Question about Dell Inspiron 6400 Notebook
Won't Reboot after installing new RAM
I have a DEll Inspiron 6400 it had 512 mb of RAM I purchased 1 stick of 1gb and when i try to power up the computer the lights flash and then it shuts down
Thanks for the Help Matt
  • 30 Answers
If you remove the 1GB memory that you were trying to install and it will boot, then it is your new memory that is not compatible. Check here for what memory will be compatible with your laptop.
Posted on Jan 02, 2009
I have purchase a memory upgrade KByte and not sure how to install. I went to www.kbytememory.com and found nothing to help me.
This looks very much like my old M90... you pop out the battery, locate and unscrew the memory door, and then snap in the new memory. Then restart the laptop... if it beeps at your (this is called a beep code) then the BIOS doesn't recognize one or both of the sticks. Assuming all goes well it should prompt you and say something to the effect of 'amount of system memory has changed, press F1 to continue or F2 for bios'... go into BIOS and confirm its reading the new memory amount (2GB will say 2064). This model apparently only accepts 2 x 1GB sticks so hopefully you didn't order 2GB sticks... unless there's a BIOS update you can install the mobo won't recognize memory sticks greater than 1GB. Good luck.
These links will be very helpful... please rate me if this helps you:
http://www.ifixit.com/Guide/Installing-Dell-Inspiron-E1705-RAM/3987/1
This is the parent page for the E1705:
http://www.ifixit.com/Device/Dell_Inspiron_E1705
Jan 15, 2012 | Dell Inspiron E1705, Intel Core 2 Duo...
Unit came with 2 256 mem sticks--bought and installed 2 1GB sticks(pc3200,400mhz,84pin,low density,DDR--unit will not boot
The 2 1Gb RAM are either the wrong type or they are incompatible.
Try to use the same brand and speed as the 256 Mb RAM that was installed in your Dell.
Jul 31, 2010 | Dell Dimension 3000 PC Desktop
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
Jul 26, 2010 | Dell Precision Workstation 670 PC Desktop
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
Physical Memory Issue!
What happens after you reboot and check?
Jun 17, 2009 | Dell Inspiron 1521 Notebook
My Dell C600 won't recognize the 2 new 256 mb sticks of RAM
i think you need a same brand of 256 for it to work? and when you buy something for your computer make sure that the one you both is the same brand or code with your 128 for example you have 128 ddr2 sdram so you can only upgrade it with 256 ddr sdran or 512mb,1gb,2gb ddr sdram.
May 01, 2009 | Dell Latitude C600 Notebook
I CANNOT FORMAT AND INSTALL A NEW OS
You RAM module may be faulty or needs reseating in the DIMM slot B. Reseat the both RAM modules then :-
Check the POST information as it boots up, the amount of install RAM should equal to the installed RAM (the total RAM could be 256Mb or 512Mb or 1Gb depends how much memory you purchased with the laptop) less 64 Mb or 128 Mb RAM which is used for video memory (depends upon your video card requirements).
Once you fix your RAM problems you should be able to reinstall Windows.
Mar 04, 2009 | Dell Inspiron 1525 Notebook
Dell 2400 ram upgrade problem
RAM can be finicky so first test all memory slots with a known good stick (your 512MB). Make sure you're starting from a complete power down and you get a POST beep (hopefully your system is set up to beep when it powers on) and everything loads up all the way through to your OS.
Once you do that with all your memory slots test with the new stick by itself in all memory slots. If neither of the memory slots work with the new stick but you verify that it works in another system you should then check your BIOS settings and RAM timings to ensure compatibility with your stick. If you can't find the timing on the RAM stick itself, look up the manufacturer's part number for the information.
Feb 03, 2009 | Dell Dimension 2400 PC Desktop
Error message after installing memory ram upgrade.....
The memory appears to be the right kind.
Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
Dec 20, 2008 | Dell Inspiron E1505 Notebook
Upgrade from 512MB to 1GB
The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
Mar 15, 2008 | ASUS P4B266 Motherboard
Dell Inspiron 6400 Notebook Logo
117 people viewed this question
Alun Cox
