode
to "CLOCK ON". Then push the "MENU" button
The time indicator will flash.
3. Push the "SEEK TRACK" button to adjust
the hour.
Push the "TUNE" button to adjust the
minute.
Pushing the , buttons will advance
and , buttons will turn back
the time.
4. Push the "MENU" button to finish the
adjustment.
May 24, 2014 | Cars & Trucks
Setting the clock
HI,
Please give me a min.i'll let you know if there's a manual available for your model
Apr 24, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Explain how to set the date in the bottom right corner of my computer screen
  • Double click the time display on the bottom right of the computer screen to open the date and time properties box. Use the tabs to access settings for time, date, time zone and Web-based time updates.
  • 2 Set the clock for the correct time zone. Click the "Time zone" tab. Click the drop-down menu for time zone choices. Click the time zone choice for your area. Click a check in the box for automatic updates on daylight saving time changes. Click the "Apply" button, then the "OK" button.
  • 3 Set the correct date. Click the "Date and time" tab to show clock and calendar settings. Click the drop-down menu displaying the name of a month to change the month. Use the up-and-down arrow keys to change the year being displayed. Click on a date on the calendar image to set the date. The time can be manually set on this page also.
  • 4 Set the current time. Use the up-and-down arrow keys next to the numeric time display on the date and time page to manually set the clock. Click "Apply," then click "OK" to confirm date and time settings.
  • 5 Click the "Internet time" tab to use a Web-based clock for updates to automatically correct the time. Click the "Server" drop-down menu for listed Internet time sources. Click a check mark into the check box for automatic synchronizing. Click the "Update now" button, then click the "OK" button.
Sep 12, 2011 | Dell Dimension 4700 PC Desktop
How do you set the clock in a 2011 Porsche cayenne turbo?
You use the indicator stalk to access to menu.
Navigate your way to settings, the select the Clock option and set the time using the rocker switch, you can also format the clock to 12 /24 hour
Mar 14, 2011 | 2011 Porsche Cayenne
Can not change date and time the clock is not highlighed and the date it has is 1/01/2006 5:52 instead of 9/27/2010 11:50 The next question is I can not program the direct tv remote for the imput
Your tv is needs a digital signal to set the time.
So if your just using an xbox or ps3 you will not be able to do it.
If you have your cable / direct tv hooked to it.
You should be able to go to the "Menu" button select it.
Then in the Menu display it should show a "time" box or clock icon.
If the Icon for time does not show up then you do not have the
correct connection.
I'm using the Dynex as a computer monitor, direct connect and I do
not get the icon for time.
Therefore I can not change the display time for the TV.
Hope this helps.
Sep 28, 2010 | Dynex DX-L42-10A 42 in. LCD TV
How do you adjust the clock on a porsche cayenne s 2005
Hi, British Summer time hey! You can use the indicator stalk to access to menu.
Navigate your way to settings, the select the Clock option and set the time using the ricker switch, you can also format the clock to 12 /24 hour - enjoy!
Bash.
Apr 14, 2009 | 2005 Porsche Cayenne
Setting the time
Setting Time
1 Press TITLE repeatedly until the time is displayed.
For details, see “Displaying the Text” (page 13)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the “hour.” Minutes will reset to “00”. If the display shows
over “30” minutes when you do this, the time will advance one hour.
Listening to Radio
1 Press SOURCE/POWER until a radio frequency
appears on the display.
2 Press BAND repeatedly until the desired radio band
is displayed.
F1 (FM1) F2 (FM2) AM F1 (FM1)
3 Press TUNE to select the tuning mode.
DX SEEK (Distance mode) SEEK (Local mode)
OFF (Manual mode) DX SEEK
• The initial mode is Distance mode.
Distance mode:
Both strong and weak stations will be automatically tuned in
(Automatic Seek Tuning).
Local mode:
Only strong stations will be automatically tuned in (Automatic
Seek Tuning).
Manual mode:
The frequency is manually tuned in steps (Manual tuning).
4 Press or to tune in the desired station.
Holding down or will change the frequency
continuously.
Manual Storing of Station Presets
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish
to store the station.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
•You will need to start from set up or you will not be able to set the mins
Dec 31, 2008 | Alpine CDE-9852 CD Player
Setting the clock on a Comdial DX-80 Digital phone
To change Comdial phone read out time
feature
######## (8 pounds)
show
0814
save (System time)
show (Year)
next (Month)
next (Day)
next (Weekday)
change enter what you want to change
Mar 25, 2008 | Lands Phones
Oven control panel
Lok at your manual tp view all the possible control options. However, the solution could be; The touchpads, in conjunction with the dial, are used to select an oven mode,
set the oven temperature, set the time(s) and to set up your range. To use the
touchpad, press the center part of the pad with the flat part of your fingertip. A
beep will sound to indicate that the selection has been made. Turn the dial to the
desired setting and press START.
Pull the plug or flip the circuit breaker, wait five seconds and plug in the range or flip the circuit breaker to on. Always set the clock after installation or after a power failure. Once power returns to the oven, the clock defaults to 12:00 am.
Clock time display can be turned off. The default display is on.
1. Access SELECT FUNCTIONS Menu.
2. Turn knob clockwise until CLOCK DISPLAY is displayed.
3. Press START.
4. Turn knob to select ON or OFF
5. Press START to accept new selection.
Reset the Factory Settings This feature is used to change all the “Select Functions” settings back to the original factory settings (or defaults).
2. Turn knob clockwise until RESET DEFAULTS is displayed.
3. Press START. Display reads SELECT FUNCTIONS.
Dec 03, 2007 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
Dynex 32 in. LCD Flat-Panel HDTV Logo
446 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
